YBR 125 - engine cuts out at every stop
Waaarrrggghhh
PostPosted: 13:23 - 12 Mar 2017    Post subject: YBR 125 - engine cuts out at every stop Reply with quote
engine just cuts out every time I come to a stop.
The revs just die down to zero, then when I open the throttle, even just a tiny bit, the engine turns itself off. I am keeping the clutch held in completely. When I try to start it back up, I need to hold the power button down for a good 10 seconds or so for the engine to start back up again, otherwise it just struggles, and doesn't start.
I checked the spark plug and it looks fine.
Anyone know what could be the problem? Faulty battery?
This happened straight after a fairly long (120 mile) trip.
PostPosted: 13:30 - 12 Mar 2017    Post subject: Reply with quote
Fuel injection or carb?
Waaarrrggghhh
PostPosted: 13:57 - 12 Mar 2017    Post subject: Reply with quote
fuel inject, its a 2010 model.
zark
PostPosted: 16:57 - 12 Mar 2017    Post subject: Reply with quote
If you click into neutral before coming to a stop does it still stall? Clutch not disconnecting drive fully?
Warm start problems are fairly typical, iirc
CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou...
Waaarrrggghhh
PostPosted: 00:20 - 13 Mar 2017    Post subject: Reply with quote
No idea but probably it would, should be no difference at all between st with clutch in and neutral. I don't like being in neutral because 1. it is hard to find, 2. often it says the green 'N' but it will still pull forwards, and 3. so I have a means of escape.
The last post was made 9 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 43.63 Kb
