Divvy clock lights
White Noise
Mr Dudwee
PostPosted: 21:47 - 01 Mar 2005    Post subject: Divvy clock lights Reply with quote
right i have a bit of a wierd problem, not sure when this happened but it may have been in the fall i had on monday, anyway the lights on the rear of the clocks on my 96 divvy are acting up, when i turn my lights on to "sidelights" the clocks light comes on but when i turn the lights on full both dipped and full beam the light behind the clocks go out! can't work it out but i am guessing a wire has come loose somewhere, has anyone got any suggestions of where to start looking?
WN
PostPosted: 22:11 - 01 Mar 2005    Post subject: Reply with quote
Looking at the wiring diagram it looks like a common wire from the light switch to the clocks irrespective of whether it is on dip or main beam. I would suspect that the problem is a dirty contact in the light switch.
White Noise
Mr Dudwee
PostPosted: 22:29 - 01 Mar 2005    Post subject: Reply with quote
Hi keith,
Thanks for looking that one up, looked at the wiring diagram in my haynes and can see connection that you mean, think that the wire connecting the switch to the bulbs may have got disconnected as this was the side of the bars that got bent and took most of the impact, when i am checking the voltage with a multimeter where's a good place to take a earth if i can't be bothered to find an earth wire? will the cylinder block do?
WN
Gazdaman
I did a trackday!!!
PostPosted: 22:58 - 01 Mar 2005    Post subject: Reply with quote
My non-divvy did the same the other day.
When on pilot lights they're on, switch to dipped beam and the clock lights go out.
Have a bit of a fiddle with the switch and they come back, loose connection in the RH switchgear?
Gaz
PostPosted: 00:30 - 02 Mar 2005    Post subject: Reply with quote
If the multimeter leads are long enough then use the negative terminal of the battery. Otherwise the engine block will do fine.
binge
Emo Kiddy
PostPosted: 00:44 - 02 Mar 2005    Post subject: Reply with quote
I know its not a bike, But my rev counter on my mini was doing this. When I had my lights OFF, The rev counter worked fine, But when I turned my lights ON, The light on the rev counter did NOT work and the rev counter also turned off. As soon as I turned the lgihts off, The rev counter came back on.
It was infact a bad earth from the Rev counter. This Could be the problem with yours, but dont count on it, its just an idea Thumbs Up
<|Ben|>
The last post was made 21 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 50.51 Kb
