Looking for a l-o-n-g disc alarm reminder cable
Freddyfruitba...
PostPosted: 19:21 - 25 Feb 2017    Post subject: Looking for a l-o-n-g disc alarm reminder cable Reply with quote
I use a brake disc alarm on my bike, and as most other folk who use one can attest, it's a good idea to use of those hi-viz reminder cables between lock and handlebar. This sort of thing:
https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcT_mSVeJoBahaI8Z3vDdokAQhmeVbqcymmUWAuaKSjyopLCb7TYPg
I bought one, but it was only about a metre long and is no use for me at all, because I always choose to use the lock on the back wheel (why doesn't everyone - a heavy bike is way harder to manhandle into a van with a locked back wheel than a locked front wheel). So I need a cable probably 2-3m long when stretched; I can't find anything longer than 1.2m. Anybody found one? Or know of a source of that coiled cable, maybe used for a different purpose? I haven't come to grief yet, but suspect I'm on borrowed time Shocked
Yes I could buy 2 or 3 and tie them together or something, but I like the original because it's compact and neat, and would be far less bulky (eg for fitting in a jacket pocket or under the seat) than using several separate items, or a length of uncoiled cable.
ADSrox0r
PostPosted: 20:15 - 25 Feb 2017    Post subject: Reply with quote
It's only a reminder so why not use some other form of reminder, like a laggy band round your brake/throttle. That way if you do forget, the band will be squeezing on your front brake to some degree and mean you have less chance of doing the derp.
PostPosted: 20:18 - 25 Feb 2017    Post subject: Reply with quote
If you have as disc lock alarm surely it goes off if you forget to remove it and get on your bike. If it doesn't it's not doing it's job!
Triumph Trophy Launch Edition
bamt
PostPosted: 21:38 - 25 Feb 2017    Post subject: Reply with quote
When I was using a disk lock, I used a short piece of rubber tubing that fitted tightly onto the blade of the disk lock key.
When I parked up, I had to take the tubing off the lock key to use it, so I put it onto my ignition key and left it there. When I came back to the bike, I couldn't put the ignition key in without moving that bit of rubber back to the disk lock key, so I remembered to undo the disk lock.
Hong Kong Phooey
PostPosted: 21:40 - 25 Feb 2017    Post subject: Reply with quote
Buy two and loop together.
Or as stated above use something else, like a crusty cum-sock over the mirror.
andyscooter
PostPosted: 22:05 - 25 Feb 2017    Post subject: Reply with quote
Buy one wrap it round throttle and brake and a small padlock
Keep key with bike key
BrownTrousers
PostPosted: 06:35 - 26 Feb 2017    Post subject: Reply with quote
Think I would just loop two normal ones together, but such things do exist
Bikers make great organ donors - add your name to the register
Ducati Multistrada 950 | Triumph Tiger 800 XR | Honda CBR500R | Yamaha YBR 125 Custom
TaffyTDM
PostPosted: 10:23 - 26 Feb 2017    Post subject: Reply with quote
I use an alarmed disc lock. I don't have a reminder cable - serious question, I only have to look at the thing for it to set off and wake the street up at 5am. Surely if you get on the machine with it still on it will start wailing at you?
Edit. Polarbear already got there
Matt B
PostPosted: 11:15 - 26 Feb 2017    Post subject: Reply with quote
https://thumbs3.picclick.com/d/l400/pict/282294495066_/Disc-lock-reminder-Metal-Tip-by-Lock-Mate.jpg
https://www.lockmatekey.com/ Thumbs Up
Simple, effective.
grr666
PostPosted: 11:34 - 26 Feb 2017    Post subject: Reply with quote
I just loop mine around each hand grip and straight across the bars. It doesn't need to be attached to the lock to remind you.
andyscooter
PostPosted: 11:44 - 26 Feb 2017    Post subject: Reply with quote
that's why I was putting one round the handle bar with a small padlock to maybe stop it being nicked
Freddyfruitba...
PostPosted: 13:40 - 26 Feb 2017    Post subject: Reply with quote
Thanks a lot for the suggestions.
Oh I like it - I reckon that's the winner! (now I just need to find a suitable bit of tubing that will fit both keys Laughing )
In response to some of the other ideas:
For me and my-ever decreasing number of brain cells, a reminder has to be something I won't forget to 'set' when I lock up the bike, which is why I liked the idea of having a hi-viz reminder cable permanently attached to the lock; if it's dangling off the wheel when I've locked the bike I wouldn't forget to use it. And interesting that there are long such cables around; however I still can't find one outside for sale the US of A, with prohibitive postage.
And although I haven't yet tried to ride off with the lock in place, I'm pretty sure it would be possible to do so before the alarm sounded, especially as it has a short lag time.
Poecilotheria
PostPosted: 13:56 - 26 Feb 2017    Post subject: Reply with quote
Get a long loop end galvanised steel cable, wrap yellow tape around it. I picked up a 4mm 3ft long about £9. Good thing is its a little added security granted not much bit can loop it anywhere, loop through the disc lock alarm versions and even if its dodgy like my oxford screamer that goes off when you dont want it to but not if you do... but anyone trying to pull bars or move it will pull the disc lock and set the alarm off anyway.
Alot of people park their bike in gear so locks the rear wheel.
Need more bikes!
Arcane1729 This post is not being displayed because the poster is banned. Unhide this post / all posts.
Rogue_Shadow
PostPosted: 14:43 - 26 Feb 2017    Post subject: Reply with quote
Simple, effective.
+1
I was very grateful that the extra width also stopped my keys falling down a storm drain in Italy.
Matt B
PostPosted: 18:30 - 26 Feb 2017    Post subject: Reply with quote
First time I saw this type of reminder was on your keys during that trip Thumbs Up
The last post was made 9 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 93.08 Kb
