suzuki gp100 breathing
ash.y
PostPosted: 09:14 - 14 May 2017    Post subject: suzuki gp100 breathing Reply with quote
it was working ok took the carb off to clean as only had the bike a few weeks now main jet was blocked in some of the holes, put it back on and it wont rev or pull when the cover is on when its off it runs/ pulls fine any advice? plus it has 3 pipes on the left side of carb i know what 2 of them are but the third one i cant find any use for it cant find anything in the manual about this lone pipe any help would be greatly appreciated.
jaffa90
PostPosted: 09:23 - 14 May 2017    Post subject: Reply with quote
What cover??
ash.y
PostPosted: 09:28 - 14 May 2017    Post subject: Reply with quote
on the right hand side of the bike the carb is behind a cover/ case when this is on the bike wont pull but when its off its fine.
jaffa90
PostPosted: 10:17 - 14 May 2017    Post subject: Reply with quote
Not familiar with your bike but it sounds happier with a freer air flow (without cover), so what is wrong with the carb if it was ok before?
Is the carb airtight to the engine and does the choke shut off?
Be carefull not to run on a weak mixture.
ash.y
PostPosted: 11:50 - 14 May 2017    Post subject: Reply with quote
it didnt seem quite 100% so took it off to clean, it is air tight to to engine and choke does shut off, ive seen two posts with the exact same problem but there was no answer as to why this happens i googled the symptoms of it and both posts were on here.
Nemo
PostPosted: 12:28 - 14 May 2017    Post subject: Reply with quote
One of the hoses is an air vent, is it clogged or kinked?
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Nobby the Bastard
Harley Gaydar
PostPosted: 14:04 - 14 May 2017    Post subject: Reply with quote
The carb is on the rhs of the crank behind a cover (because it has a rotary valve on the end of the crank.)
If it only runs without the cover, it's either running incredibly rich or the pipe from the airbox is blocked.
Triumph Sprint ST 1050
ash.y
PostPosted: 20:09 - 14 May 2017    Post subject: Reply with quote
cant see anything thats blocked, ive set the mix screw out at 1 and a half turns so the manual says, ive tried playing around with it but has made no difference.
Commuter_Tim
PostPosted: 20:14 - 14 May 2017    Post subject: Reply with quote
Did you poke anything in the jet holes to 'clean' them?
I ride a Bandit 600... badly.
ash.y
PostPosted: 20:19 - 14 May 2017    Post subject: Reply with quote
i used an old tooth brush to clean the jet holes and some carb cleaner,
Nobby the Bastard
Harley Gaydar
PostPosted: 20:51 - 14 May 2017    Post subject: Reply with quote
Remove the air filter from the airbox and try it.
ash.y
PostPosted: 20:57 - 14 May 2017    Post subject: Reply with quote
tried that. im at a loss as to what the cause is.
Mentacycle
PostPosted: 13:56 - 15 May 2017    Post subject: Reply with quote
Just wondering how long its been since it had new crank seals...
What is your air filter like, check it for leaves,bugs,etc
bypass2
PostPosted: 21:37 - 15 May 2017    Post subject: Reply with quote
when you are putting the cover back on is it kinked/restricting the petrol flow to the petrol pipe if thats possiable.
bladerunner
PostPosted: 12:40 - 17 May 2017    Post subject: Reply with quote
Sounds like you've unblocked the main jet emulsion tube to where it should be and thats causing it to run rich now, either the last owner adjusted the air corrector screw to compensate or the air filter is blocked or now causing it to run rich. The std airbox even with a new filter is a restriction on the GP100 and they went much better without the entire thing TBH! ( pre harmonic airboxes tuned to your engine days!)
OR you screwed something up like float valve sticking or height is now different causing it to flood the carb !!
The last post was made 8 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 4.89 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 78.32 Kb
