2 stroke RC valve
Honda Nsr 125
PostPosted: 01:56 - 10 Mar 2017    Post subject: 2 stroke RC valve Reply with quote
question is there anyway to make the rc valve engage sooner than 7500 rpm is it as simple as tighten one cable and loosen the other?
2 Stroke Monster
skatefreak
PostPosted: 10:58 - 10 Mar 2017    Post subject: Reply with quote
Nope.
Adjusting the cables will just adjust the position of the valve when it is open/closed which is of no use and may even decrease performance.
Mr Honda spent a lot of time/money tuning the engine and setting the R/C valve to work together through specific RPM ranges.
One thing you can do is unplug the servo and move it manually to open or closed (whilst stationary) and see how it effects the performance of the engine. Here's a clue though it doesn't do anything good, I'll say that much...
stirlinggaz
PostPosted: 18:35 - 10 Mar 2017    Post subject: Re: 2 stroke RC valve Reply with quote
Nope, you'd need ignitech box to alter when rc moves,
cheers,
GAZ
Fin
PostPosted: 20:17 - 10 Mar 2017    Post subject: Reply with quote
Adjusting the cables does change when the RC valve opens.
binge
Emo Kiddy
PostPosted: 20:30 - 10 Mar 2017    Post subject: Reply with quote
How?
If it's anything like the YPVS on the R1's, then the servo dictates when it moves, and the cables just dictate how far it moves (Obviously you want it adjusted so it fully opens)
By tightening the cables, you could end up with it being open too far at idle, and then going past fully open, and possibly snapping the cables etc.
My old 4xV R1, I fitted a 421 TI system on it, and had a box made up to replace the servo, to trick the engine management to thinking it still had the servo.
Although it was making over 150bhp on the rollers, it was flat as fuck below 6k. I always regretted coming away from a working valve.
redeem ouzzer
PostPosted: 21:44 - 10 Mar 2017    Post subject: Reply with quote
Kill yourself.
Be a REAL MAN!
PostPosted: 15:12 - 11 Mar 2017    Post subject: Re: 2 stroke RC valve Reply with quote
Why do you want to? Chances are that doing this (or at least beyond a nominal amount) you would get a flat spot between the power valve opening and the power band kicking in.
If you have changed the exhaust, etc, so the power band kicks in earlier (and the chances are this would result in an exhaust giving less peak power) then it might be a useful thing to do.
Katy
The last post was made 9 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 52.94 Kb
