09 BMW R1200R stalling at low RPMs/Idle
rhun
PostPosted: 18:52 - 06 Mar 2017    Post subject: 09 BMW R1200R stalling at low RPMs/Idle Reply with quote
I'm having some issues with my 09 R1200R (21k miles). It usually starts up fine and then the idle sounds a bit 'weak' (the needle will keep jumping up and down at the bottom of the rev counter as if its trying not to stall) and then after a minute or so it will stall. Once it does this it will refuse to idle and I'll have to twist the throttle to get it to start and then hold it open to get it to idle but it's very rough. When I'm riding it has a tendency to stall at low RPM's constantly and it will also run like a dog, the indicated MPG will drop down into the 20's. Sometimes it seems to run fine and idle however I think it's getting worse and much more common for it to stall at low RPMs. Yesterday it started kangaroo hopping like mad however I think that may be down to some shoddy fuel that I filled my tank up with in some tiny obscure petrol station in the highlands (live and learn). I don't know if this is relevent but it seemed to be running fine for 400 miles and then I got caught in a seriously heavy downpour in Glencoe and ever since then this has been happening. If anyone has any good ideas that I can try at home I'd be very appreciative. As due to the age of the bike taking it into BMW is a last resort.
Service history shows a full and comprehensive service 5k mile ago.
Honda CBR600F6
PostPosted: 19:22 - 06 Mar 2017    Post subject: Reply with quote
My knee jerk would be coils / HT leads / plug caps, but since it's starting then spazzing, my head says some sensor, either oxygen sensor in the exhaust or throttle position sensor. I'd hit it with a can of WD40 before trying anything clever.
rhun
PostPosted: 19:59 - 06 Mar 2017    Post subject: Reply with quote
I've uploaded a video here to show the issue I'm having. It idles fine (I think) when it's cold, its when it warms up and I assume the automatic choke makes changes to the fuel mixture where it starts to experience problems. As you see at the end of the video I blip the throttle a bit to show what happens when I'm riding it and then it will be unable to start without throttle. It's clear from the video that the engine isn't running right as you can hear it misfiring or something similar to that. Please let me know if anyone can hear anything obvious that I'm missing. I'm new at all this. (my old 2002 cbr600f never had any issues Sad )
https://www.youtube.com/watch?v=oqWmoOLW5DE
Honda CBR600F6
Oldie
PostPosted: 21:55 - 06 Mar 2017    Post subject: Reply with quote
Erratic rev counter is very often a symptom of a knackered Hall Sensor.
There's plenty of info on the ukgser forum to help you. Most people, including myself, end up buying a second hand unit off ebay but, even then, they're not cheap.
rhun
PostPosted: 00:01 - 07 Mar 2017    Post subject: Reply with quote
There are no hall sensors on the hexhead models. Roger, I've been looking around and other people with very similar symptoms as mine seem to think it's the Coils. Do you think there's a place I can blast some wd40/check its actually them before I go ordering new ones.
Honda CBR600F6
Oldie
PostPosted: 07:24 - 07 Mar 2017    Post subject: Reply with quote
Sounds very much like it's firing on one cyclinder most of the time. After starting from cold do a quick check to see which exhaust pipe is heating quicker to determine if there is a difference.
If you can identify that one cylinder is not firing properly then you can start a proper diagnosis. I haven't worked on hexheads but, yes, a simple idea would be to swap the coils over to test them. However, I'd put in new plugs before I did anything. Also, inspect the wiring below the rubber boot of the connector to the injector on the "faulty side". These hidden wires can split leading to intermittent power to the injector. Or maybe it's the HT lead or plug cap - start the bike and spray WD40 onto them to see if that improves running.
As I said, the ukgser forum will have many similar stories and solutions.
BTTD
PostPosted: 11:18 - 07 Mar 2017    Post subject: Reply with quote
Are the throttle bodies properly balanced? I've had lumpy low revs on out of balance, but not stalling.
rhun
PostPosted: 00:24 - 11 Mar 2017    Post subject: Reply with quote
Hi, both downpipes were hot. Changed all the plugs today hoping that would fix it but if anything it's worse. Also removed every connector I could see around the throttle bodies area to check for moisture and clean them. Only one had a little bit of water in but the problem still remained after. I'm going to test the TPS tomorrow with a multimeter. Any ideas on the awful clapping noise at low revs (as it wants to stall) is all about?
I have a service receipt of the throttle bodies being balanced last year which was only 5k miles ago, according to the service schedule they're a 12k jobbie.
