Absolute Mother of a Siezed Axle
MahatmaAndhi
PostPosted: 17:00 - 22 Apr 2017    Post subject: Absolute Mother of a Siezed Axle Reply with quote
The new chain and sprocket arrived, so I began to set to work on the GN125. However, the rear axle will. not. fucking. budge.
I've been trying to get it out for hours. I've twatted it with a rubber mallet more times than I know.
I've taken the entire wheel and swing arm off, laid them so that the axle is suspended and hit that fucker so much that I'm physically tired. After several hours, it's now sticking out about an inch out of the other side.
The axle turns freely. Put a wrench over the nut (the bit that's part of the axle) and it turns no problem. But moving it horizontally? No chance.
Any ideas?
2008 Aprilia Sportcity 250
andy_uk
PostPosted: 17:17 - 22 Apr 2017    Post subject: Reply with quote
Spray some penetrating oil on the bits you can see, wack it back in again, more oil then try tapping it out again.
kgm
PostPosted: 17:20 - 22 Apr 2017    Post subject: Reply with quote
Heat gun or plus gas (penetrant oil).
If you're having to hit it that hard then you might want to consider replacing the wheel bearings (less than £5 each) as you may end up damaging them. Also using heat could damage the seals if you're not careful. How big a hammer are you using?
PostPosted: 17:27 - 22 Apr 2017    Post subject: Reply with quote
Cut it with a hacksaw and get a replacement from a breakers or eBay. Wink
Fisty
PostPosted: 17:29 - 22 Apr 2017    Post subject: Re: Absolute Mother of a Siezed Axle Reply with quote
Any ideas?
Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing
Fatter and faster than Fret
MahatmaAndhi
PostPosted: 17:40 - 22 Apr 2017    Post subject: Reply with quote
A rubber mallet. Dunno how big. About the size of a coffee mug.
I thought about cutting it off, but then it's still stuck in the wheel itself, so I'd have to replace that too.
Fisty
PostPosted: 18:00 - 22 Apr 2017    Post subject: Reply with quote
Hit it harder with a lump hammer.
If it went in, it will come out.
dydey90
Hitting it with something made by Thor rather than Fisherprice will help. I generally find that a 2lb lump hammer and a big swing will shift most things.
Sounds daft, but there's generally a circlip or two that you can never see because everything is covered in grease and road dust. I've seen tiny circlips give a hydraulic press some trouble.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:17 - 22 Apr 2017    Post subject: Reply with quote
The rubber mallet is just to tickle things. If you want to actually shift stuff, 2lb lump hammer.
It's not like you can't make it any worse than a wheel that you can't put a new tyre on.
Triumph Sprint ST 1050
PostPosted: 18:57 - 22 Apr 2017    Post subject: Reply with quote
Axles are pretty soft, twatting it with a hammer is going to ruin the end very quickly. You need to use a piece of soft ally to protect the end of the axle. Putting a tube over the large end and driving the axle into the tube held vertically on the floor will help a lot too.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:22 - 22 Apr 2017    Post subject: Reply with quote
So, if you can't get the fucker out what difference does this make?
PostPosted: 19:42 - 22 Apr 2017    Post subject: Reply with quote
It makes a difference if you ever want to re-use it again. Knock it out and use it vs knock it out and buy a new one.
M.C
PostPosted: 19:57 - 22 Apr 2017    Post subject: Reply with quote
My 125 had a seized rear axle... it stayed in. Tried everything, took a blowtorch to it, even twatted it to within an inch of its life.
Chris45
PostPosted: 20:03 - 22 Apr 2017    Post subject: Reply with quote
Heavy duty hammer+block of wood between said items usually works for me. Get a mate (wife will do) to hold the block of wood and give it an almighty wallop. If that doesn't work try a heavy duty punch centered on the mid point of the axle. Tap it, don't whack...
Could deffo be a broken circlip or bearing stopping it sliding out though... Sad
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
Nobby the Bastard
Harley Gaydar
PostPosted: 20:05 - 22 Apr 2017    Post subject: Reply with quote
If you have to belt it that hard with a lump hammer, the fucker is fucked.
Sload
PostPosted: 20:27 - 22 Apr 2017    Post subject: Reply with quote
We need pics
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
Andy_Pagin
PostPosted: 20:34 - 22 Apr 2017    Post subject: Reply with quote
You could try a Kango hammer with a metal block protecting the axle from the chisel, vibrate the bastard into submission.
pepperami
PostPosted: 21:37 - 22 Apr 2017    Post subject: Reply with quote
Knock it out as far as it will go and squirt the dry end with penetrating oil , then knock it back in.
Repeat many times.
Each time you will get the oil in a bit further.
If you can get some rotation on the axle, that will help.
V2
PostPosted: 07:35 - 23 Apr 2017    Post subject: Reply with quote
Bigger hammer
https://s-media-cache-ak0.pinimg.com/736x/85/6d/07/856d07a5d284e6bd0f1587ef3dab410e.jpg
kramdra
PostPosted: 13:38 - 23 Apr 2017    Post subject: Reply with quote
Probably sprocket carrier bearing spacer siezed in place. I have had this, chopped the axle. Large sledge hammer wouldnt shift it, almost bent the swingarm.
PostPosted: 16:10 - 23 Apr 2017    Post subject: Reply with quote
I've just split several blocks shifting my Nazi Tractor axle. It did shift eventually though. PlusGas in between all the components, wiggle the wheel side-to-side to try and break the bond between the axle and whatever it's binding on.
nowhere.elysium
The Pork Lord
PostPosted: 17:05 - 23 Apr 2017    Post subject: Reply with quote
Only if you're a total spastic. Pete's advice is sound.
MahatmaAndhi
PostPosted: 18:24 - 24 Apr 2017    Post subject: Reply with quote
I just bought a dead blow hammer and a set of punches (that go up to 9.5mm). I'm gonna have to buy a new rear axle anyway, so I'm going to hammer the living daylights out of it until it gets the fuck out... tomorrow, as I just put the kids to bed.
Sload
PostPosted: 20:08 - 24 Apr 2017    Post subject: Reply with quote
Seriously, do a short vid of it with you manipulating it for people to see (the axle, don't get kinky). Couple of experienced peeps here might save you a bit of bother.
Skudd
PostPosted: 20:28 - 24 Apr 2017    Post subject: Reply with quote
Put the nut back on but keep it at the top of the axle to protect it and also give yourself a bigger area to hit. Just a normal everyday hammer will do and a bit of time and muscle. You will need to change the bearings as this is what the axle is stuck on. Also give the axle a good clean afterwards.
The last post was made 8 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 128.97 Kb
