| mrmistoffelee... |
 mrmistoffelee... Nova Slayer
| M.C |
 M.C Super Spammer
| Monkeywrenche... |
 Monkeywrenche... Nearly there...
| Monkeywrenche... |
| Nexus Icon |
 Nexus Icon World Chat Champion
| mrmistoffelee... |
| M.C |
 M.C Super Spammer
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 13:36 - 31 May 2017 Post subject: |
On a motorcycle, IF you need a torque wrench, it will likely be to avoid stripping threads on very LOW TORQUE screws and such in alloy castigs; not as on cars to wack up cylinder head studs to monster torques to keep them from blowing.
As such, MOST useful torque wrench for M/C mechanics will be a LOW RANGE, 0-25Nm sort of region, ad that will likely be on a smaller 1/4 drive rather than larger 3/8 or 1/4".
For the likely use, a 'cheap' £30ish example from Machine mart aught be more than good enough; provided you take care to look after it; and zero the scale after each use before storage; don't use it as a breaker bar and remember its a final setting tool, not a fancy ratchet; so use only for fnal setting after using an ordinary ratchet for doing stuff up 'fingy' tight, or getting old screws out to start with.
Most often, a Torque Wrench should be used only to avoid over tightening on delicate fasteners, or to ensure 'even' tightening across a flange like a primary drive case or such. It doesn't need to be ultra accurate; merely 'consistent' so on a flange all fasteners are within a couple of Nm of each other. So way you use it; stage setting, dong fasteners up around the clock, in sequence, keeping socket square to head, remembering to zero before store, and not use it as GP doey-upey ratcet, just as final setting tool, you dont have to have an ultra expensive one.
I bought a real cheap and nasty (high-range) one, when I was about 18, as didn't have a borrow in a hurry; Twenty years later, I won a rather fancy Teng one, with cal-cert and everything; Did a setting click-off on the pair to see how far off the old cheapo was, and you know what? it was within a couple of ft-lb throughout the range; more than good-enough; just through discipline of zeriong before store, and not using to (too often) as a fancy ratchet breaker bar, rather than a setting gauge!
But, as said, great for dong car cylinder head bolts, or disc brake mounting's; 25-250Nm torque-wrenches really aren't needed very often on a motorcycle; 1/4" drive 5-25Nm low range wench is far ore useful, far more often; ad that £30 Clarke fro Machne mart s an K example; get a couple of rails of 1/4" scokets to go with it, and keep just for the tQ-Wrench; £50 job-jobbed.
Only place you may want a high-range, usually 1/2" drive tQ-Wrench on a bike s stuff like calper bolts; axle bolts may need to be tight, but aren't usually that crtical; generator rotor-bolts, probably better off with an air impact wrech, or you just end up turning the crank; egine mounts? Like axle nuts; not that crtical; and even inside the engine, if you do a tear down, low-range wrench is far more likely to be far more use, come oil pump studs and the like; and even big end caps and cylinder head studs, are likely not that far out of the low-range, if at all.
BUT, discipline in use; payg attension to unts on the scale, and settg ft-lb not Kg-M!!! Zero-before store; NOT using it as a breaker bar; not sng it as a wratchet, savng it for settigs, and payng attension to tightening orders on a flange, and stage settng, doing ALL on a flange to the same settng on the wrench, before changng the setting; that sort of stuff, will make far ore difference than what you buy, whether cheapy or expensive....
But as said, 1/4" low range is likely most useful; 1/2" high-range, may have odd uses. 3/8".. is a neither or, and you'll probably be lucky to find one. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| chrisdubya |
 chrisdubya Scooby Slapper
| kgm |
 kgm World Chat Champion
| notbike |
 notbike World Chat Champion
 Posted: 15:48 - 31 May 2017 Post subject: |
I have one with low torque specs for stuff like brake calipers, and one for high torque specs like rear axle bolts. Halfords professional wrenches (cause my mates get me it on trade price which is sweeeeeeeet).
