Noob torque wrench advice
mrmistoffelee...
PostPosted: 12:15 - 31 May 2017    Post subject: Noob torque wrench advice Reply with quote
So wanting to purchase a torque wrench to begin spannering but have 0% knowledge (have got the haynes for my bike)
do i get 1/2 / 3/8 ?
M.C
PostPosted: 12:18 - 31 May 2017    Post subject: Reply with quote
Never needed to use one. Not required unless you're rebuilding an engine/gearbox IMO.
Monkeywrenche...
PostPosted: 12:20 - 31 May 2017    Post subject: Reply with quote
they'll likely cover a different range of torque settings, 3/8 usually goes 10/20 up to 100/110nm while 1/2 goes 30 to 200 or so, a half inch set at it's lowest can be unwieldy compared to a 3/8 set in it's mid range likewise it's easier to do 100nm witha 1/2 than a shorter 3/8.
Tl;Dr get both
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
Monkeywrenche...
PostPosted: 12:25 - 31 May 2017    Post subject: Reply with quote
Some people like to know that fasteners that need to be a certain tightness are not too loose or at risk of damage by over tightening. without the experience required to "feel" what's tight enough a torque wrench will save stripped threads and damaged components.
Nexus Icon
PostPosted: 12:47 - 31 May 2017    Post subject: Reply with quote
3/8" will do 90% of things on a motorcycle but the larger one will do things the things that positively need doing.
Get both.
Greetings from Shitsville!
mrmistoffelee...
PostPosted: 12:49 - 31 May 2017    Post subject: Reply with quote
Also, speaking of spanner.. I am one, can this be moved to the workshop pls
M.C
PostPosted: 13:04 - 31 May 2017    Post subject: Reply with quote
There's enough evidence in the workshop of the damage a noob can do with a torque wrench.
Teflon-Mike
tl;dr
PostPosted: 13:36 - 31 May 2017    Post subject: Reply with quote
On a motorcycle, IF you need a torque wrench, it will likely be to avoid stripping threads on very LOW TORQUE screws and such in alloy castigs; not as on cars to wack up cylinder head studs to monster torques to keep them from blowing.
As such, MOST useful torque wrench for M/C mechanics will be a LOW RANGE, 0-25Nm sort of region, ad that will likely be on a smaller 1/4 drive rather than larger 3/8 or 1/4".
For the likely use, a 'cheap' £30ish example from Machine mart aught be more than good enough; provided you take care to look after it; and zero the scale after each use before storage; don't use it as a breaker bar and remember its a final setting tool, not a fancy ratchet; so use only for fnal setting after using an ordinary ratchet for doing stuff up 'fingy' tight, or getting old screws out to start with.
Most often, a Torque Wrench should be used only to avoid over tightening on delicate fasteners, or to ensure 'even' tightening across a flange like a primary drive case or such. It doesn't need to be ultra accurate; merely 'consistent' so on a flange all fasteners are within a couple of Nm of each other. So way you use it; stage setting, dong fasteners up around the clock, in sequence, keeping socket square to head, remembering to zero before store, and not use it as GP doey-upey ratcet, just as final setting tool, you dont have to have an ultra expensive one.
I bought a real cheap and nasty (high-range) one, when I was about 18, as didn't have a borrow in a hurry; Twenty years later, I won a rather fancy Teng one, with cal-cert and everything; Did a setting click-off on the pair to see how far off the old cheapo was, and you know what? it was within a couple of ft-lb throughout the range; more than good-enough; just through discipline of zeriong before store, and not using to (too often) as a fancy ratchet breaker bar, rather than a setting gauge!
But, as said, great for dong car cylinder head bolts, or disc brake mounting's; 25-250Nm torque-wrenches really aren't needed very often on a motorcycle; 1/4" drive 5-25Nm low range wench is far ore useful, far more often; ad that £30 Clarke fro Machne mart s an K example; get a couple of rails of 1/4" scokets to go with it, and keep just for the tQ-Wrench; £50 job-jobbed.
Only place you may want a high-range, usually 1/2" drive tQ-Wrench on a bike s stuff like calper bolts; axle bolts may need to be tight, but aren't usually that crtical; generator rotor-bolts, probably better off with an air impact wrech, or you just end up turning the crank; egine mounts? Like axle nuts; not that crtical; and even inside the engine, if you do a tear down, low-range wrench is far more likely to be far more use, come oil pump studs and the like; and even big end caps and cylinder head studs, are likely not that far out of the low-range, if at all.
BUT, discipline in use; payg attension to unts on the scale, and settg ft-lb not Kg-M!!! Zero-before store; NOT using it as a breaker bar; not sng it as a wratchet, savng it for settigs, and payng attension to tightening orders on a flange, and stage settng, doing ALL on a flange to the same settng on the wrench, before changng the setting; that sort of stuff, will make far ore difference than what you buy, whether cheapy or expensive....
But as said, 1/4" low range is likely most useful; 1/2" high-range, may have odd uses. 3/8".. is a neither or, and you'll probably be lucky to find one.
chrisdubya
PostPosted: 14:35 - 31 May 2017    Post subject: Reply with quote
+1. A mechanic once told me its all in the wrist and rule of thumb is if its 'FT' its fine.
Only issue is there's two types of FT - Finger Tight and Fucking Tight. Getting the righty tighty is the tricky part.
kgm
PostPosted: 15:04 - 31 May 2017    Post subject: Reply with quote
I have a couple and I find them useful. I mainly use them to prevent over torquing but if I feel it's getting tight enough before it clicks then I'll stop
notbike
PostPosted: 15:48 - 31 May 2017    Post subject: Reply with quote
I have one with low torque specs for stuff like brake calipers, and one for high torque specs like rear axle bolts. Halfords professional wrenches (cause my mates get me it on trade price which is sweeeeeeeet).
