FFS...ALMOST fixed: leaky nipple? (Yam Tracer)
Tracer1234
PostPosted: 00:21 - 09 May 2017    Post subject: FFS...ALMOST fixed: leaky nipple? (Yam Tracer) Reply with quote
Right, so first off, I am well aware of the extreme newbness of these question.
So, my main riding experience of a bog boy bike, has been the street triple.
I am now riding the 900 Tracer. I have been riding along quite happily without any issues. Yesterday, when riding on the motorway, at slight kitten killing speeds, although not too high, when coming off the throttle, I noticed a high level of what I assume is engine braking. I was a little surprised by how much. So in playing on the bike at different speeds, I have become worried that the engine braking may be too much, although at lower speeds, I do not notice the issue. So I began to wonder if my brakes were actually dragging, after a ride, with very little rear brake use, I stopped and felt the disk, and noticed that it was hot to touch.
TL;DR
What does normal engine braking feel like at, say 80?
How do I tell if the back brake is rubbing?
Is it normal for the disk to get hot.
When on the Centre stand, how free should the wheel be to move?
I am sorry for the stupid questions.
TYIA. Thumbs Up
Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
Evil Hans
PostPosted: 00:31 - 09 May 2017    Post subject: Reply with quote
Is this a question about brakes?
Tracer1234
PostPosted: 00:40 - 09 May 2017    Post subject: Reply with quote
Embarassed
Lol, indeed, breaks.
jaffa90
PostPosted: 00:46 - 09 May 2017    Post subject: Reply with quote
Ride the bike only using the front brake and then feel the back disc, also visa-versa. An unused brake disc should not feel hot.
arry
PostPosted: 06:42 - 09 May 2017    Post subject: Reply with quote
You're going to have to clean the caliper up at some point; may as well just make it now and put your mind at ease - best way of telling either you've a sticky piston is to go actually move that piston.
Tracer1234
PostPosted: 14:15 - 09 May 2017    Post subject: Reply with quote
Piston cleaned and piston moves...
It may be a case of not knowing what is normal. How freely should the rear wheel spin when on centre stand?
How should normal engineering braking feel?
Anyone local want a quick ride and tell me what they think?
garth
PostPosted: 14:19 - 09 May 2017    Post subject: Reply with quote
I'm in Hampshire. I'll have a ride and look for you.
Hedge end to be precise.
Tracer1234
PostPosted: 14:30 - 09 May 2017    Post subject: Reply with quote
That would be amazing. What beers do you drink lol?
Side note. Put it back together and now spongy and no brakes at all Embarassed
Kris
PostPosted: 14:55 - 09 May 2017    Post subject: Reply with quote
I think your brakes are dragging. I had similar symptoms when mine were dragging and binding on the disc.
With mine, I let off the throttle a slight amount and the bike slowed much quicker than anticipated. Fuel consumption suffered too.
www.prisonplanet.com
Tracer1234
PostPosted: 15:07 - 09 May 2017    Post subject: Reply with quote
After further attempts to fix, the brake has now seized.
Clearly I have screwed something. Embarassed Crying or Very sad
DrSnoosnoo
PostPosted: 15:29 - 09 May 2017    Post subject: Reply with quote
Describe what you have done during these attempts and you may get some simple solutions.
Tracer1234
PostPosted: 15:45 - 09 May 2017    Post subject: Reply with quote
So, I took it apart, then pumped the brakes to put out the piston then cleaned this.
Then, with a clamp and wood, i pushed it back in.
Cleaned off the rest of it.
Put it back on the bike and tightened.
At this stage I started the bike and pushed the brake, it was very spongy and was not engaging the brake.
Then at this point took it off again, checked, put it back together, pumped the brake and the back wheel is now seized.
Embarassed
DRZ4Hunned
PostPosted: 15:48 - 09 May 2017    Post subject: Reply with quote
Did you remove the pistons?
Did you re-bleed the brakes?
