Chain lube - WD40?
onlyJaz
PostPosted: 16:28 - 01 Feb 2017    Post subject: Chain lube - WD40? Reply with quote
I was just wondering if anyone has used this on their chain? Is it any good?
https://www.halfords.com/motoring/engine-oils-fluids/lubricating-penetrating-oil/wd-40-specialist-high-performance-ptfe-lubricant-250ml
What chain lube would you recommend?
Not sure about wet/dry etc
Yamaha YBR 125
TheArchitect
PostPosted: 16:30 - 01 Feb 2017    Post subject: Reply with quote
why not use purpose-made chain lube? [serious question]
GSXR 600 K6 - Stolen
MT09 - Almost stolen
onlyJaz
PostPosted: 16:32 - 01 Feb 2017    Post subject: Reply with quote
I probably will if I can agree on a particular one (still a bit of a noob). I just saw this and wondered if it's good I guess could be multi purpose..
Yamaha YBR 125
GrumpyGuts
PostPosted: 16:33 - 01 Feb 2017    Post subject: Reply with quote
I would not put that shit on any motorcycle chain, let alone a bicycle chain.
Use a lube designed for that purpose, only
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
tom_e
PostPosted: 16:34 - 01 Feb 2017    Post subject: Reply with quote
WD40 do a proper chain lube and a chain wax as well, I've been using their wax for the last year or so and it's decent sticks around with 200 miles a week commuting and doesn't cover everything in fling.
You'll get a million different answers though, chain lubes are very much personal preference.
TheArchitect
PostPosted: 16:37 - 01 Feb 2017    Post subject: Reply with quote
I can't recommend any over the other as frankly to me they all do the same thing.
I've been using the WD40 branded chain cleaner and lube for a while now and think it does the job just fine. A quick squirt of lube every weekend works fine for me, but I only do approx 120 miles most weeks.
mkjackary
PostPosted: 17:08 - 01 Feb 2017    Post subject: Reply with quote
Use gear oil 80w90 automatic transmission oil is the best suited as far as I know. Get it cheap from eurocarparts for about 4 quid including postage and then buy an oil can to apply it.
Apply it after a ride when it is hot and then leave it whilst it cools down and the change in temperature will suck the oil into the chain, not just coat the outside of it.
By the morning almost all the excess will have dripped off. If you feel fancy you can leave a drip tray or old oven tray underneath to catch the excess.
wr6133
PostPosted: 17:31 - 01 Feb 2017    Post subject: Reply with quote
Having tried various Chain lubes/waxes/old oil I settled on this stuff
https://www.ebay.co.uk/itm/4x-Wynns-10179-Clear-Lube-500ml-Aerosol-Wynns-NEW-MULTIBUY-SAVER-/331703785691?hash=item4d3b1618db:g:aJUAAOSwI-BWQJUb
Sticks quite well, doesn't fling too much, can lasts ages. If you have a Range near you they sell it for about £7 a can.
lilredmachine
PostPosted: 19:24 - 01 Feb 2017    Post subject: Reply with quote
https://www.ajsutton.co.uk/product/LUCAS%20OIL/LU10014/Chain%20Lube,%20CLEANING-CARE?gclid=CIbYqP3B79ECFeqc7QodRPQN7Q
What I use. I run a O-ringless drag chain on the bandit, they don't hold lube like an O-ring chain and wear excessively when dry so keep a stock of this.
On something like my commuter bike it lasts for about 4 weeks between applications in all weathers.
Seriously good stuff and cheap for the amount you get.
kramdra
PostPosted: 20:10 - 01 Feb 2017    Post subject: Reply with quote
All of the above are inferior to used engine oil. Apply large amounts with a squirter each morning and clean once every 6 months/year.
Fisty
PostPosted: 20:29 - 01 Feb 2017    Post subject: Reply with quote
Fit a Scottoiler.
Fatter and faster than Fret
lilredmachine
PostPosted: 20:45 - 01 Feb 2017    Post subject: Reply with quote
Fisty wrote:
Fit a Scottoiler.
Rubbish, ready made vacuum leak. Also has a habit of only oiling one side of the chain. In order of usefulness it came slightly behind the broken neons fitted to the rear of my Busa when I got it. They're an excellent way of flushing 100 quid down the shitter though.
PostPosted: 20:50 - 01 Feb 2017    Post subject: Reply with quote
[citation needed]
Fisty
PostPosted: 21:10 - 01 Feb 2017    Post subject: Reply with quote
lilredmachine wrote:
Fisty wrote:
Fit a Scottoiler.
I can taste your salty tears from here.
Ive had them fitted to my last 3 bikes, including the TL. Never had a vacuum leak, correctly set up they oil both sides of the chain perfectly, and my last set of chain and sprockets lasted 23k miles. I only ever adjust the chain when I need to change tyres.
redeem ouzzer
PostPosted: 21:18 - 01 Feb 2017    Post subject: Reply with quote
Fisty wrote:
Fit a Scottoiler.
Are you trying to become a lolcow?
Scottoilers are love, scottoilers are life.
Be a REAL MAN!
PostPosted: 21:41 - 01 Feb 2017    Post subject: Reply with quote
Fisty wrote:
my last set of chain and sprockets lasted 13k miles.
Mine are on 19, 19, n-n-n-n-nineteen. Occasionally I give the (X-ring) chain a scrub with paraffin and wipe some axle grease over it.
Shall we consider that the control group?
Fisty
PostPosted: 21:48 - 01 Feb 2017    Post subject: Reply with quote
But you ride like a penny pinching Scott and its not a 135bhp v-twin you ride. Amrite?
lilredmachine
PostPosted: 21:51 - 01 Feb 2017    Post subject: Reply with quote
Precisely. A meticulously hand maintained chain will always last longer than a machine maintained chain. The lube I posted requires almost-never maintenance all the way through winter.
lilredmachine
PostPosted: 21:54 - 01 Feb 2017    Post subject: Reply with quote
210rwhp Bandit, 165rwhp Busa, GSX6/12 here. All ridden like a cunt at all times and through winter. No car licence. Thumbs Up
Fisty
PostPosted: 21:57 - 01 Feb 2017    Post subject: Reply with quote
So, you are going to clean and relube your chain daily while riding through winter are you? Are you?
Scottoilers are for the lazy, I am the lazy, most people who ride bikes through the winter are not going to come home after a days work and clean then relube their chain.
lilredmachine
PostPosted: 22:01 - 01 Feb 2017    Post subject: Reply with quote
Uh, no. you must have missed this:
If you go to a drag event at Shakespeare County/Santa Pod it's usually what you have available to buy. Never encountered a scott oiler tent there. Smile
Johnnythefox
PostPosted: 22:07 - 01 Feb 2017    Post subject: Reply with quote
Chainpal?
Fisty
PostPosted: 22:08 - 01 Feb 2017    Post subject: Reply with quote
I didn't miss anything.
4 weeks between aplications is not meticulous. 4 weeks is bodygurad levels of maintainance. Daily is meticulous.
I wasnt refering to you, but im sure your chains would last longer with a scottoiler and shorter maintainance periods.
pdg
You go to an event at a venue to dress up like a girl?
Seems a lot of hassle, should do it at home like the rest of us and save a trip.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
pdg
PostPosted: 22:11 - 01 Feb 2017    Post subject: Reply with quote
Both of them have a misfire?
The last post was made 9 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Goto page 1, 2, 3, 4  Next
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 134.97 Kb