Anything for plastics or anything with an aluminium thread that isn't a major component should be hand tight and especially be careful with aluminium threads & steel bolts. I've stripped aluminium threads on my Ninja 300's yoke before by being a fucking idiot and tightening it down with tard strength. The funny thing is, I wasn't even trying to tighten it down too hard, just stop it from vibrating loose. Ended up having to pinch it down with a longer bolt and a nut on the other side.
Since then, I've learned that blue loctite helps when you need something a bit tighter than hand tight without actually having to tighten it down so hard. You can also use red if its meant to be stuck on there harder, which usually needs bigger tools to take it off again like a breaker bar.
For everything else, just put the numbers in properly as per your bike's owners manual and you'll have no problems, the engineers didn't put those numbers in there to fill up the word count.
Also couple other things, don't confuse Ft/lbs with Nm or you'll fuck something up, don't use the torque wrench as a breaker bar (to undo bolts), and remember to set the torque back to 0 when you're done or over time you can throw the calibration off and it'll be inaccurate and your wheel will come off and you will crash and get pregnant and die.
Bru
PostPosted: 18:56 - 31 May 2017    Post subject: Reply with quote
Hello.
For what it is worth, I recommend a 3/8-drive torque wrench like the one I bought from Halfords: 8 - 60 Nm. About 95% of the jobs I have done, required only that.
Certainly, it is valuable for M6 casing bolts (8 - 10 Nm), which are very easy to strip. The number I have had to helicoil (OK, just three) were all M6 bolts.
Also good for hydraulic 'banjo' bolts, as the sealing depends on the minimum force for consistent tightening (especially as replacement brake-hose kits seem to be stocked with very short bolts, which lose a couple of turns).
As mentioned earlier - the torque values are designed for good reason.
M.C
PostPosted: 20:27 - 31 May 2017    Post subject: Reply with quote
Stuff like sump plugs, spark plugs etc. you take care not to over-tighten, everything else just tighten up normally. With bodywork you can tell if you're over-tightening it.
TheSmiler
PostPosted: 20:47 - 31 May 2017    Post subject: Reply with quote
I've been using a torque wrench more and more recently it's handy on the k100 as there is a lot of aluminium on the bike. These threads can easily be stripped I know I've done it and had to helicoil. The 3/8ths came in more use when doing most of the bolts.
If you can afford it get both if not get the 3/8ths then the 1/2 for any larger bolts.
1198
PostPosted: 22:35 - 31 May 2017    Post subject: Reply with quote
Brake caliper bolts. Axle pinch bolts. Yoke pinch bolts. Banjo nuts. Sump plugs. Axles themselves. Sprocket mounting bolts (Front and rear). Just a few of my more recent uses for torque wrenches. I'd rate them as pretty much as essential as a tyre pressure gauge....
andym
PostPosted: 23:28 - 31 May 2017    Post subject: Reply with quote
Brake caliper bolts - nope
Axle pinch bolts - nope
Yoke pinch bolts - nope
Banjo nuts - nope
Sump plugs - nope
Axles - nope
Sprocket mounting bolts (front and rear) - nope
I've done all of those jobs and never once used a torque wrench.... and none of my bikes have fallen apart... yet.
Also very rarely use a tyre pressure gauge
Valerian95 This post is not being displayed because the poster is banned. Unhide this post / all posts.
sickpup
Old Timer
PostPosted: 10:51 - 01 Jun 2017    Post subject: Reply with quote
The cheap £30 machine mart one in this range is actually £39.59 On the other hand the Teng 1/4 is on Ebay for £44.25 and I recently got one for £34
See comments above
I agree a 25-250Nm torque wrench is next to useless on a motorcycle BUT torque wrenches aren't rated by the socket fitment size and the range of use can vary enormously.
I have 4 torque wrenches as follows
https://i945.photobucket.com/albums/ad297/750RK/Odds%20and%20ends/20170601_111717_1496313144525.jpg
Britool EVT 600A 1/2 10-50 lbfft 12-68Nm
Halfords 3/8 6-45 lbf.ft 8-60Nm
Teng 3892AG-3/8 E1 4-18lbs.ft 5-25Nm
Teng 1492AG-E 1/4 4-18lbs.ft 5-25Nm
So to say 3/8ths as you later do is neither here nor there is incorrect.
A 3/8ths is likely to be more useful than a 1/4 of the same size, most people would at least have a decent range of sockets in 3/8ths rather than a cheap set of 1/4 that someone got them for Christmas.
So when choosing a torque wrench the first thing to do is look at the range you need and then look at the drive sizes available.
PostPosted: 13:29 - 01 Jun 2017    Post subject: Reply with quote
Amazon? I got that too, the case is fucking massive Laughing
I picked this up too.
https://www.machinemart.co.uk/p/040215238/
I paid £35, figured it would be a catch all for anything bigger. I 'tested' it against my Dads Britool 30-120nm and they were close enough (<5% different)
colink98
PostPosted: 14:42 - 01 Jun 2017    Post subject: Reply with quote
everyone ever with a torque wrench (including me).
Always gives it a little nip after the wrench pops.
which is of course comical.
Ride it like you stole it.
sickpup
Old Timer
PostPosted: 14:57 - 01 Jun 2017    Post subject: Reply with quote
No we don't.
The last post was made 9 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 117.61 Kb
