Brake disk bolts (Stuck) Broken drill bit stuck inside.
T1Cybernetic
PostPosted: 18:59 - 01 Jun 2017    Post subject: Brake disk bolts (Stuck) Broken drill bit stuck inside. Reply with quote
My rear brake disk bolts are stuck fast, I tried all sorts to free them but nothing helped so in the end I started to drill them out (Carefully)
Two came out no problem Wink But I've broken the drill bit inside one of the bloody bolts Sad So I called it a day for now.
I do possess a Dremel so I'm going to grind or drill out the little buggers but I'm not sure which bit/s I need to drill or grind it out with? Or where to order the correct parts from?
Signature removed by popular demand...
redeem ouzzer
PostPosted: 19:17 - 01 Jun 2017    Post subject: Reply with quote
If you've snapped a drill bit inside a bolt, you're fucked son.
Best find a workshop with a spark eroder.
Be a REAL MAN!
PostPosted: 09:19 - 02 Jun 2017    Post subject: Reply with quote
A wheel on ebay will probably set you back in the region of £50.
Compare that to the cost of having a hardened steel drill bit removed and a thread insert fitted.
PostPosted: 09:39 - 02 Jun 2017    Post subject: Reply with quote
In future, buy this...
https://www.amazon.co.uk/Tx-Star-Spline-Mechanics-Piece-Draper/dp/B00K1FB5XU/ref=sr_1_12?ie=UTF8&qid=1496395833&sr=8-12&keywords=draper+expert
Select the spline tool that is slightly bigger than the allen hole. Place it Over the hole and hammer the cunt out of it so it bites into the sides of the hole. Put a socket on it and whilst pushing down hard unscrew it.
This has never failed for me.
Obviously you can't do that now. I would suggest using a dremel or file or hacksaw cut 2 flats off of the side of the bolt and use a spanner to undo it.
It is worth hammering the buggery out of it before you try undoing it to break a lock on it.
DRZ4Hunned
PostPosted: 09:48 - 02 Jun 2017    Post subject: Reply with quote
If it's a standard HSS bit, I'd imagine a carbide bit will get the fekker out. Thumbs Up
DRZ400-SM
FZS600
PostPosted: 14:27 - 02 Jun 2017    Post subject: Reply with quote
No it won't. I will keep slipping off centre and fuck the wheel.
Triumph Trophy Launch Edition
iansoady
PostPosted: 09:40 - 03 Jun 2017    Post subject: Reply with quote
It depends how far down it's broken. If it's below the level of the head then you might be able to use bigger drills to remove the head of that one. Then remove the others properly using the torx bit as suggested.
That should let you get the disc off and you should be able to remove the remains of the offending bolt with mole grips.
They will probably have been fitted with loctite so get them nice & hot before trying to remove them.
Ian
1986 Honda XBR500
1952 Norton ES2
T1Cybernetic
PostPosted: 15:12 - 03 Jun 2017    Post subject: Reply with quote
Luckily these bolts are stuck on the old wheel Wink I bought myself a replacement wheel + disk not so long ago, You guessed it. £50 with brake disk and spare bolts (Not attached)
The hss drill bit is snapped and stuck pretty deep Sad After a bit of research it seems a carbide or the more expensive diamond bit should get rid of the stuck hss bit and bolt!
And yep you guessed right again, The bolts look like they are stuck with some thread lock and a bit of old fashioned corrosion.
To be fair I saved this old wheel with the stuck bolts just to see if I can get them out when I have a bit of spare time. I did originally do all the regular stuff like heating them up and even using a hammer Very Happy and also tried some larger tools but the heads of the bolts that are left have totally chewed up and then snapped off so I resorted to drilling which went well on a couple of them until the bit snapped off Sad
T1Cybernetic
PostPosted: 15:15 - 03 Jun 2017    Post subject: Reply with quote
Forgot to ask, Can you point me in the right direction to some Carbide bits that will do the job? There a few different types and I don't know which ones to get.
With a Carbide bit, Is it a case of drilling through the old broken drill bit and bolt or grinding it out?
