Dropped the Fazer
Andy_Pagin
PostPosted: 17:01 - 29 Jan 2017    Post subject: Dropped the Fazer Reply with quote
No idea how I managed this, I had it on the centre-stand, oiling the chain and it rolled forward off of the stand. Luckily it was near the garage and the fairing hit the garage door which saved a lot of damage.
The only damage I can see is that the fairing has a split and is now at the wrong angle. It looks like the fairing is only held on by a couple of rods connected to the yoke which appear twisted.
Is it just a case of replacing the rods, in which case what are they called? Or is it worth trying to straighten them, I suspect getting them dead right will be a bit tricky.
I took this pic on the side stand then 'shopped it to make the bike look upright, you can see the fairing's twisted.
https://i636.photobucket.com/albums/uu84/anadin96/rotated.png
https://i636.photobucket.com/albums/uu84/anadin96/2017-01-29%2015.03.31_with_note.png
From the back
https://i636.photobucket.com/albums/uu84/anadin96/2017-01-29%2015.03.24.jpg
SilverWings
PostPosted: 17:21 - 29 Jan 2017    Post subject: Reply with quote
No input on how to fix it I'm afraid but I'm so glad I'm not the only one doing dumb stuff like this today. I dropped my ER5 when I got to work because the side stand got caught in my trousers and I pulled it back up without noticing...
Andy_Pagin
PostPosted: 17:25 - 29 Jan 2017    Post subject: Reply with quote
Laughing Thanks for finding a funnier way than mine to drop a bike.
SilverWings
PostPosted: 17:27 - 29 Jan 2017    Post subject: Reply with quote
Ah that's not even the best I've done, 2 bikes back I had a 600 bandit, dropped that when I left the disc lock on and tried to back it up...
doggone
PostPosted: 17:42 - 29 Jan 2017    Post subject: Reply with quote
Sometimes you can just stand astride front wheel facing the bike and wrench the bars while gripping the wheel with your knees to get it something like - especially if this in the middle of the moors at 1am Rolling Eyes
In the shed you might slacken things off and do more or less the same, it's unlikely anything actually bent.
Andy_Pagin
PostPosted: 17:50 - 29 Jan 2017    Post subject: Reply with quote
doggone - thanks, I'll give it a try in the morning with a breaker bar. I actually tried with a big screwdriver, I now have a bent screwdriver. Not wishing the afternoon to degenerate into a Mr. Bean sketch I thought I'd consult the BCF sages before trying anything heaftier.
PostPosted: 17:51 - 29 Jan 2017    Post subject: Re: Dropped the Fazer Reply with quote
Definitely. I'd be in there with a scaffold pole or similar. Just don't bend the actual frame.
Andy_Pagin
PostPosted: 17:59 - 29 Jan 2017    Post subject: Reply with quote
I suspect they're a deliberate weak point, I'm not too worried about the frame, I'm not a big muscly geezer.
Andy_Pagin
PostPosted: 19:45 - 29 Jan 2017    Post subject: Reply with quote
Fazer. wrote:
That will be the fairing mounting bracket they can be manipulated fairly easily remove the mirrors screen fairing and lights. Then lots of minor whacks with a rubber mallet keep checking until it is spot on as it will piss you off every time you look at it if it's slightly out.
Bugger that it happened on a Sunday, best I can do before work tomorrow is a breaker bar between the two rods of the bracket. Failing that I'll try your method. Amazingly there appears to be a used (straight) assembly on Ebay for £55 at the moment.
Evil Hans
PostPosted: 20:30 - 29 Jan 2017    Post subject: Reply with quote
Had a similar issue when the Bandit fell over. I managed to crowbar / rubber mallet it more or less back into shape .... Then spotted a good used one on eBay for only £20. No brainer.
kramdra
PostPosted: 22:10 - 29 Jan 2017    Post subject: Reply with quote
How much Shocked
It wont be straight.
Evil Hans
PostPosted: 23:06 - 29 Jan 2017    Post subject: Reply with quote
kramdra wrote:
How much Shocked
To be honest it was probably over 30 with postage. It was perfectly straight though. And a lot less rusty than the one I took off.
Bandit parts seem to be cheaper though ... Probably more get written off because they are owned by idiots Wink
The last post was made 9 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 79 Kb
