delayed rear drum brake release
czakal
PostPosted: 20:19 - 03 May 2017    Post subject: delayed rear drum brake release Reply with quote
Hello,
I'm having a problem with my rear drum brake on my Kymco Pulsar 125 (mostly like a CG125). The rear brake pads take a moment to fully release when I use it (the brake pedal appears to return completely but the pads are still dragging and usually make a squeaking noise). As the problem disappears some time after I start my trip, I'm not able to recreate it when I finish my trip to troubleshoot. What causes the rear brake pads to not release right when you lift your foot off the lever?
Thanks for your help,
Seb
kgm
PostPosted: 20:45 - 03 May 2017    Post subject: Reply with quote
Probably just needs a good clean out. Brake dust builds up in the drum and can cause such problems. Use a tiny bit of grease of the cam (the bit that turns and pushes the shoes apart, just a wee dab in between the shoe and the cam face - you don't want it to contaminate the pad surface)
czakal
PostPosted: 22:19 - 03 May 2017    Post subject: Reply with quote
Thanks, I haven't disassembled a brake before. Guess there's a first time for everything!
Seb
kgm
PostPosted: 04:46 - 04 May 2017    Post subject: Reply with quote
If you can take the wheel off you can do that. Other thing it could be is corrosion around the shaft of the cam. Again a clean out and a little lube in there. Loosen the bolts holding the actuator arm on before you take the wheel off. If they're still it's easier whilst the whole assembly is still mounted.
rcbikeracer
PostPosted: 07:10 - 04 May 2017    Post subject: Reply with quote
pads suggest disc brakes Rolling Eyes
PostPosted: 07:52 - 04 May 2017    Post subject: Reply with quote
Sticky, corroded cam freeing off when it gets hot from use.
Strip, clean, re-lube.
https://www.bikechatforums.com/viewtopic.php?t=174773
Evil Hans
PostPosted: 08:01 - 04 May 2017    Post subject: Reply with quote
Yeah, but I'm pretty sure the Pulsar has a rear drum. Confused now!
Stoker
PostPosted: 13:45 - 04 May 2017    Post subject: Reply with quote
"...my rear drum brake..." suggests drum brake
mkjackary
PostPosted: 21:53 - 05 May 2017    Post subject: Reply with quote
I took mine off the other day, piece of piss. Just go around everything with some brake cleaner and then anything sized/stiff that shouldn't be, wd40 it till it's not, then grease it till it's smooth, then put it back together, may be worth replacing your shoes whilst you are in there, depends whether you can be asked to take it all apart again later down the line. For the sake of 18 quid I replaced mine whilst un seizing it.
Aslong as you have the tools (socket set, torque wrench if you don't trust yourself) and the lube, then you just need to watch a couple of videos on YouTube and you are set
iooi
PostPosted: 08:26 - 06 May 2017    Post subject: Reply with quote
mkjackary wrote:
then grease it
What grease?
Given brakes get hot... Last thing you need is it melting all over shoe surface....
Tankie
PostPosted: 08:55 - 06 May 2017    Post subject: Reply with quote
iooi wrote:
mkjackary wrote:
then grease it
What grease?
Small amount on spindle of cam after cleaning off any corrosion
grr666
PostPosted: 09:19 - 06 May 2017    Post subject: Reply with quote
Handy video to show how they work.
iooi
PostPosted: 14:57 - 06 May 2017    Post subject: Reply with quote
But what type of grease.... Rolling Eyes
There are many types. Some will cause problems. Others won't. Thumbs Up
Tankie
PostPosted: 15:11 - 06 May 2017    Post subject: Reply with quote
High melting point, which is a pretty standard grease
ThatDippyTwat
PostPosted: 17:26 - 06 May 2017    Post subject: Reply with quote
Shell Gadus, V220c. Anything that turns on a bike and needs greasing will be fine with it. The grease fairy in work brings mine. Otherwise, a fiver on ebay will get you a tub that will probably outlast the bike, and possibly you, if you seal it properly when done using it.
The last post was made 8 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 83.99 Kb
