Fixing the bike after dropping it
Sweaty_Doughnut
PostPosted: 07:02 - 13 May 2017    Post subject: Fixing the bike after dropping it Reply with quote
Hi guys,
I am trying to figure out how to fix the damaged parts after dropping the bike. I believe it will start to rust if I don't repair those. I have included the video for reference.
Do you have any advice?
https://drive.google.com/open?id=0B23_TkNKg71kSURqQzczc3pubXM
PostPosted: 07:18 - 13 May 2017    Post subject: Reply with quote
Yes, you will want to cover those ASAP. A light sanding then paint on the black bits (gloss and satin as indicated, £1 shop is fine) and clear lacquer on the shiny bits.
Try not to sweat it, bikes get dropped and that could have been worse.
Sweaty_Doughnut
PostPosted: 07:48 - 13 May 2017    Post subject: Reply with quote
Do I need to use something to fill up the holes as well? What type of paint would you use for the exhaust so it doesn't burn?
PostPosted: 09:33 - 13 May 2017    Post subject: Reply with quote
If you want it to look pristine then you'll have to fill and match the paint. Chances are you'll just go and drop it on the other side though. I'd be more concerned about covering the metal ASAP.
You can use VHT / stove enamel / barbecue paint on the exhaust, but end cans don't get super hot so you might get away with £1 shop.
M.C
PostPosted: 11:23 - 13 May 2017    Post subject: Reply with quote
Unless you live on the Isle of Portland I wouldn't worry about it. None of my exposed areas started to rust.
ADSrox0r
PostPosted: 11:27 - 13 May 2017    Post subject: Reply with quote
The engine crash bars might rust but the rest is fine. It's just battle scars, wear them with pride it just adds character and maximises bants.
Sweaty_Doughnut
PostPosted: 00:52 - 14 May 2017    Post subject: Reply with quote
I painted everything, thanks for advice guys. It doesn't look perfect but I was not willing to pay the shop to do it.
arry
PostPosted: 09:11 - 14 May 2017    Post subject: Reply with quote
Good effort. I'd have done same, Roger's advice was the right option.
PostPosted: 09:42 - 14 May 2017    Post subject: Reply with quote
Winter in Scotchland can be like riding on salt flats.
Granted, OP's not in Scotchland it's not winter. Wink
grr666
PostPosted: 09:51 - 14 May 2017    Post subject: Reply with quote
What paint did you use OP? I have a small mark on my frame as the only remaining reminder of a recent spill.
My frame is a satin black colour. I don't even mind buying 'proper' touch up paint from Yamaha if it will match in
right. Failing that, does anyone know if the chips away type guys do bikes?
M.C
PostPosted: 11:54 - 14 May 2017    Post subject: Reply with quote
Can you find colour codes for the other bits (frame/forks etc.)?
grr666
PostPosted: 18:48 - 14 May 2017    Post subject: Reply with quote
I've found a metallic matte black which seems about right, but I'd like to know for certain if it's a perfect match
before I pull the trigger.
M.C
PostPosted: 13:37 - 15 May 2017    Post subject: Reply with quote
Let me know if you find a way. I've only found colour codes for the main bits (tank etc.), where there are plenty of sellers on eBay willing to sell you a very expensive tiny touch-up pot.
chickenstrip
PostPosted: 13:45 - 15 May 2017    Post subject: Reply with quote
right.
I thought Yamaha stopped doing touch-up paints years ago?
I have been told RS Paints do a touch up for the, sort of, graphite black on my frame and engine, but pricey.
The last post was made 8 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 82.03 Kb
