| Arcane1729 |
 Arcane1729 Banned
 Posted: 21:10 - 21 Feb 2017 Post subject: What the hell is a bolt extractor? |
I've seen many of these online and am searching for this coveted tool because of this article:
https://www.doityourself.com/stry/9-steps-to-removing-a-motorcycle-ignition-switch
Yes I've decided to take the plunge and stop being scared of ruining it. ____________________ Kymco Super 8 (125) Honda CBR 125
A2 2017
Teflon Mike: "A man can dream... but most of them are probably best not voiced.... Folk will likely think you are just mad, sad or simply a pervert." |
| Fisty |
 Fisty Super Spammer
| Baggyman |
 Baggyman Crazy Courier
| ThatDippyTwat |
 Posted: 21:40 - 21 Feb 2017 Post subject: |
Left handed drill bit, gotta get the bolts hot to soften the threadlock.
I have also cut them with a grinder when I lost my keys at work. 1mm disc in the gap cut the bolts and allowed me to release the steering lock. Fitted it back with packing washers. ____________________ a.k.a 'Geri'
 Posted: 22:08 - 21 Feb 2017 Post subject: |
For ignition switches I've always just drilled the heads off the bolts. There's enough of a stub left once you lift the lock off to either simply unscrew with mole grips or file a couple of flats on and undo with a spanner ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Billy Balthorpe |
 Billy Balthorpe Trackday Trickster
| Arcane1729 |
 Arcane1729 Banned
 Posted: 23:33 - 21 Feb 2017 Post subject: |
Will this all work if the steering lock is on?
Mole grips = adjustable pliers? if so check. I defo have adjustable pliers like in the pic below
Combi drill check. Drill bits not check
Angle grinder however check.
Can I angle grind the head of the bolts? or is it too dangerous for the other parts around the area on the bike in case I jolt and cut them instead like a wire...
I havent actually had the balls to attempt this yet but are these threaded bolts deep in the bike can I reach them from the handlebars or must I get underneath the bike to access them?
Edit: oh you all mean the bolts in step 6 of the article: "Set ignition switch facing down and locate the two bolts that hold it to the underside of the triple tree." ____________________ Kymco Super 8 (125) Honda CBR 125
A2 2017
| Billy Balthorpe |
| weasley |
 weasley World Chat Champion
 Posted: 23:50 - 21 Feb 2017 Post subject: |
| Freddyfruitba... |
| redeem ouzzer |
| Jim Mc |
 Jim Mc Nearly there...
| pompousporcup... |
 pompousporcup... World Chat Champion
| skatefreak |
 Posted: 09:54 - 22 Feb 2017 Post subject: |
I had to switch the ignition on my NSR a few years back.
Ground the head off the bolt and shaft came out with fingers alone!
Once the tension was released from the threads the remainder of the bolt was loose as anything
Not everything turns into a sh*tfest ! |
 Posted: 10:17 - 22 Feb 2017 Post subject: |
| sharpe2002 wrote: | surely, i may be wrong, but, if you drill out the middle of a seized bolt and then proceed to effectively wedge the 'extractor' down the middle, all it is doing is pushing the thread of the seized bolt against the threaded hole it sits in, thereby making it even more difficult to release? |
In fairness, if you've managed to drill straight down the middle of a bolt, you're as well to keep going with sequentially larger drills until you can either break the remnants of the bolt into the middle or hit the tapping size and chase the threads out. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Arcane1729 |
 Arcane1729 Banned
| grr666 |
 grr666 Super Spammer
| Arcane1729 |
 Arcane1729 Banned
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:09 - 22 Feb 2017 Post subject: |
Bolt extractors are something that you'd find in a Workshop, which is where I hope you'll - eventually - learn to post these threads. ____________________ Biking is 1/20th as dangerous as horse riding.
| Arcane1729 |
 Arcane1729 Banned
| grr666 |
 Posted: 12:21 - 22 Feb 2017 Post subject: |
You have my every best wish of success.  ____________________ Currently enjoying products from Ford, Mazda and Yamaha
| arry |
 arry Super Spammer
| Arcane1729 |
 Arcane1729 Banned
| arry |
 arry Super Spammer
The last post was made 9 years, 239 days ago. Instead of replying here, would creating a new thread be more useful? |
