Bike that stops when you sit on it?
Sirjohnsavile
PostPosted: 23:10 - 15 May 2017    Post subject: Bike that stops when you sit on it? Reply with quote
I have a Suzuki burgman an250. Recently it starts ok and ticks over and revs. However if I sit on the seat it cuts out. So I took off the seat and sat on the frame. Same thing...it stopped. It restarts when I get off the seat. Very mysterious..any ideas. Crying or Very sad
Arpete
jaffa90
PostPosted: 23:35 - 15 May 2017    Post subject: Reply with quote
EEEEEEEERRRRRRRRR, tilt sensor when up righting the bike or smothering the air intake.
sickpup
Old Timer
PostPosted: 23:36 - 15 May 2017    Post subject: Re: Bike that stops when you sit on it? Reply with quote
There is a wiring short somewhere. Possibly a wire going to the coils if all that happens is the engine cuts out.
PostPosted: 07:43 - 16 May 2017    Post subject: Reply with quote
Yup, wiring. Check for wiring that's being strained or rubbed when the suspension compresses.
<Tefanecdote> I inflicted this on myself when I fitted an oversized aftermarket CDI under the seat. Every time I hit a bump I strained the cables and the bike cut out. </Tefanecdote>
bugeye_bob
PostPosted: 08:00 - 16 May 2017    Post subject: Reply with quote
I thought that owners of the 250 Burgman had to have the mini RFID chip inserted in or around the anus, then paired to the bike as a security feature . . . . . Embarassed
Sirjohnsavile
PostPosted: 20:04 - 16 May 2017    Post subject: Reply with quote
Took off air filter, changed fuel filter. Checked fule pump, checked coil, checked side stand cut off switch.....no difference. Or runs on full throttle when i sit on it but anything less and it stops. Running out of ideas. Sorty ran out of ideas. CAnt think what it could be.Slent 3 days on it so far...
Arpete
jaffa90
PostPosted: 20:24 - 16 May 2017    Post subject: Re: Bike that stops when you sit on it? Reply with quote
""""Or runs on full throttle when i sit on it but anything less and it stops."""""
I`m confused now!
PostPosted: 21:00 - 16 May 2017    Post subject: Reply with quote
Hmm.
Taking all your symptoms at face value, I can think of two unlikely causes, which I throw out there just for quirkiness.
1) Compressing the suspension is causing something in the transmission (belt + shaft?) to engage the centrifugal clutch and stall it out at idle.
2) Even wilder, it's vaguely conceivable that you've got a crankcase breather that's being pinched when you sit on the seat, and it's over-pressuring the crankcase and stopping the piston at idle. I mention this because the AN400 had issues with sucking oil from the crankcase into the airbox and one bodge was to plug the airbox and re-route the breather... somewhere else.
That said, I'd still assume that your fuelling problem is electrical until it's been absolutely ruled out. Particularly so if it cuts out immediately when you sit on it, rather than struggling and then dying.
Which is a closer description of what's happening?
Sirjohnsavile
PostPosted: 07:54 - 17 May 2017    Post subject: Reply with quote
Well on idle the engine cuts out when I sit on the seat. If I get off the seat quickly it picks up again . I lifted the seat and took off the plastic cover. I found that if I press in the frame heavily then the engine cuts out. If I start the engine and rev it alot whilst holding the brake(it's an automatic) then it doesn't cut out until I ease off the revs. I've checked for any blocked or pinched file pipes but none are apparent.
Arpete
Sirjohnsavile
PostPosted: 07:58 - 17 May 2017    Post subject: Reply with quote
Furthermore the engine cuts out immediately not as if it were a fuel shortage where it might do a few seconds later.
Arpete
PostPosted: 09:02 - 17 May 2017    Post subject: Reply with quote
Electrical then. Something is being moved when you put weight on the frame, you just have to find it. Coil, CDI, HT lead, plug cap, main earth strap?
WD Forte
PostPosted: 11:04 - 17 May 2017    Post subject: Reply with quote
Just looked in as the title begged for "stop sitting on it then"
As the engine is part of the suspension It could any cable
or connector between engine and frame getting a bad contact as it flexes.
I'd start with the ground cable/s first
bikers smell of wee
Nemo
PostPosted: 11:44 - 17 May 2017    Post subject: Reply with quote
It doesn't like you
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
lilredmachine
PostPosted: 12:11 - 17 May 2017    Post subject: Reply with quote
Does it kill the ignition totally? No lights on dash etc as it is pooping out?
Hawkeye1250FA
PostPosted: 12:14 - 17 May 2017    Post subject: Reply with quote
Agreed.
Do you have any way of lifting the bike to work on it? I think you need to get under it with a powerful flashlight and check every cable.
My bet is one of them is either:
- Badly frayed and the movement of the frame is pulling what little copper is contacting away from the connector
- Or worse, there will be no signs of damage but an old cable will be snapped inside the sheath. The only way to find this is to check every cable with a multimeter without pressure on the frame and then again with pressure on.
Good luck!
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
WD Forte
PostPosted: 13:46 - 17 May 2017    Post subject: Reply with quote
OK
the BCF crowd are sensitive souls who wouldn't dream of causing offence, so I'll ask.
How heavy are you?
Is there a chance your enormously fat arse cheeks are restricting the air flow to the engine?
I don't judge, we don't do that here, just asking
bikers smell of wee
Sirjohnsavile
PostPosted: 14:03 - 17 May 2017    Post subject: Reply with quote
Sorry 12stone 13 but the air filter is off and it runs perfectltbwell til the engine flexes then immediately cuts out .it has to be electrical surely. Just cleaned starter motor earth. Cdi unit cables inspected and it still ticks over nicely. Gonna try and put a news ignition unit on when it arrives as I said earlier cos can't think of anything else.
Arpete
Sirjohnsavile
Sorry 12stone 13 but the air filter is off and it runs perfectltbwell til the engine flexes then immediately cuts out .it has to be electrical surely. Just cleaned starter motor earth. Cdi unit cables inspected and it still ticks over nicely. Gonna try and put a news ignition unit on when it arrives as I said earlier cos can't think of anything else.Coulnt be faulty stator could it cos battery is always charged
Arpete
PostPosted: 14:46 - 17 May 2017    Post subject: Reply with quote
Randomly changing parts is a hella expensive way of diagnosing an electrical problem. A multimeter is cheaper than pretty much any part. Unplugging and replugging connections is free.
Sirjohnsavile
PostPosted: 23:21 - 17 May 2017    Post subject: Reply with quote
Sorted it thank goodness. It was loose spade fittings on the coil. Thanks to all those who gave suggestions Very Happy
Arpete
lilredmachine
PostPosted: 00:04 - 18 May 2017    Post subject: Reply with quote
Lulz. Seruis?
As in checked it was present? Within the same postcode? Made for the machine? Wasn't off a Goldwing? Jebus, I remember why I don't come in here these days.
PostPosted: 09:09 - 18 May 2017    Post subject: Reply with quote
Congratulations on finding it. Loose connections are a right sod - give me a broken wire every time.
Hawkeye1250FA
PostPosted: 09:10 - 18 May 2017    Post subject: Reply with quote
Awesome.
Not the 7 weeks I imagined... Smile
The last post was made 8 years, 219 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 117.85 Kb
