!!!NC30 Head light!!!
Whitetrash This post is not being displayed because the poster is banned. Unhide this post / all posts.
Scotsman37
PostPosted: 22:30 - 01 Mar 2005    Post subject: Reply with quote
Use some insulation tape on the top 3rd of the headlight so that it doesn't blind on coming drivers so as to get it home.
Scotsman37
PostPosted: 22:41 - 01 Mar 2005    Post subject: Reply with quote
https://shop.wemoto.com/pictures/hl/be56e.jpg
for the VFR 400 R3N (NC30)
12v 60/55 watts
bike technical spec
https://www.motorcyclelane.com/spec.html
Scotsman37
PostPosted: 22:52 - 01 Mar 2005    Post subject: Reply with quote
It's your bulb because when you press the pass button it uses the main beam to create the flash effect and so your bulb is faulty because I have had that same problem a year ago when I could only use the dip part of the bulb.
Scotsman37
PostPosted: 22:56 - 01 Mar 2005    Post subject: Reply with quote
12v 60/55 watt and I've already supplied a pic of what it looks like !
You can buy it from Halfords and petrol stations/garages usually stock a selection of headlight bulbs and so they may have that one or you could buy via this link;
Scotsman37
PostPosted: 23:39 - 01 Mar 2005    Post subject: Reply with quote
do both of your headlights goto dip ?
You'll need to inspect the high beam relay as it should click when you flip the switch to high beam and if it doesn't check for a loose connection and/or check for a blown fuse otherwise you maybe looking a new high beam relay.
Here's info from VFR400 manual in regards to headlight.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 13:58 - 02 Mar 2005    Post subject: Reply with quote
Err if it's an import spec nc30 (which most are) a UK spec 60/55 bulb will not fit without modification to the bulb, and fiddling with the electrics. Think the Jap spec is 60/35 watt or something similar with differently spaced tabs.
A local shop wanted £25 for one, which is scandalous. I got one for £6 from another shop, can't remember the code though. It's not a bulb you'll find in generic auto shops, you'll need to goto a bike shop and ask there.
Scotsman37
PostPosted: 17:34 - 02 Mar 2005    Post subject: Reply with quote
VFR 400R NC30 Service Manual
https://x-files.serveftp.com/harkermaticwebspace/1nc30/ncarticles/manuals/nc30%20servicemanual.zip
VFR 400 NC30 HRC Manual
https://x-files.serveftp.com/harkermaticwebspace/1nc30/ncarticles/manuals/nc30%20hrcmanual.pdf
VFR 400 NC30 Parts Fiche
https://x-files.serveftp.com/harkermaticwebspace/1nc30/ncarticles/manuals/nc30%20microfiche.pdf
EuropeanNC30R...
Gay Hairdresser
PostPosted: 17:42 - 02 Mar 2005    Post subject: Reply with quote
Another thing is that if you do modify a H4 bulb to fit a grey nc30, without modifying the electrics, it'll eventually lead to a relay getting burnt out.
I can't remember the exact details, it's all on www.400greybike.co.uk
Dom_
Points Mean Prizes
PostPosted: 22:51 - 02 Mar 2005    Post subject: Reply with quote
Do you carry a laptop around with you, connected up to your mobile phone??
If not, how the hell did you post all this? Confused Confused
Scotsman37
PostPosted: 23:27 - 02 Mar 2005    Post subject: Reply with quote
Doesn't have to be an actual laptop as it could a handheld Ipaq with a foldable keyboard to utilise internet access.
Scotsman37
PostPosted: 01:49 - 03 Mar 2005    Post subject: Reply with quote
Whitetrash wrote:
well Dom... what do you think??? or perhaps You thik too much!!!! I stopped at someones house and used their PC then carried out the repair at the side of the road!!! didnt fake it for fun you know! Laughing
Was it a stranger's house and, if so, then what was the look on their face when you said "I've got a problem with my headlights, can I use your PC?". Confused Laughing
I hope you're buying them a pint or 2 for helping you out ! Thumbs Up
Dom_
Points Mean Prizes
PostPosted: 11:43 - 03 Mar 2005    Post subject: Reply with quote
Calm down, i never meant you were faking it. It was just a bit wierd how you kept saying you were miles from home and needed advise, yet you were on the 'net.
The last post was made 21 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 108.09 Kb
