| White Noise |
 White Noise Mr Dudwee
 Posted: 21:47 - 01 Mar 2005 Post subject: Divvy clock lights |
right i have a bit of a wierd problem, not sure when this happened but it may have been in the fall i had on monday, anyway the lights on the rear of the clocks on my 96 divvy are acting up, when i turn my lights on to "sidelights" the clocks light comes on but when i turn the lights on full both dipped and full beam the light behind the clocks go out! can't work it out but i am guessing a wire has come loose somewhere, has anyone got any suggestions of where to start looking?
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
| Kickstart |
 Kickstart The Oracle
| White Noise |
 Posted: 22:29 - 01 Mar 2005 Post subject: |
Hi keith,
Thanks for looking that one up, looked at the wiring diagram in my haynes and can see connection that you mean, think that the wire connecting the switch to the bulbs may have got disconnected as this was the side of the bars that got bent and took most of the impact, when i am checking the voltage with a multimeter where's a good place to take a earth if i can't be bothered to find an earth wire? will the cylinder block do?
| Gazdaman |
 Gazdaman I did a trackday!!!
| Kickstart |
| binge |
 binge Emo Kiddy
 Posted: 00:44 - 02 Mar 2005 Post subject: |
I know its not a bike, But my rev counter on my mini was doing this. When I had my lights OFF, The rev counter worked fine, But when I turned my lights ON, The light on the rev counter did NOT work and the rev counter also turned off. As soon as I turned the lgihts off, The rev counter came back on.
It was infact a bad earth from the Rev counter. This Could be the problem with yours, but dont count on it, its just an idea
<|Ben|> |
The last post was made 21 years, 266 days ago. Instead of replying here, would creating a new thread be more useful? |
