| Riderz |
This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
 Riderz Two Stroke Sniffer
| Monkeywrenche... |
 Monkeywrenche... Nearly there...
| Riderz |
| andyscooter |
 andyscooter World Chat Champion
| trevor saxe-coburg-gotha |
 trevor saxe-coburg-gotha World Chat Champion
| Riderz |
| Beehive Bedlam |
This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
 Beehive Bedlam World Chat Champion
| Bozzy |
 Bozzy Traffic Copper
| Riderz |
 Posted: 13:59 - 03 Feb 2017 Post subject: |
You guys are right! I'll start with this and then I will buy new calipers worst case scenario...
I might even do it up a little  ____________________ |CURRENT RIDE:MK1 GSF600N| PAST BIKES:Varadero 125/RS125 x2./XT400/KLR650/CBR 500R/. A2 LICENSE SUCKS |
| Kaya75 |
 Kaya75 Trackday Trickster
 Posted: 14:03 - 03 Feb 2017 Post subject: |
don't buy new lever - your switch just need pushing back a half millimetre.
replace your old rubber lines too -
read my last reply to your which bike thread
edit: if you got hand guards on it these can push against lever and cause heating issues above
Also I they are floating callipers - so a quick polish of the slider pins can resolve sticking.
if got cash and keeping consider braided lines - reverse bleed with baking syringe and tubing on nibble - bleeding down from cylinders is near impossible  ____________________ ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2.
| Evil Hans |
 Evil Hans World Chat Champion
 Posted: 14:05 - 03 Feb 2017 Post subject: |
If only there was a 'workshop' forum where you could ask questions like this  ____________________ Triumph Sprint ST 1050. And it's Red. |
| Riderz |
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:42 - 03 Feb 2017 Post subject: |
| trevor saxe-coburg-gotha wrote: | | Riderz wrote: | anodised gold. |
Blue is best.
Brakes are really very simple. Lever pushes a plunger, plunger pushes fluid, fluid pushes pistons. I'd far rather work on my own than trust them to anyone else, choppa engineea or not.
I can think of four possibilities, which I'd check in this order:
1) Your caliper seals or bleed nipple are pissing fluid. This will be obvious because your caliper will be covered in fluid and you are dead.
2) Your lever is sticking. It may simply be bolted on too tightly by the last ape to work on it, or the profile is just not suitable for your caliper.
3) Your M/C piston seals are shot and fluid is escaping past them. When you say your M/C was replaced, do you actually mean the whole assembly, or just the piston and seals? It's possible that the new seals were pre-perished from storage, or just junk, and tore up as soon as the piston went in.
4) Your pistons are sticking, although even at that, there should be some return pressure on the lever. ____________________ Biking is 1/20th as dangerous as horse riding.
| Kaya75 |
 Posted: 14:47 - 03 Feb 2017 Post subject: |
cool - but the switch is fine, its the placement of the switch and the pushrod, seriously I had a switch on order, when my mate turned up, grabbed a screw driver and pushed the switch back a tad, sorted.
You should be able to hear the switch click on and off when you pull the lever and release, push the lever out so brake light id off, pull lever and release if there is no click when you release the lever, the switch is too far forward (not the push rod - that I presumed was the switch)
There is about 1.5mm of travel on my lever before it hits the switch "click". The thing is the lever is sloppy so doesn't flick out. I'm not saying replace the switch just adjust it back a little by turning it on the pivot - it's only a little plastic push switch that sits behind the push rod- its the push rod that you can see from the top of the bars, have a look underneath the bars. You should see the lever, then the pushrod that engages the little black plastic push switch.
If the pushrod spring is slightly tired you could replace the levers and even the switch and it won't make a difference as the rod won't disengage the switch..
I hate this about the bandit - its dangerous has the brake light stays on so effectively cars behind me don't know I'm braking has I generally ride with lights on regardless day/night. I check the switch weekly and adjust switch if needed.
anyway I'll stop banging on about it now
nice one for deciding to keep the bandit!
some links to issues I had:
https://www.bikechatforums.com/viewtopic.php?t=310475&highlight=
https://www.bikechatforums.com/viewtopic.php?t=311113&highlight=
Also Delboy's Garage on youtube - Delboy has some good video's working on bandits.
this is a pic of fucked nylon brake lines - (pads and calipers are simple the real engineering is in the lines - it should be a nice smooth hole - here they are knackered - will be cause of most brakes sticking)
https://www.amphicar.net/minnow/tech/Brake_plug1.jpg ____________________ ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2.
| Holdawayt |
 Holdawayt Trackday Trickster
| Riderz |
| Riderz |
| Kaya75 |
 Posted: 15:19 - 03 Feb 2017 Post subject: |
mad, are they actually 100% on, like locking up instantly? it can take a while for the pads to bed in, which can make them behave a bit erratic for the first 50+ miles.
I hate to say this, but 200+ quid is a lot of dollar for a rebuild - you could get a recon set for about 120..
The only thing I can think of is lines or the slider pins on the front callipers - but if the pins where not sliding, the disc should be getting warm - sounds like lines not flowing back, which would give you the effect of pumping the levers, meaning you would only have progressive increase with no decrease... stupid bikes!
good luck anyhows  ____________________ ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2.
| Holdawayt |
| Riderz |
| tom_e |
 tom_e Brolly Dolly
| Riderz |
| Evil Hans |
| Riderz |
| tom_e |
 tom_e Brolly Dolly
The last post was made 9 years, 230 days ago. Instead of replying here, would creating a new thread be more useful? |