DRZ400-SM
FZS600
Tracer1234
PostPosted: 15:56 - 09 May 2017    Post subject: Reply with quote
I didn't remove it completely, and I didn't re-bleed them.
Would not have the first clue where to start to bleed/re-bleed them etc
Would I need to buy brake fluid?
Holdawayt
PostPosted: 16:05 - 09 May 2017    Post subject: Reply with quote
As above... you need to bleed the brakes if you've removed the piston.
If you're unsure about working on bikes, the brakes are an awful place to start tinkering. They're pretty vital and bleeding them should be an obvious final step.
DRZ4Hunned
PostPosted: 16:06 - 09 May 2017    Post subject: Reply with quote
If you brake the seal (by removing the pistons) then you need to re-bleed them. I typically replace the fluid when doing this.
The brakes shouldn't be spongy after a squeezing the lever a few times and if they are then they need to be bled. Not sure why would be seized unless you've twisted one of the piston seals and it's dragging on the piston? I'd remove the caliper and pump the pistons (making sure not to pop them out), just to see whether they're moving at all. If you clamp one piston, the others should move.
DRZ400-SM
FZS600
Tracer1234
PostPosted: 16:18 - 09 May 2017    Post subject: Reply with quote
Worried that I have the wrong part in mind as there is only ?one piston?
So, the next ridiculous question, in this thread of stupidness, what break fluid does one need to buy.
DRZ4Hunned
PostPosted: 16:22 - 09 May 2017    Post subject: Reply with quote
Apologies, rear brake then yes one piston... Even easier Very Happy
Doesn't it say on the top of the reservoir cap? I'd imagine DOT 4
DRZ400-SM
FZS600
Tracer1234
PostPosted: 17:20 - 09 May 2017    Post subject: Reply with quote
Ok, so... I am stumped.
The bolt in the image.
https://s24.postimg.org/n54mf6ekl/IMG_20170509_170203.jpg
When this is loose, or not in, the brakes work fine. No sticking, no sponge etc etc.
But when this bolt is tightened again, it is spongy, with no resistance on the foot peddle, and the breaks are seized. when pushing the peddle, the whole caliper moves as can be seen slightly in the video.
Also, when I pushed the prison back in, I didn't remove the cap from the break fluid, could I have damaged something here?
Help?!? Sad
https://www.youtube.com/watch?v=wMxPEJkiUY4
Orinj
PostPosted: 18:05 - 09 May 2017    Post subject: Reply with quote
Hi guys, friend of Nathan's here.
Went round to have a look at his brakes for him. Piston wasn't pushed out so dont need to bleed.
The main thing that has stumped me is that as he said, with only the rear calliper bolt in, and no front bolt in, there is pressure in the pedal. The wheel spins freely and stops as should when the pedal is pressed.
When the front bolt is put in and tightened up, the wheel will not spin freely, and no pressure builds in the pedal even after pumping it 20+ times.
When tightened, it seems like the calliper is too close to the disc, so the static pad is sitting on the disc rather than floating on it.
Just thought I'd add this to make it clear.
Yes he pushed the piston back in without taking fluid cap off, but that would damage the seal if anything, not how the calliper sits surely?
Thanks.
arry
PostPosted: 18:09 - 09 May 2017    Post subject: Reply with quote
Take caliper off again. Take reservoir cap off. Push piston back in fully (it should be able to be done by hand) and then put cap back on, and remount caliper. See what happens.
I reckon the piston has forced its way back out.
Tracer1234
PostPosted: 18:31 - 09 May 2017    Post subject: Reply with quote
Done, No luck. thank you though.
Added note, that when i push the bolt in, and twist once of twice, it is still ok. but said bolt, any further than that, it all goes wrong Sad
garth
PostPosted: 18:51 - 09 May 2017    Post subject: Reply with quote
Put the tools down, I'll have a look tomorrow.
Tracer1234
PostPosted: 18:53 - 09 May 2017    Post subject: Reply with quote
Sad Roger that.
Beehive Bedlam This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
The last post was made 8 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 135.37 Kb
