Help with relays and air horn
map
Mr Calendar
PostPosted: 14:22 - 02 Mar 2005    Post subject: Help with relays and air horn Reply with quote
Hi,
I think this may have been covered before but can't seem to find the right thread via a search. If anyone does know it from before just point me to the thread.
Anyhow, thinking of getting an air horn. A Stobel Nautilus, because it's small and has everything in one unit.
Mounting will not be a problem, however, I want to keep my original horn as well.
So I'm wondering what the circuit layout would be including the original as the air horn uses a relay.
FYI I don't like auto electrics but I'm perservering with my phobia and relays confuse me at times Mad.
Thanks Thumbs Up
Git
PostPosted: 16:59 - 02 Mar 2005    Post subject: Reply with quote
To get both the horns to make a noise when the horn button is pressed this should do it.
The dotted lines are the wires you will have to put in.
Would be a good idea to find out how many amps the air horns need to size up what cable is needed and to make sure the relay is man enough for the job.
The teminal numbers are pretty much standard on most auto relays but just make sure...
map
Mr Calendar
PostPosted: 17:29 - 02 Mar 2005    Post subject: Reply with quote
Thanks for the info. Should be able to get that wired up using the original connectors for the horn so avoid splicing too many cables.
FYI I wanted to keep the original horn fitted for two reasons:
Arrow In case any question over it being legal for MOT
Arrow In case any delay from the air horn the original cuts in first
Thanks again Thumbs Up
mr.z
PostPosted: 19:22 - 02 Mar 2005    Post subject: Reply with quote
After investigateing for myself i found that "apparently" theres no problem with the horn (should declare it on the insureance though) provided its no too quiet, can be as loud as you like (within reason).
Go to a scrap yard and get some relays from there, they are £2 for 20odd, instead of £5 each!
SOLDER ALL the conncetors and use the propper stuff, made the mistake of shoddy wireing (only got away with it because of the liberal electrical tapeing) defenately use the right ampage wireing too, dont forget the fuses! Razz
Scotch bolks, while very handy, will go rotten, and be the source of much grief somewhere allong the line... save the pain and use propper sleaved, crimped and soldered spades Thumbs Up
Hmmm need to fit mine again Twisted Evil
The last post was made 21 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 42.83 Kb
