Cutting out on idle
rhys99
PostPosted: 17:41 - 07 Mar 2017    Post subject: Cutting out on idle Reply with quote
My Aprilia RS4 125 just began cutting out on idle, it will idle for 10 ish seconds then die. It starting doing this half way through a ride once the engine was warm, also when starting it back up it would backfire. It's due a valve clearance check, could this be the cause of the problem? thanks
21:16:02 Fin: I got a girl to believe I have a huge dick today, she's going to be so disappointed
K̶5̶ ̶S̶V̶6̶5̶0̶S̶ K3 SV650N
Tankie
PostPosted: 20:29 - 07 Mar 2017    Post subject: Reply with quote
sounds like it's running a bit lean, screw the air screw in 1/4 turn
rhys99
PostPosted: 22:13 - 07 Mar 2017    Post subject: Reply with quote
It's fuel injected
Paulf
PostPosted: 22:35 - 07 Mar 2017    Post subject: Reply with quote
Not familiar with aprilla but if it's fuel injected it would sound like the IAC idle air control valve if fitted on other makes e.g. honda you can do an IAC reset but means messing with ecu. Check youtube for aprilla reset or a learned member might put in a suggestion. This assumes the basics are right e.g. good spark, good compression, fuel pump working, spot on timing and valve clearances spot on. Start with the basics.
rhys99
PostPosted: 22:48 - 07 Mar 2017    Post subject: Reply with quote
The bike seems to run fine through out the rev range, it's just the stuttery idle then cutting out which is strange. One of the times i restarted and set off it bucked badly which makes me think its more than a sensor or control valve.
rhys99
PostPosted: 17:09 - 12 Mar 2017    Post subject: Reply with quote
Update : plugged in to diagnostics thingy and has 3 faults codes, open circuit ( cant remember other bit ) on Injector, coil and temp sensor. Bike doesn't start at all now.
The last post was made 9 years, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.64 - MySQL Queries: 13 - Page Size: 48.74 Kb
