Lexmoto FMR 125 Jerking High Revs, Then Cuts Out!
KyleiAm
PostPosted: 08:27 - 30 Jan 2017    Post subject: Lexmoto FMR 125 Jerking High Revs, Then Cuts Out! Reply with quote
So i've had this bike since June 2016, done 5KM going to work and back and this morning going to work it started jerking at 30MPH+ then cut out and wouldn't start for 5 minutes or so, Now it won't start every time, i have to keep trying for 5 minutes or so then it does, then off i go and when it get's to high revs 30MPH+ it jerks and cuts out, could this be down to battery?
If so does it need charging or is it ballsed.
Bought the bike brand new, only done 5KM.
Thanks.
andyscooter
PostPosted: 08:36 - 30 Jan 2017    Post subject: Re: Lexmoto FMR 125 Jerking High Revs, Then Cuts Out! Reply with quote
Thanks.
test the battery and see what voltage it has with a multi meter
should be 12.5 volts normal going up to about 14 when running
also before you get karma bombed should be in workshop area
PostPosted: 09:19 - 30 Jan 2017    Post subject: Reply with quote
Bombers were already in flight.
It's starting and running at low RPM, so I wouldn't suspect the battery.
Either the electrics are spazzing out, or you're not getting enough fuel through.
When it cuts out, immediately shut off the fuel tap, and then drain the float bowl. Is there fuel in it?
On the electrics, is the plug cap secure? Any sign of cracks in the cap or the HT lead? Follow the HT lead from the plug to the coil, and check that everything is secure, including the low tension terminals on the coil.
andyscooter
PostPosted: 09:39 - 30 Jan 2017    Post subject: Reply with quote
Think it's a scooter rog so no proper fuel tap
6 months old and only 5 kms
Or is that 5000 kms
PostPosted: 10:12 - 30 Jan 2017    Post subject: Reply with quote
Oh, I was thinking of the Superbyke (and others) RMR, since OP said "bike". Since it's a scootay, I'd like to change my advice to "It's within warranty, so it's Lexmoto's problem."
NutsyUk
PostPosted: 12:59 - 30 Jan 2017    Post subject: Reply with quote
It could be the tappets? Very Happy
Actually at 30MPH it prolly isnt... I had a similar problem but it was after sustaining 60mph on a slight incline for a while...
Oh and welcome to the forum...
Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Kawasaki ER6F 2007 650 Gonna sell as a project bike!
Lexmoto XTR S 125 Sold!
KyleiAm
PostPosted: 13:27 - 30 Jan 2017    Post subject: Reply with quote
Or is that 5000 kms
That would be 5000KM lmao, do 20 miles a day to work and back.
It's going in garage tomorrow to be sorted so not my problem anymore.
The last post was made 9 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 52.32 Kb
