| Sirjohnsavile |
 Sirjohnsavile L Plate Warrior
 Posted: 23:10 - 15 May 2017 Post subject: Bike that stops when you sit on it? |
I have a Suzuki burgman an250. Recently it starts ok and ticks over and revs. However if I sit on the seat it cuts out. So I took off the seat and sat on the frame. Same thing...it stopped. It restarts when I get off the seat. Very mysterious..any ideas.  ____________________ Arpete |
| jaffa90 |
 jaffa90 World Chat Champion
| sickpup |
 sickpup Old Timer
| Rogerborg |
 Rogerborg nimbA
 Posted: 07:43 - 16 May 2017 Post subject: |
Yup, wiring. Check for wiring that's being strained or rubbed when the suspension compresses.
<Tefanecdote> I inflicted this on myself when I fitted an oversized aftermarket CDI under the seat. Every time I hit a bump I strained the cables and the bike cut out. </Tefanecdote> ____________________ Biking is 1/20th as dangerous as horse riding.
| bugeye_bob |
 bugeye_bob World Chat Champion
 Posted: 08:00 - 16 May 2017 Post subject: |
I thought that owners of the 250 Burgman had to have the mini RFID chip inserted in or around the anus, then paired to the bike as a security feature . . . . .  |
| Sirjohnsavile |
| jaffa90 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 21:00 - 16 May 2017 Post subject: |
Hmm.
Taking all your symptoms at face value, I can think of two unlikely causes, which I throw out there just for quirkiness.
1) Compressing the suspension is causing something in the transmission (belt + shaft?) to engage the centrifugal clutch and stall it out at idle.
2) Even wilder, it's vaguely conceivable that you've got a crankcase breather that's being pinched when you sit on the seat, and it's over-pressuring the crankcase and stopping the piston at idle. I mention this because the AN400 had issues with sucking oil from the crankcase into the airbox and one bodge was to plug the airbox and re-route the breather... somewhere else.
That said, I'd still assume that your fuelling problem is electrical until it's been absolutely ruled out. Particularly so if it cuts out immediately when you sit on it, rather than struggling and then dying.
Which is a closer description of what's happening? ____________________ Biking is 1/20th as dangerous as horse riding.
| Sirjohnsavile |
| Sirjohnsavile |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:02 - 17 May 2017 Post subject: |
| Sirjohnsavile wrote: | Furthermore the engine cuts out immediately not as if it were a fuel shortage where it might do a few seconds later. |
Electrical then. Something is being moved when you put weight on the frame, you just have to find it. Coil, CDI, HT lead, plug cap, main earth strap? ____________________ Biking is 1/20th as dangerous as horse riding.
| WD Forte |
 WD Forte World Chat Champion
| Nemo |
 Nemo Could Be A Chat Bot
| lilredmachine |
 lilredmachine World Chat Champion
| Hawkeye1250FA |
 Hawkeye1250FA World Chat Champion
| WD Forte |
| Sirjohnsavile |
| Sirjohnsavile |
| Rogerborg |
 Rogerborg nimbA
| Sirjohnsavile |
 Posted: 23:21 - 17 May 2017 Post subject: |
Sorted it thank goodness. It was loose spade fittings on the coil. Thanks to all those who gave suggestions  ____________________ Arpete |
| lilredmachine |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:09 - 18 May 2017 Post subject: |
Congratulations on finding it. Loose connections are a right sod - give me a broken wire every time. ____________________ Biking is 1/20th as dangerous as horse riding.
| Hawkeye1250FA |
The last post was made 8 years, 221 days ago. Instead of replying here, would creating a new thread be more useful? |
