Tire Repair Kit?
Tracer1234
PostPosted: 23:55 - 28 May 2017    Post subject: Tire Repair Kit? Reply with quote
Hope you are all having a good BHW Bank Holiday Weekend, just a quick one:
Any recommendations for a small tire repair kit to pop under the seat.
There are many out there, so would rather go for one that has been recommended.
Tyia.
Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
Commuter_Tim
PostPosted: 00:51 - 29 May 2017    Post subject: Reply with quote
Stop and Go Mushroom kit
Used twice, holds air remarkably well.
I ride a Bandit 600... badly.
BTTD
PostPosted: 08:18 - 29 May 2017    Post subject: Reply with quote
https://www.amazon.co.uk/MOTORCYCLE-PUNCTURE-REPAIR-TUBELESS-SELLER/dp/B001AXK9QQ
Current one in the back tyre has seen 1000 miles and 120mph.
People seem to have equal success with the mushroom and the stringy ones. The biggest difference seems to be in the application, do it wrong and they're all equally bad.
doggone
PostPosted: 08:46 - 29 May 2017    Post subject: Reply with quote
Not all punctures are repairable at all if something goes in at an angle.
That little kit with included CO2(?) inflation seems worth having if there's space under the seat.
kramdra
PostPosted: 09:44 - 29 May 2017    Post subject: Reply with quote
BHW? Bum Hole Wank?
The kits are good problem is the person using it. You'd be better off with rac cover.
I prefer the string kit.
BTTD
PostPosted: 09:48 - 29 May 2017    Post subject: Reply with quote
If you use a canister, put your glove back on. The canisters freeze as they vent the gas.
I also carry a small airman pump in my bag as the canisters will get some air back into your tyre, probably enough to limp to a petrol station. I'm basing that on a 190 rear.
PostPosted: 10:05 - 29 May 2017    Post subject: Reply with quote
I switched to mushrooms after having two strings fail in a puncture. The mushroom held.
Shame you weren't there, you could have pointed out what I was doing wrong with the string, twice.
chickenstrip
PostPosted: 10:25 - 29 May 2017    Post subject: Reply with quote
I've gone for one of these, as it seems to get a lot of recommendations here on BCF, and BCF recommendations haven't let me down so far. I have never had to use a puncture repair kit of any description, except for one time many years ago when I didn't have one, and a helpful courier got me out of trouble by using his kit for me. So I'm probably quite capable of doing it wrong, although it looks simple enough.
waffles
PostPosted: 10:31 - 29 May 2017    Post subject: Reply with quote
I carry the Stop and Go kit for touring. Yes it is expensive and there are cheaper options out there but it has everything you would need to get you on your way again if you do get a puncture. Or at least mobile enough to limp to the nearest garage and call for help.
Plus the instructions are laminated in case you have to repair when its raining. They thought of everything!
chickenstrip
PostPosted: 10:34 - 29 May 2017    Post subject: Reply with quote
I only got the basic kit; no umbrella!
PostPosted: 10:35 - 29 May 2017    Post subject: Reply with quote
It feels a bit strange making the hole bigger, but don't be afraid to ream it out thoroughly. Once your little mushroom is popped into the gaping hole, you need to tug it out good and hard to achieve closure.
chickenstrip
PostPosted: 10:38 - 29 May 2017    Post subject: Reply with quote
Now I want a puncture! Laughing
wr6133
PostPosted: 11:06 - 29 May 2017    Post subject: Reply with quote
I used a string kit on my recent puncture (it was all I could scrounge). It held up fine for the ride home.
As already said though those little gas cans will only get 20-odd PSI in your rear so just enough to limp you to a garage. If you plan on being any real distance from a garage you'll also want a small compressor or more gas cans.
chickenstrip
PostPosted: 11:13 - 29 May 2017    Post subject: Reply with quote
How many canisters for a completely flat tyre? (180/55/17)
I've got 4, plus a compressor...bit of a belts and braces man Smile
waffles
PostPosted: 11:20 - 29 May 2017    Post subject: Reply with quote
You should have splashed out and bought the deluxe kit, it comes with a gazebo and someone to fix it for you while you relax!
ADSrox0r
PostPosted: 11:28 - 29 May 2017    Post subject: Reply with quote
https://media.2oceansvibe.com/wp-content/uploads/2015/01/ohmy.png
BTTD
PostPosted: 11:30 - 29 May 2017    Post subject: Reply with quote
Rolling Eyes
No, I couldn't. I've only ever used the Rema plugs I linked to. I like them, they work for me.
However I've read severable threads where they've been used incorrectly (user error or inappropriate punctures) and slated accordingly. My point is that I've read similar positive/negative threads on the strings and mushrooms.
You still in a bad mood because you got pay raped? Laughing
noobRider
PostPosted: 11:32 - 29 May 2017    Post subject: Reply with quote
+1 for the stop & go kit. I carry one after Ollie helped me with one on my rear tyre. 3 cylinders inflated it enough to get to a air line. I carry a mini powered pump as well now.
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
chickenstrip
PostPosted: 11:33 - 29 May 2017    Post subject: Reply with quote
I've got it covered:
https://i1291.photobucket.com/albums/b550/nicknicklxs/DSCN8718_zps33ukbgjn.jpg
Mr. Green
Freddyfruitba...
PostPosted: 12:12 - 29 May 2017    Post subject: Reply with quote
I now carry the Stop and Go kit following BCF recommendations (never had to use it yet), but reading the above I wonder whether the 'mushrooms' are less suitable for angled punctures than 'string' repair kits?
As it happens I need to replace my tyres very shortly, and when I do I'm going to have a practice with the puncture kit at home in the warm, dry, garage, to see how I get on with it.
chickenstrip wrote:
I've got it covered
I hope you can deflate that guitar, mate, or you're really gonna struggle getting it in the tank bag.
wr6133
I managed 24PSI on my 190/50/17 using 4 cans (which was adequate to limp to a garage). I have ordered these (box of 10 canisters) https://www.ebay.co.uk/itm/111868651124?_trksid=p2060353.m2749.l2649&var=410842504038&ssPageName=STRK%3AMEBIDX%3AIT
chickenstrip
PostPosted: 12:23 - 29 May 2017    Post subject: Reply with quote
Freddyfruitbat wrote:
chickenstrip wrote:
I've got it covered
Oh, I can carry a guitar. It's the rug I'm struggling with Thinking
Tracer1234
PostPosted: 14:08 - 29 May 2017    Post subject: Reply with quote
Ok thank you all. Stop n go looks like the way to go. Thumbs Up
kramdra
PostPosted: 15:34 - 29 May 2017    Post subject: Reply with quote
12v pump will fit underseat, beats cannisters.
A bike was here for a front tire swap yesterday. He didnt realise both were flat. 15psi front ad 10psi rear Shocked
MCN
PostPosted: 15:49 - 29 May 2017    Post subject: Re: Tire Repair Kit? Reply with quote
Tyia.
Ultraseal. Fit and forget.
The last post was made 9 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 141.68 Kb
