| mkjackary |
 mkjackary Nitrous Nuisance
 Posted: 23:07 - 23 Feb 2017 Post subject: Headlight stopped working, nothing obvious will fix it. |
Driving at 7pm today on the a12 when the main and fullbeam goes out. Pull over, do some diagnostics, sidelight is on the same fuse circuit as the main beam and it still works. Every other light and horn still works besides the full beam, main beam, and fullbeam dash indicator light.
Changed the fuses, nothing new, got my mum to drive up with a new bulb, nothing, tried two different new bulbs and nothing. Checked for obvious cables being unplugged or anything, maybe the wind blew one loose, but narp. What else could it be? I'm going to take off the tank and check every cable I can, try and get a multimeter to check if there is power going to the plug or whatever, anything else I should try?
Cheers |
| mkjackary |
| Nobby the Bastard |
| mkjackary |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
| Nobby the Bastard |
| Hong Kong Phooey |
 Posted: 23:56 - 23 Feb 2017 Post subject: |
I think misunderstandings are in evidence here.
In other words, if the earth is already broken, but it's common to both main and dipped beam, then how can it be faulty?
Multimeter is your friend, multimeter is good mmmkay. ____________________
'81 CG125, '97 FZS600 : '99 CBR600F4, '09 KTM RC8 |
| mkjackary |
 Posted: 00:22 - 24 Feb 2017 Post subject: |
Apologies, long day, been outside in the cold for about 3 and a half hours trying to fix it and waiting for a ride so brain isn't firing on all cylinders.
I have bought a multimeter that should arrive tommorow, and hopefully I can get it fixed for my 7pm-3am shift on Saturday.  |
| Nobby the Bastard |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 00:57 - 25 Feb 2017 Post subject: |
| mkjackary |
 Posted: 07:53 - 25 Feb 2017 Post subject: |
Take the switch clusters off and fix them properly. When you're in there look to see if the tape you have put round the bars has bunched up and messed with the wires or switch. ____________________ a.k.a 'Geri'
| doggone |
 doggone World Chat Champion
| mkjackary |
 Posted: 17:03 - 25 Feb 2017 Post subject: |
So, multimeter is here. Took hand control off, no loose cables or anything obvious, so my Eureka moment didn't amount to anything, I tried taking it apart further after this photo was taken but it just doesn't want to, I would have to take the switches off from underneath and I don't think the issue is here. https://i.imgpile.com/i/vdc9o.jpg
Took the headlight off and took the bulb out, the bulb is fine, as I said before I have tried an old bulb that I know works and a brand new bulb in this one's place, so I know it isn't the bulb. Tested continuity of the socket, the left and right ones are connected, so they must be the positive for the low and high beams, meaning the top is earth. But wierdly I tested the continuity of the earth and the shiny bit of the forks, and nothong, but there is continuity between the shiny bit of the forks and the two live cables, which isn't good obviously.
Is there any useful info anyone can gather from this? It just confused me more.
https://i6.imgpile.com/i/vdiaj.jpg |
| Nobby the Bastard |
 Posted: 17:13 - 25 Feb 2017 Post subject: |
That looks like the earth is getting too hot and melting the plastic. This is probably why the light isn't working (plastic melting, causing the metal connectors to seperate and not make contact.)
Have you put in a higher wattage bulb than standard? ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Triumph Sprint ST 1050 |
| Copycat73 |
 Copycat73 World Chat Champion
| Nobby the Bastard |
| bamt |
 bamt World Chat Champion
| Copycat73 |
| mkjackary |
 Posted: 18:17 - 25 Feb 2017 Post subject: |
| Nobby the Bastard wrote: |
Have you put in a higher wattage bulb than standard? |
No, just standard h4 bulb. Just chucked a lead into the right hand socket in the photo above, black cable, and then put the bulb in tried connecting it to an earth somewhere but nothing. Sorry when I posted the response an hour or so ago I hadn't found an insulated cable to try it with. |
| mkjackary |
 Posted: 18:22 - 25 Feb 2017 Post subject: |
| bamt wrote: | The way you are holding that socket, ground should be the right hand side connection, low beam on the top and high beam on the left.
1
Put the meter onto volts, turn on the bike so the lights should be on, and measure between the top pin and the ground pin. If you've got 12V there then either you have two duff bulbs or there is a mechanical problem with the pins connecting to the bulb.
2
If not, put your black lead to ground (try a good, unpainted part of the bike - maybe the bolt holding your horn in, or the engine) and red lead to the top connection. You should get 12v there.
If not (and you are sure you are using the meter correctly and the ground connection to the meter was good) then your problem is somewhere on the +ve side wiring. If you do, then the problem is an issue with the ground wire. |
So I tried 1 and got 0.2 volts, got the same result ok your second point as well.
So that means it is on the positive side, so I guess from here I work backwards untill I get a reading of 12v and there is my problem. |
| Nobby the Bastard |
| bamt |
| Hawkeye1250FA |
 Hawkeye1250FA World Chat Champion
| iooi |
 iooi Super Spammer
The last post was made 9 years, 51 days ago. Instead of replying here, would creating a new thread be more useful? |
