Bloody rust!!!
Poecilotheria
PostPosted: 23:40 - 01 Mar 2017    Post subject: Bloody rust!!! Reply with quote
Just cant see how its happening, bike is always covered and cleaned. Never been let to be poured on in rain without its cover (oxford good quality one) but my clutch and front brake adjusters are now showing rust, my front disc was literally stuck to pads. My discs are cleaned weekly, its driving me crazy.
Need more bikes!
Itchy
PostPosted: 23:57 - 01 Mar 2017    Post subject: Reply with quote
They're made from unprotected metal.
The brake discs in particular are exposed to the elements as the friction rubs off any coating to protect them from the elements. Add in heat from friction you get surface rust. It even happens on cars brake discs.
Poecilotheria
PostPosted: 00:05 - 02 Mar 2017    Post subject: Reply with quote
What can I do to protect my non disc rusted parts? something good
Need more bikes!
Alex A
PostPosted: 00:10 - 02 Mar 2017    Post subject: Reply with quote
A cover won't prevent rust. If it's outside, it'll be exposed to moisture one way or another. Steel parts will be particularly vulnerable.
Storage in a garage usually will prevent rust, especially if it's heated.
Itchy
PostPosted: 00:14 - 02 Mar 2017    Post subject: Reply with quote
ACF50 or FS365.
FS365 worked well for me as I reapplied it after every ride. I built up a layer of protective crud on my bikes. You'd be able to rub off a layer of crud come summer though summer would also get applications of it.
Though YMMV.
https://f2mcltd.blogspot.co.uk/2012/01/winter-salt-protection-acf50-fs365-or.html
Or you go the cheapo route and simply slather your bike in grease (but not the brake discs). It looks awful. It rubs off onto your clothing if you should brush against it but it works.
Ross a bike shop owner I once knew used a thick layer of grease on his XJ900. He's always leave grease stains on my chairs though from the rub off. But when he degreased it later his bike was nice and new under the crud.
Since it's just the adjusters I'd go grease.
ackack
The adjusters I would replace with alloy ones and any bolts that are starting to go I would look for your nearest plating firm, and ask them to Cadmium plate them. Don't let them fob you off with Zinc or Zinc Nickel.
"fli hi mi angle"
Poecilotheria
PostPosted: 00:25 - 02 Mar 2017    Post subject: Reply with quote
That is super helpful, thanks. It seems good to have acf 50 looking at the control and test pictures.
I just got a pair of nissin off a scrap bike, I have looked for plate firms and there is one not far from me so will get them done before fitting I think.
Need more bikes!
PostPosted: 09:31 - 02 Mar 2017    Post subject: Reply with quote
I rode a £800 Chinese 125 through three Scotch winters and it was still pristine when I sold it on. It was ACF-50'd when fresh out of the crate, and re-applied each Autumn. Correlation doesn't imply causation, but I'm a believer.
That said:
That. Or vaseline, or any other gloop that you have handy.
Heretical as it is, I apply a thin covering of grease to my (O and X ring) chains rather than oiling them. Oil shouldn't penetrate past the rings anyway, and the grease is there to prevent surface corrosion without flinging off.
Chain lube thread get.
Oldie
PostPosted: 10:07 - 02 Mar 2017    Post subject: Reply with quote
There's a German product which I bought a while back (but rarely use) to stop discs from rusting. They allege that it has no effect on braking performance. Apparently used by motor dealers who display their vehicles outside.
AHB Disc Protector
https://www.directsupplyukltd.co.uk/brake-disc-protect/p368
Loui5D
PostPosted: 10:26 - 02 Mar 2017    Post subject: Reply with quote
The local allyearbiker guy has said that they offer another treatment other than ACF-50 called XCP one.
The promotional pack they sent to him made it look really good (as you'd imagine)
Tbh if it lived up to half of what it says it's almost as good as acf50
PostPosted: 11:27 - 02 Mar 2017    Post subject: Reply with quote
Does it?
Does it?
