| Ayup_Mi-Duck |
 Ayup_Mi-Duck Renault 5 Driver
 Posted: 10:31 - 25 Jan 2017 Post subject: YBR 125 gear issue: stuck in high gear? |
Hi there
I hope you can help as I have just purchased my first bike.
here are the symptoms.
Clutch does not seem to go out far enough. If I unhook the cable from its retainer on the engine case, and roll along whilst hitting the start switch, it will run a if it is in gear. I cant crash into any other gears.
when the cable is where it should be, I can move the shifter in the downwards direction into a gear but it does not return to the middle position. it stays depressed.
The chain tension is v slack for some reason, the previous owner said he liked loose chain? :\
other than that, it starts and runs lovely! really lovely.
I was thinking, could it be the jobby on the other end of the shift levers shaft has broken so its not moving the selectors? or is it more than likely the clutch is buggered/ gear box is a brick?
Please help.
Dan |
| stinkwheel |
 Posted: 11:05 - 25 Jan 2017 Post subject: |
I'd be having a look at the front sprocket first. See what's going on under there. Nobody "likes a loose chain".
Having a look at the clutch and clutch mechanism isn't a huge job and would be my next step. You either need to lean the bike way over to the left or drain the oil and remove the RHS engine cover. You will need a new gasket for it.
Probably best to change the oil once you've found the problem anyway given the apparent attitude to routine maintainance.
Your symptoms could fit with a few things from something very simple to somethign catastrophic. My guess (it's a total guess) is that the clutch basket retaining nut has come loose and the clutch is flapping about.
In B4 welded on front sprocket... ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jaffa90 |
 jaffa90 World Chat Champion
| Ayup_Mi-Duck |
| Ayup_Mi-Duck |
| Fizzoid |
 Fizzoid World Chat Champion
| jaffa90 |
| stinkwheel |
| Ayup_Mi-Duck |
| Ayup_Mi-Duck |
 Posted: 13:27 - 25 Jan 2017 Post subject: Checking oil |
Erm, just one more thing *in Colombo voice*
It says in the service manual
"Ensure bike is on a level surface, place on a suiltable stand and make sure that the vehicle is upright."
Does that mean on the side stand or on the centre stand? im confused.
If its on the side stand, the oil level is perfect. if it means the centre stand, the reading says that the engine is swimming in oil.
Bloody hell, welcome to motorcycles  |
| Polarbear |
 Polarbear Super Spammer
 Posted: 14:39 - 25 Jan 2017 Post subject: Re: Checking oil |
| MahoosiveDan wrote: | Erm, just one more thing *in Colombo voice*
All oil levels should be done with the bike level. It isn't level on the side stand is it. You have too much oil in it now.
It's worded like that in case you have a paddock. Abba or similar stand as some bike don't come with a centre stand. ____________________ Triumph Trophy Launch Edition |
| Ayup_Mi-Duck |
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
| stinkwheel |
| ThatDippyTwat |
 Posted: 22:18 - 25 Jan 2017 Post subject: |
| stinkwheel wrote: | | ThatDippyTwat wrote: | Too much oil will do this on a YBR. Mine came with a "sticky shift" in the same manner. changed the oil as a matter of course on a bike I don't know, and shift is not an issue. It may not be your only problem, but it'll only cost you 1L of oil to find out, before you start opening cases etc. |
I'm not saying it isn't the case but it's hard to think of a good mechanical explanation for why this would happen. I'd expect a motorcycle clutch and gearbox to function the same way either completely empty of oil (although it would start wearing very quickly) or totally immersed in oil. |
I can't tell you why, only that it is. I over-filled it last time (busy gassing), and it was a pig to change 1st-2nd, neutral almost every fucking time. Proper oil level? No issues, and no other change other than dropping about 100-200ml excess oil out. Same issues as when I initially had it, but not as severe, but the initial ffill must have been more like 1.5L. Your guess is as good as mine, I've not been inside this gearbox, so I can't comment with any authority. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
| Ayup_Mi-Duck |
| Ayup_Mi-Duck |
| Ayup_Mi-Duck |
| stinkwheel |
| Ayup_Mi-Duck |
| Ayup_Mi-Duck |
| chris-red |
| Ayup_Mi-Duck |
| chris-red |
| chris-red |
 Posted: 15:07 - 23 Feb 2017 Post subject: |
https://www.fowlersparts.co.uk/parts/5452211/ybr125ed-2012-51d2-europe-black-metallic-x/shift-cam-fork
Looking at the diagram it has a dowel to keep the Star thing from spinning does yours have it? ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
The last post was made 9 years, 40 days ago. Instead of replying here, would creating a new thread be more useful? |