Recorded another video here.
https://www.youtube.com/watch?v=K5IS6SJ6ZYM
Honda CBR600F6
Old Git Racing
PostPosted: 07:53 - 11 Mar 2017    Post subject: Reply with quote
Forget wd40, go get some proper contact cleaner from somewhere like Maplins and take every connector apart and clean them, along with HT leads and plug caps. I'd also dump the fuel and refill with new stuff. Won't be a coincidence it started doing it after the rain/fuel.
OGR.
Oldie
PostPosted: 08:13 - 11 Mar 2017    Post subject: Reply with quote
Mmmmm, thinking that it might be your fuel pump or FPC. Certainly worth investigating further. The R1200R has a tendency to allow water to gather around the fuel filler cap and you may have suffered from water ingress during your Glencoe ride. Many owners fit an Abdeckring (I did) which seals the filler cap and you can get them off ebay.de.
If it's not the pump itself, it's probably the fuel pump controller. The part number for the 1200GS is 16147720776 and I guess that it's the same for the R, but you could check online - https://www.realoem.com/bmw/select.do?kind=M&arch=0
The basic rule for the FPC is Black = good, Silver = bad. Most 1200's had a recall but maybe not yours?
If you're handy, there's a bypass of the FPC which you can do, but we'll leave that for later Very Happy
rhun
PostPosted: 13:04 - 11 Mar 2017    Post subject: Reply with quote
My bike so now with BMW. Hopefully it won't cost me too much. Missing my cbr600 right about now. Rolling Eyes
Honda CBR600F6
PostPosted: 13:36 - 11 Mar 2017    Post subject: Reply with quote
https://i.imgur.com/KJphK.gif
rhun
PostPosted: 14:27 - 11 Mar 2017    Post subject: Reply with quote
I know, I'm expecting a right royal bumming. Sure hoping their diagnostic gizmo picks up the problem.
Honda CBR600F6
PostPosted: 14:49 - 11 Mar 2017    Post subject: Reply with quote
Douglas Park Motorrad, by any chance?
I'll be interested to hear how that turns out.
rhun
PostPosted: 14:59 - 11 Mar 2017    Post subject: Reply with quote
Yeah, they're the nearest to me (still 40+ miles mind you). That sounds ominous... Do tell?
Honda CBR600F6
Oldie
PostPosted: 15:06 - 11 Mar 2017    Post subject: Reply with quote
They're mostly fine. Needed them 3 times - always happy with the result.
PostPosted: 15:39 - 11 Mar 2017    Post subject: Reply with quote
I got my GS from them. The sales experience was outstanding. Pity about the popped fork seal that was gushing oil big style when I got it home. Must have happened on the 3 mile ride after the 150 point inspection, definitely wasn't them wheelying it around the yard after they had my deposit.
Other experiences vary though, I hope it goes well for you. Wink
rhun
PostPosted: 16:04 - 11 Mar 2017    Post subject: Reply with quote
Well it's my first BMW dealership experience so hopefully it'll be a good one. The bike has already dissapointed me enough. Thumbs Down
Ideally I'll have it back within a week or two and report back positive things. Thumbs Up
Honda CBR600F6
rhun
PostPosted: 22:18 - 13 Mar 2017    Post subject: Reply with quote
I received a call today, it is the Throttle Position Sensor as has been mentioned a few times. Quite relieved it isn't a big job.
Honda CBR600F6
PostPosted: 23:17 - 13 Mar 2017    Post subject: Reply with quote
Ah, good news.
Is it a cheap job though? Honestly, I have no idea what dealer costs are like on BMWs.
rhun
PostPosted: 14:14 - 14 Mar 2017    Post subject: Reply with quote
Rogerborg wrote:
Ah, good news.
I don't know if 220 is a good price or not but the sensor alone is probably over 100. Then the throttle bodies need synchronising so I guess it's probably fair enough. Definitely need to invest in a GS-911 though as it would have diagnosed it for me.
Honda CBR600F6
PostPosted: 14:55 - 14 Mar 2017    Post subject: Reply with quote
That actually sounds reasonable enough, although a GS-911 is first on my list if (when) my midi-Tractor starts acting up.
rhun
PostPosted: 15:07 - 14 Mar 2017    Post subject: Reply with quote
I thought so. Been pretty pleased with the service, good comms and super quick turnaround. It'll be ready to collect tomorrow.
Maybe we can share one seeing as you're local. Laughing
Honda CBR600F6
Oldie
PostPosted: 17:14 - 14 Mar 2017    Post subject: Reply with quote
I've got one with 7 slots left - happy to share.
rhun
PostPosted: 17:33 - 14 Mar 2017    Post subject: Reply with quote
That would be most appreciated in tough times like these/reset service indicator Mr. Green . Are you based around Glasgow?
Honda CBR600F6
The last post was made 9 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 128.87 Kb
