Zzr600 starting problems
Tonyg1987
PostPosted: 20:14 - 18 Feb 2017    Post subject: Zzr600 starting problems Reply with quote
Hey guys, I'm new here so I'm not 100% sure if I've posted this in the right section. my bike is a zzr600 2001 model (y reg). Earlier on this afternoon, I attempted to start it for the first time in 2 weeks. I put the key in the ignition and turned it, dashboard lit up fine. I pressed the start button for a second or two and the engine just turned over but would not start, and when I released the button, for some reason the engine kept trying to turn over and this continued even after pressing the kill switch(red button) and removing the key from the ignition. Eventually after about 1 minute the battery died. I managed to borrow a battery charger from a neighbor and as soon as it was hook up the bike started trying to turn over on it's own again...while the key was in my pocket! The only way to stop it was to disconnect the wires from the battery. Now the battery is on charge but I have absolutely no idea what's wrong with the bike so I was hoping someone here could help me as it would be much appreciated. I'm a lost soul when it comes to mechanics but I will get my dad to have a look if someone could give me an idea on what may be causing it.
Thanks in advance.
jaffa90
PostPosted: 23:51 - 18 Feb 2017    Post subject: Reply with quote
The starter relay switch / contacts are stuck / welded in the ON position.
This can be caused by wear and tear and also having a low state of a battery when starting. I suggest a new switch and checking the battery voltage to be 12.8v the morning after in warm weather and 12.6v in cold weather. It`s all about Amps really but voltage checks will do.
Robby
Dirty Old Man
PostPosted: 00:14 - 19 Feb 2017    Post subject: Reply with quote
Starter relay. It will be near the battery, and have two thick cables going into it and a multi-plug with two or three thin wires. Replace it.
Tonyg1987
PostPosted: 00:29 - 19 Feb 2017    Post subject: Reply with quote
Thanks very much for the swift replies, relay switch seems to be fairly inexpensive. I was worried that it was gonna cost me an arm and a leg to fix the problem, but it seems I can relax a little now. It probably doesn't help that the bike has only been getting started once every 2 weeks, I will make sure the battery is fully charged before attempting to start it next time.
jaffa90
PostPosted: 00:44 - 19 Feb 2017    Post subject: Reply with quote
Also check the battery earth connection to the frame and the engine earth strap to the frame if fitted.
Tonyg1987
PostPosted: 22:53 - 19 Feb 2017    Post subject: Reply with quote
https://m.ebay.co.uk/itm/381053894966?_mwBanner=1
This is the correct part rights guys?
Robby
Dirty Old Man
PostPosted: 23:39 - 19 Feb 2017    Post subject: Reply with quote
That's the bit.
Tonyg1987
PostPosted: 11:06 - 23 Feb 2017    Post subject: Reply with quote
Just a quick update, I replaced the starter relay but now when I connect the battery, I get nothing. No neutral lights or lights around the clock, and the bike won't turn over now. Also I've checked the fuse box under the seat and they seem to be fine
davethekwak
PostPosted: 11:15 - 23 Feb 2017    Post subject: Reply with quote
Stupid question alert. You have recharged the battery after it going flat?
ZX6R G2 (1999) & ZX6R F2 (1996). I like ZX6!
Tonyg1987
PostPosted: 11:26 - 23 Feb 2017    Post subject: Reply with quote
Stupid alert is right!!! But it wasn't the battery. Took the starter relay back of and because it's not an official Kawasaki item, the fit was slightly different and the rubber from one of the wires was getting in the way of the connection haha Embarassed
DrSnoosnoo
PostPosted: 11:34 - 23 Feb 2017    Post subject: Reply with quote
Check the fuses under your seat, too.
The last post was made 9 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.81 - MySQL Queries: 13 - Page Size: 66.92 Kb
