In bandits we trust
Riderz This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
Monkeywrenche...
PostPosted: 12:47 - 03 Feb 2017    Post subject: Reply with quote
with the brake light staying on it sounds like the brake is not releasing fully (at the lever). do you have aftermarket levers fitted?
Examine the lever/pivot etc very carefully see if it's sticking for some reason.
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
Riderz
PostPosted: 12:50 - 03 Feb 2017    Post subject: Reply with quote
They are after market however to my knowledge they are completely stock but anodised gold. Maybe I should buy another set?
|CURRENT RIDE:MK1 GSF600N| PAST BIKES:Varadero 125/RS125 x2./XT400/KLR650/CBR 500R/. A2 LICENSE SUCKS
andyscooter
PostPosted: 13:03 - 03 Feb 2017    Post subject: Reply with quote
pull the lever in and press the switch at the back does it work properly
could be a fucked switch
they work the opposite way to the car ones so they light up when there is no pressure
bit like the door light on a car
then strip the caliper and rebuild or get someone to help (sure someone off here local can help) new lines depending on age of yours fresh fluid and if it comes to it a new disc
should put your mind at ease
consider new levers as well if you want
trevor saxe-coburg-gotha
PostPosted: 13:09 - 03 Feb 2017    Post subject: Reply with quote
Riderz wrote:
anodised gold.
Wub
Riderz
PostPosted: 13:17 - 03 Feb 2017    Post subject: Reply with quote
But they have just been rebuilt... the switch is fine I have checked. The levers look 100% stock but just gold
However the lever doesn't like spring back like it does on any other bike I've had it's like I pull it in and let go and it just doesn't spring back... I really don't know what to do anymore I hate it Sad
Beehive Bedlam This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
Bozzy
PostPosted: 13:39 - 03 Feb 2017    Post subject: Reply with quote
I'd definitely start with fitting a set of OE levers to it. I saw a post on here where some fella had incorrectly fitted a set of aftermarkets which caused the front brake to be slightly on. Once he'd ridden a bit the brake fluid got too hot and forced the pad hard against the disk causing the front wheel to lock.
2004 SV650S >>> 2009 Street Triple R
Riderz
PostPosted: 13:59 - 03 Feb 2017    Post subject: Reply with quote
You guys are right! I'll start with this and then I will buy new calipers worst case scenario...
I might even do it up a little Smile
Kaya75
PostPosted: 14:03 - 03 Feb 2017    Post subject: Reply with quote
don't buy new lever - your switch just need pushing back a half millimetre.
replace your old rubber lines too -
read my last reply to your which bike thread Smile
edit: if you got hand guards on it these can push against lever and cause heating issues above Smile
Also I they are floating callipers - so a quick polish of the slider pins can resolve sticking.
if got cash and keeping consider braided lines - reverse bleed with baking syringe and tubing on nibble - bleeding down from cylinders is near impossible Smile
ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2.
Evil Hans
PostPosted: 14:05 - 03 Feb 2017    Post subject: Reply with quote
If only there was a 'workshop' forum where you could ask questions like this Wink
Riderz
PostPosted: 14:06 - 03 Feb 2017    Post subject: Reply with quote
Checked over by a chopper engineer, master cylinder fitted by him he checked the switch and said it's fine Sad
All I can think of is new levers, failing that new calipers
PostPosted: 14:42 - 03 Feb 2017    Post subject: Reply with quote
trevor saxe-coburg-gotha wrote:
Riderz wrote:
anodised gold.
Wub
Blue is best. Folded arms
Brakes are really very simple. Lever pushes a plunger, plunger pushes fluid, fluid pushes pistons. I'd far rather work on my own than trust them to anyone else, choppa engineea or not.
I can think of four possibilities, which I'd check in this order:
1) Your caliper seals or bleed nipple are pissing fluid. This will be obvious because your caliper will be covered in fluid and you are dead.
2) Your lever is sticking. It may simply be bolted on too tightly by the last ape to work on it, or the profile is just not suitable for your caliper.
3) Your M/C piston seals are shot and fluid is escaping past them. When you say your M/C was replaced, do you actually mean the whole assembly, or just the piston and seals? It's possible that the new seals were pre-perished from storage, or just junk, and tore up as soon as the piston went in.
4) Your pistons are sticking, although even at that, there should be some return pressure on the lever.
Kaya75
PostPosted: 14:47 - 03 Feb 2017    Post subject: Reply with quote
cool - but the switch is fine, its the placement of the switch and the pushrod, seriously I had a switch on order, when my mate turned up, grabbed a screw driver and pushed the switch back a tad, sorted.
You should be able to hear the switch click on and off when you pull the lever and release, push the lever out so brake light id off, pull lever and release if there is no click when you release the lever, the switch is too far forward (not the push rod - that I presumed was the switch)
There is about 1.5mm of travel on my lever before it hits the switch "click". The thing is the lever is sloppy so doesn't flick out. I'm not saying replace the switch just adjust it back a little by turning it on the pivot - it's only a little plastic push switch that sits behind the push rod- its the push rod that you can see from the top of the bars, have a look underneath the bars. You should see the lever, then the pushrod that engages the little black plastic push switch.