BCF requires that you soak your discs then hammer it towards a ditch. Whistle
Be safe, wear your Rainpal.
steve__b
PostPosted: 11:33 - 02 Mar 2017    Post subject: Reply with quote
I spray a bit of ACF50 on to a soft cloth and wipe it on metal parts...exhaust down pipes and other places. Then I leave it for a day or two, when I start bike up to ride it the ACF50 seems to evaporate off as it smokes off looking as if bike is about to catch fire. What is best way to apply ACF50 ??
Riding 2001 BMW F650 Funduro. 1st bike Yamaha YBR 125. CBT Aug 2014. Theory Oct 2014. Mod 1 Passed Sept 2015. Mod 2 passed Dec 2015. Wish I'd started biking 20+ years ago...luv it Smile
evilzed
PostPosted: 11:50 - 02 Mar 2017    Post subject: Reply with quote
I've ordered some of this stuff to compare (XCP rust blocker). I've had no trouble with ACF other than is being tricky to apply thinly though.
I did find this though.... https://f2mcltd.blogspot.co.uk/2016/12/xcp-rust-blocker-v-acf50-testing-and.html although they don't show the product I'm not too sure..... The XCP comparison video looks promising but it's made by the company that makes it so....
I've had decent results with ACF50 and FS365
thx1138
PostPosted: 11:56 - 02 Mar 2017    Post subject: Reply with quote
My Honda CBF125 had rust issues, to be fair, not as bad as my BMW Sertao.
My Honda I knew would need looking after from the threads on here, and unusually for me I cleaned it meticiu I can't spell that, carefully.
Yet I noticed rust streaks just inside the little fairing on both sides from a fastener.
Sertao ditto from the sides of the oil cooler but worse after being left out in the rain, once.
PostPosted: 12:24 - 02 Mar 2017    Post subject: Reply with quote
Sad times, but common on both bikes. I'd have thought that all the oil leaking from the cooler would have kept the rust at bay though. Whistle
Mudshark
PostPosted: 12:55 - 02 Mar 2017    Post subject: Reply with quote
cover your wheels and spray it everywhere, then use a small soft paintbrush to do the wheels. (I would guess)
woo
PostPosted: 13:26 - 02 Mar 2017    Post subject: Reply with quote
bike chain lube helps if you cant be arsed with ACF 50
I use chain lube on most exposed parts and reapply when needed hence why my msx is totally rust free
Elen sila lummen omentielvo!
Loui5D
Just be careful you don't do this on brand new tyres.
I made that mistake when trying to take the lump of the paddock stand, it threw me over with it.
Oldie
PostPosted: 21:01 - 02 Mar 2017    Post subject: Reply with quote
Rogerborg wrote:
Does it?
Does it?
Yes
Can't remember
Anal rip is a scam
tadge
PostPosted: 21:25 - 02 Mar 2017    Post subject: Rust Reply with quote
Cheapest and one of the best options Silicon spray from the range for bike and kit......£6 ish a big can.
tadge
PostPosted: 21:26 - 02 Mar 2017    Post subject: Rust Reply with quote
natefz6
PostPosted: 21:48 - 02 Mar 2017    Post subject: Reply with quote
Maybe I ride to fast or too many miles but one application of ACF 50 does not last me a winter, tbh at the moment I am happy if it lasts two weeks.
Seems like I am always fecking cleaning the thing, despite liberal coatings of ACF I still have pits appearing on fork, wing mirrors and down by the tank hinge. It does take some abuse this time of year with all the salt.
I see daffodils and blossom so spring is here so the gritters can go back to wence they came and I can get back to my monthly cleaning schedule.
"no I didn't steal it that's just the way I ride"
PostPosted: 22:44 - 02 Mar 2017    Post subject: Reply with quote
Apply ACF-50.
Don't clean.
Wait for spring.
Clean.
steve__b
PostPosted: 01:07 - 03 Mar 2017    Post subject: Reply with quote
Rogerborg wrote:
Apply ACF-50.
Don't clean.
Wait for spring.
Clean.
I apply
Wait a day
Ride
It evaporates off like smoke when bike gets warm
aardys
PostPosted: 15:27 - 05 Mar 2017    Post subject: Reply with quote
cheap silicone spray is the answer
its not a lube remember , just spray it on anything you dont want to rust including the exhaust , just keep it away from brake disks ,
its easy and cheap
to old to care
The last post was made 9 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 130.38 Kb