Anything for plastics or anything with an aluminium thread that isn't a major component should be hand tight and especially be careful with aluminium threads & steel bolts. I've stripped aluminium threads on my Ninja 300's yoke before by being a fucking idiot and tightening it down with tard strength. The funny thing is, I wasn't even trying to tighten it down too hard, just stop it from vibrating loose. Ended up having to pinch it down with a longer bolt and a nut on the other side.
Since then, I've learned that blue loctite helps when you need something a bit tighter than hand tight without actually having to tighten it down so hard. You can also use red if its meant to be stuck on there harder, which usually needs bigger tools to take it off again like a breaker bar.
For everything else, just put the numbers in properly as per your bike's owners manual and you'll have no problems, the engineers didn't put those numbers in there to fill up the word count.
Also couple other things, don't confuse Ft/lbs with Nm or you'll fuck something up, don't use the torque wrench as a breaker bar (to undo bolts), and remember to set the torque back to 0 when you're done or over time you can throw the calibration off and it'll be inaccurate and your wheel will come off and you will crash and get pregnant and die. |
| Bru |
 Bru Trackday Trickster
| M.C |
 M.C Super Spammer
| TheSmiler |
 TheSmiler World Chat Champion
 Posted: 20:47 - 31 May 2017 Post subject: |
I've been using a torque wrench more and more recently it's handy on the k100 as there is a lot of aluminium on the bike. These threads can easily be stripped I know I've done it and had to helicoil. The 3/8ths came in more use when doing most of the bolts.
If you can afford it get both if not get the 3/8ths then the 1/2 for any larger bolts. ____________________ CB125>CG125>GN125>ER5>K100RS>R1100RS>K100RS
A2 completed 23/07/15 Ready for the Golden Crisp Packet |
| 1198 |
 1198 World Chat Champion
| andym |
 andym World Chat Champion
| Valerian95 |
 Valerian95 Banned
| sickpup |
 sickpup Old Timer
 Posted: 10:51 - 01 Jun 2017 Post subject: |
| Teflon-Mike wrote: | As such, MOST useful torque wrench for M/C mechanics will be a LOW RANGE, 0-25Nm sort of region, ad that will likely be on a smaller 1/4 drive rather than larger 3/8 or 1/4".
For the likely use, a 'cheap' £30ish example from Machine mart aught be more than good enough; |
The cheap £30 machine mart one in this range is actually £39.59 On the other hand the Teng 1/4 is on Ebay for £44.25 and I recently got one for £34
| Teflon-Mike wrote: | I bought a real cheap and nasty (high-range) one, when I was about 18, as didn't have a borrow in a hurry; Twenty years later, I won a rather fancy Teng one, |
See comments above
| Teflon-Mike wrote: | But, as said, great for dong car cylinder head bolts, or disc brake mounting's; 25-250Nm torque-wrenches really aren't needed very often on a motorcycle; 1/4" drive 5-25Nm low range wench is far ore useful, far more often; ad that £30 Clarke fro Machne mart s an K example; get a couple of rails of 1/4" scokets to go with it, and keep just for the tQ-Wrench; £50 job-jobbed. |
I agree a 25-250Nm torque wrench is next to useless on a motorcycle BUT torque wrenches aren't rated by the socket fitment size and the range of use can vary enormously.
I have 4 torque wrenches as follows
https://i945.photobucket.com/albums/ad297/750RK/Odds%20and%20ends/20170601_111717_1496313144525.jpg
Britool EVT 600A 1/2 10-50 lbfft 12-68Nm
Halfords 3/8 6-45 lbf.ft 8-60Nm
Teng 3892AG-3/8 E1 4-18lbs.ft 5-25Nm
Teng 1492AG-E 1/4 4-18lbs.ft 5-25Nm
So to say 3/8ths as you later do is neither here nor there is incorrect.
A 3/8ths is likely to be more useful than a 1/4 of the same size, most people would at least have a decent range of sockets in 3/8ths rather than a cheap set of 1/4 that someone got them for Christmas.
So when choosing a torque wrench the first thing to do is look at the range you need and then look at the drive sizes available. |
| chris-red |
| colink98 |
 colink98 Could Be A Chat Bot
| sickpup |
 sickpup Old Timer
The last post was made 9 years, 167 days ago. Instead of replying here, would creating a new thread be more useful? |
