| Tracer1234 |
 Tracer1234 World Chat Champion
 Posted: 00:21 - 09 May 2017 Post subject: FFS...ALMOST fixed: leaky nipple? (Yam Tracer) |
Right, so first off, I am well aware of the extreme newbness of these question.
So, my main riding experience of a bog boy bike, has been the street triple.
I am now riding the 900 Tracer. I have been riding along quite happily without any issues. Yesterday, when riding on the motorway, at slight kitten killing speeds, although not too high, when coming off the throttle, I noticed a high level of what I assume is engine braking. I was a little surprised by how much. So in playing on the bike at different speeds, I have become worried that the engine braking may be too much, although at lower speeds, I do not notice the issue. So I began to wonder if my brakes were actually dragging, after a ride, with very little rear brake use, I stopped and felt the disk, and noticed that it was hot to touch.
TL;DR
What does normal engine braking feel like at, say 80?
How do I tell if the back brake is rubbing?
Is it normal for the disk to get hot.
When on the Centre stand, how free should the wheel be to move?
I am sorry for the stupid questions.
TYIA.  ____________________ Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
| Evil Hans |
 Evil Hans World Chat Champion
| Tracer1234 |
| jaffa90 |
 jaffa90 World Chat Champion
| arry |
 arry Super Spammer
| Tracer1234 |
| garth |
 garth World Chat Champion
| Tracer1234 |
| Kris |
 Kris World Chat Champion
 Posted: 14:55 - 09 May 2017 Post subject: |
I think your brakes are dragging. I had similar symptoms when mine were dragging and binding on the disc.
With mine, I let off the throttle a slight amount and the bike slowed much quicker than anticipated. Fuel consumption suffered too.
 ____________________ NSR125RR - ZXR750H1 - ZX9R E1 - GSF600S - GSF600SK3 - VFR400-NC30 - SV1000N - ST1100-R - CBR900RR-R - GSF1200SK5 - GSF600SK1 - VFR1200FA - GSXR1000K2 - ZZR1400 D8F
www.prisonplanet.com |
| Tracer1234 |
 Posted: 15:07 - 09 May 2017 Post subject: |
After further attempts to fix, the brake has now seized.
Clearly I have screwed something.  ____________________ Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
CBT 04/14. A: Mod 1 & 2 13/04/15 |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| Tracer1234 |
 Posted: 15:45 - 09 May 2017 Post subject: |
So, I took it apart, then pumped the brakes to put out the piston then cleaned this.
Then, with a clamp and wood, i pushed it back in.
Cleaned off the rest of it.
Put it back on the bike and tightened.
At this stage I started the bike and pushed the brake, it was very spongy and was not engaging the brake.
Then at this point took it off again, checked, put it back together, pumped the brake and the back wheel is now seized.
| DRZ4Hunned |
 DRZ4Hunned World Chat Champion
| Tracer1234 |
| Holdawayt |
 Holdawayt Trackday Trickster
| DRZ4Hunned |
| Tracer1234 |
| DRZ4Hunned |
 Posted: 16:22 - 09 May 2017 Post subject: |
Apologies, rear brake then yes one piston... Even easier
Doesn't it say on the top of the reservoir cap? I'd imagine DOT 4 ____________________ DRZ400-SM
FZS600 |
| Tracer1234 |
 Posted: 17:20 - 09 May 2017 Post subject: |
Ok, so... I am stumped.
The bolt in the image.
https://s24.postimg.org/n54mf6ekl/IMG_20170509_170203.jpg
When this is loose, or not in, the brakes work fine. No sticking, no sponge etc etc.
But when this bolt is tightened again, it is spongy, with no resistance on the foot peddle, and the breaks are seized. when pushing the peddle, the whole caliper moves as can be seen slightly in the video.
Also, when I pushed the prison back in, I didn't remove the cap from the break fluid, could I have damaged something here?
Help?!?
https://www.youtube.com/watch?v=wMxPEJkiUY4 ____________________ Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
| Orinj |
 Orinj L Plate Warrior
 Posted: 18:05 - 09 May 2017 Post subject: |
Hi guys, friend of Nathan's here.
Went round to have a look at his brakes for him. Piston wasn't pushed out so dont need to bleed.
The main thing that has stumped me is that as he said, with only the rear calliper bolt in, and no front bolt in, there is pressure in the pedal. The wheel spins freely and stops as should when the pedal is pressed.
When the front bolt is put in and tightened up, the wheel will not spin freely, and no pressure builds in the pedal even after pumping it 20+ times.
When tightened, it seems like the calliper is too close to the disc, so the static pad is sitting on the disc rather than floating on it.
Just thought I'd add this to make it clear.
Yes he pushed the piston back in without taking fluid cap off, but that would damage the seal if anything, not how the calliper sits surely?
Thanks. |
| arry |
 arry Super Spammer
| Tracer1234 |
| garth |
| Tracer1234 |
| Beehive Bedlam |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
 Beehive Bedlam World Chat Champion
The last post was made 8 years, 328 days ago. Instead of replying here, would creating a new thread be more useful? |
