| T1Cybernetic |
 T1Cybernetic Nitrous Nuisance
 Posted: 18:59 - 01 Jun 2017 Post subject: Brake disk bolts (Stuck) Broken drill bit stuck inside. |
My rear brake disk bolts are stuck fast, I tried all sorts to free them but nothing helped so in the end I started to drill them out (Carefully)
Two came out no problem But I've broken the drill bit inside one of the bloody bolts So I called it a day for now.
I do possess a Dremel so I'm going to grind or drill out the little buggers but I'm not sure which bit/s I need to drill or grind it out with? Or where to order the correct parts from? ____________________ Signature removed by popular demand... |
| redeem ouzzer |
 Posted: 09:19 - 02 Jun 2017 Post subject: |
A wheel on ebay will probably set you back in the region of £50.
Compare that to the cost of having a hardened steel drill bit removed and a thread insert fitted. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| chris-red |
 Posted: 09:39 - 02 Jun 2017 Post subject: |
In future, buy this...
https://www.amazon.co.uk/Tx-Star-Spline-Mechanics-Piece-Draper/dp/B00K1FB5XU/ref=sr_1_12?ie=UTF8&qid=1496395833&sr=8-12&keywords=draper+expert
Select the spline tool that is slightly bigger than the allen hole. Place it Over the hole and hammer the cunt out of it so it bites into the sides of the hole. Put a socket on it and whilst pushing down hard unscrew it.
This has never failed for me.
Obviously you can't do that now. I would suggest using a dremel or file or hacksaw cut 2 flats off of the side of the bolt and use a spanner to undo it.
It is worth hammering the buggery out of it before you try undoing it to break a lock on it. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| DRZ4Hunned |
 DRZ4Hunned World Chat Champion
 Posted: 09:48 - 02 Jun 2017 Post subject: |
If it's a standard HSS bit, I'd imagine a carbide bit will get the fekker out.  ____________________ DRZ400-SM
FZS600 |
| Polarbear |
 Polarbear Super Spammer
| iansoady |
 iansoady Borekit Bruiser
| T1Cybernetic |
 Posted: 15:12 - 03 Jun 2017 Post subject: |
Luckily these bolts are stuck on the old wheel I bought myself a replacement wheel + disk not so long ago, You guessed it. £50 with brake disk and spare bolts (Not attached)
The hss drill bit is snapped and stuck pretty deep After a bit of research it seems a carbide or the more expensive diamond bit should get rid of the stuck hss bit and bolt!
And yep you guessed right again, The bolts look like they are stuck with some thread lock and a bit of old fashioned corrosion.
To be fair I saved this old wheel with the stuck bolts just to see if I can get them out when I have a bit of spare time. I did originally do all the regular stuff like heating them up and even using a hammer and also tried some larger tools but the heads of the bolts that are left have totally chewed up and then snapped off so I resorted to drilling which went well on a couple of them until the bit snapped off  ____________________ Signature removed by popular demand... |
| T1Cybernetic |
 Posted: 15:33 - 03 Jun 2017 Post subject: |
Don't waste your time on the carbide. It would require the wheel being clamped down on a machine and drilled with a rigid setup. Carbide is hard but not tough and needs constant controlled in-feed to stop the edge deteriorating.
Next time you're considering drilling brake disk bolts, weld a big nut to the head. The heat will break down the threadlock and release the corrosion bond. ____________________ a.k.a 'Geri'
| iansoady |
| mkjackary |
 mkjackary Nitrous Nuisance
| raesewell |
 raesewell Traffic Copper
| Raffles |
 Raffles World Chat Champion
 Posted: 23:13 - 04 Jun 2017 Post subject: |
Solder melts at under 200 degrees but threadlock typically needs 300+ ____________________ a.k.a 'Geri'
| kramdra |
 kramdra World Chat Champion
 Posted: 23:37 - 04 Jun 2017 Post subject: |
Pics are needed. M6 bolts? how deep did you drill?
Snapped drills can almost always be removed knocking them with a punch and pliers as it will only be stuck at the tip. Very diffierent to a broken tap, drills are easy. That said I have not snapped many.
Id chose a carbide burr rather than drill for removing hss. However you have failed at drilling probably best you dont try.
If its an alu wheel you can use alum to slowly dissolve the steel. It wont touch alu. AvE had a video showing this. Grind the head off to remove the disc first.
www.youtube.com/watch?v=fqZYgReuywM&t |
| DRZ4Hunned |
 Posted: 09:40 - 05 Jun 2017 Post subject: |
I disagree about requiring a drill press for carbide bits, I've just drilled a hardened output shaft with a 12v hand drill...
People said it wouldn't work, but it did... ____________________ DRZ400-SM
FZS600 |
| Monkeywrenche... |
 Monkeywrenche... Nearly there...
| DRZ4Hunned |
 ........ Borekit Bruiser
The last post was made 8 years, 265 days ago. Instead of replying here, would creating a new thread be more useful? |
