| onlyJaz |
 onlyJaz Scooby Slapper
| mudcow007 |
 mudcow007 World Chat Champion
 Posted: 15:59 - 23 Feb 2017 Post subject: |
fit them properly using a relay
Guide
mine went over the grips. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:26 - 23 Feb 2017 Post subject: |
Linkfail. Actual relay wiring guide.
How to physically replace the grips will depend on the grips and the bike.
I'ma assume:
https://i.imgur.com/tla602c.jpg?1
The left grip should just slide off. By "slide", I mean that you can get it off by main force, twisting it to get it started, squirting WD-40 under it, levering a screwdriver under it, praying to Kek, or whatever works. Then replace with the heated grip.
The right, you'll have to open up RHS switchgear. You'll find that the RHS grip goes into it, and then the throttle cable hooks onto that. Detach the cable, remove the grip, and replace with the piece on the far right. Hook the cable back on, check everything works OK, then push the rest of the grip over it - it's in two pieces so that you can orient it so that the wiring isn't strained or fouling anything when the throttle is wide open or closed.
It'll be straightforward once you get stuck in. ____________________ Biking is 1/20th as dangerous as horse riding.
| mudcow007 |
| Ayup_Mi-Duck |
 Ayup_Mi-Duck Renault 5 Driver
| Baggyman |
 Baggyman Crazy Courier
| Ayup_Mi-Duck |
The last post was made 9 years, 33 days ago. Instead of replying here, would creating a new thread be more useful? |