If the pushrod spring is slightly tired you could replace the levers and even the switch and it won't make a difference as the rod won't disengage the switch..
I hate this about the bandit - its dangerous has the brake light stays on so effectively cars behind me don't know I'm braking has I generally ride with lights on regardless day/night. I check the switch weekly and adjust switch if needed.
anyway I'll stop banging on about it now Smile
nice one for deciding to keep the bandit! Thumbs Up
some links to issues I had:
https://www.bikechatforums.com/viewtopic.php?t=310475&highlight=
https://www.bikechatforums.com/viewtopic.php?t=311113&highlight=
Also Delboy's Garage on youtube - Delboy has some good video's working on bandits. Thumbs Up
this is a pic of fucked nylon brake lines - (pads and calipers are simple the real engineering is in the lines - it should be a nice smooth hole - here they are knackered - will be cause of most brakes sticking)
https://www.amphicar.net/minnow/tech/Brake_plug1.jpg
Holdawayt
PostPosted: 14:48 - 03 Feb 2017    Post subject: Reply with quote
Where abouts are you based?
I'm in the West Midlands and will gladly come and have a look for you, I quite enjoy working on brakes.
Tom.
Riderz
PostPosted: 15:03 - 03 Feb 2017    Post subject: Reply with quote
Tom.
Right at this moment I'm in sw London, thanks tho Smile
Riderz
PostPosted: 15:08 - 03 Feb 2017    Post subject: Reply with quote
We changed just the master cylinder as I trusted the garage rebuilt the calipers properly however I really believe they didn't. Took it back they said it's cos the bike has braided lines. I think something they done wrong. The brakes like I said are either 0% or 100% and also the lever refuses to return like a normal lever would no matter what I do it doesn't make a difference. Last 2 options are change levers but I'm sure this won't work.... or buy new calipers (after spending 200+ on getting my current ones rebuilt)
Kaya75
PostPosted: 15:19 - 03 Feb 2017    Post subject: Reply with quote
mad, are they actually 100% on, like locking up instantly? it can take a while for the pads to bed in, which can make them behave a bit erratic for the first 50+ miles.
I hate to say this, but 200+ quid is a lot of dollar for a rebuild - you could get a recon set for about 120..
The only thing I can think of is lines or the slider pins on the front callipers - but if the pins where not sliding, the disc should be getting warm - sounds like lines not flowing back, which would give you the effect of pumping the levers, meaning you would only have progressive increase with no decrease... stupid bikes!
good luck anyhows Smile
Holdawayt
PostPosted: 15:22 - 03 Feb 2017    Post subject: Reply with quote
It's a really strange one, but if the garage are blaming binding brakes on braided lines it's time to change your garage and assume they fucked up the caliper rebuild.
Without being there in person it's difficult to diagnose, but I really wouldn't be riding the bike with only a rear brake. It should be easy to pin point the issue if I had the bike in front of me.
Riderz
PostPosted: 15:32 - 03 Feb 2017    Post subject: Reply with quote
To explain the brake does not retract. The pump in the master cylinder won't even push in much at all.....
It can only be the calipers causing the problem?
Could the calipers affect the fluid pump in the master cylinder?
I Also believe it is them who fucked this up Sad
tom_e
PostPosted: 15:37 - 03 Feb 2017    Post subject: Reply with quote
It's pretty easy to diagnose if it's the pistons at fault, take caliper off, pump brake lever.
If the pistons start to come out of the caliper body at roughly the same rate and you can then push them back in without having to mallet them then they're moving enough to not be the source of your issue.
Riderz
PostPosted: 15:42 - 03 Feb 2017    Post subject: Reply with quote
I know little to nothing about brakes I don't mess with that kind of stuff just a personal choice....
So I'm not capable of doing any of this I only ever do things like filters/plugs/oil and that side of thing
Evil Hans
PostPosted: 15:53 - 03 Feb 2017    Post subject: Reply with quote
How old are the brake hoses?
It's not *totally* unheard of for the pipe linings to break down and act as a one-way-valve. This can happen with ordinary rubber hoses too, though.
I had it happen on a car once (classic mini) ... brake on one side would snatch and stay on. Traced it to a duff braided hose on the 4-pot converter.
Riderz
PostPosted: 16:12 - 03 Feb 2017    Post subject: Reply with quote
Update! THE WHEEL WONT SPIN FREELY.
I just pulled the bike over and it will hardly spin at all I think this is the brakes binding on yet again!
tom_e
PostPosted: 16:14 - 03 Feb 2017    Post subject: Reply with quote
Discs hot to the touch?
This really could be as simple as the lever as others have said, if it's just a couple of mm out then it will be applying small but constant pressure causing everything to heat up and in the end lock up.
The last post was made 9 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 133.13 Kb