PostPosted: 15:33 - 03 Jun 2017    Post subject: Reply with quote
Don't waste your time on the carbide. It would require the wheel being clamped down on a machine and drilled with a rigid setup. Carbide is hard but not tough and needs constant controlled in-feed to stop the edge deteriorating.
Next time you're considering drilling brake disk bolts, weld a big nut to the head. The heat will break down the threadlock and release the corrosion bond.
iansoady
PostPosted: 10:33 - 04 Jun 2017    Post subject: Reply with quote
Assuming the disc is scrap, you could possibly cut through the head of the bolt(s) with an angle grinder (depending on the exact layout) leaving the stubs to be removed with mole grips etc after heating.
Quite often, once the clamping force is removed, bolts / studs come out quite easily.
Ian
1986 Honda XBR500
1952 Norton ES2
mkjackary
PostPosted: 10:59 - 04 Jun 2017    Post subject: Reply with quote
You say you have tried heating it up, did you try with a soldering iron? If not, chuck one on the bolt or the screw for a bit (will probably take a while to heat the whole thing up) might make it expand enough to crack the corrosion seal, and maybe enough to crack/loosen the drill bit.
raesewell
PostPosted: 12:36 - 04 Jun 2017    Post subject: Reply with quote
I think you may want Cobalt bits not Carbide.
Yamaha FJR 1300 Normanton West Yorkshire
Raffles
PostPosted: 21:56 - 04 Jun 2017    Post subject: Reply with quote
Is there a particular brand of soldering iron that you could recommend and would a flux be required?
PostPosted: 23:13 - 04 Jun 2017    Post subject: Reply with quote
Solder melts at under 200 degrees but threadlock typically needs 300+
kramdra
PostPosted: 23:37 - 04 Jun 2017    Post subject: Reply with quote
Pics are needed. M6 bolts? how deep did you drill?
Snapped drills can almost always be removed knocking them with a punch and pliers as it will only be stuck at the tip. Very diffierent to a broken tap, drills are easy. That said I have not snapped many.
Id chose a carbide burr rather than drill for removing hss. However you have failed at drilling probably best you dont try.
If its an alu wheel you can use alum to slowly dissolve the steel. It wont touch alu. AvE had a video showing this. Grind the head off to remove the disc first.
www.youtube.com/watch?v=fqZYgReuywM&t
DRZ4Hunned
PostPosted: 09:40 - 05 Jun 2017    Post subject: Reply with quote
I disagree about requiring a drill press for carbide bits, I've just drilled a hardened output shaft with a 12v hand drill... Laughing
People said it wouldn't work, but it did...
DRZ400-SM
FZS600
Monkeywrenche...
PostPosted: 10:19 - 05 Jun 2017    Post subject: Reply with quote
But have you ever drilled out a bolt with a snapped Drill in it?
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
DRZ4Hunned
PostPosted: 10:25 - 05 Jun 2017    Post subject: Reply with quote
No, but couldn't you just punch a hole in the snapped bit to ensure the carbide bit won't 'walk'? If it can drill a hardened shaft, which is harder than a HSS bit, it shouldn't be an issue. Must be worth a try for the sake of a £2.50 bit.
DRZ400-SM
FZS600
PostPosted: 10:46 - 05 Jun 2017    Post subject: Reply with quote
I've drilled many, many HSS jobber drills with cobalt drill bits. Ideally you would want to do this in a drill press or mill but it certainly isn't necessary.
If you can get in there with a small abrasive wheel or similar to flatten off the top of the broken drill bit it will make your life a lot easier. A good cordless drill isn't a bad tool to use with a cobalt bit as they turn nice and slow and have reasonable speed control. The down side is the chucks aren't very accurate so your (fairly expensive) cobalt bits aren't going to last very long. Usually you're only likely to be doing this to 'save the day' however so a few quid on drill bits is acceptable.
PostPosted: 18:08 - 05 Jun 2017    Post subject: Reply with quote
Soldering iron might well manage a lot more easily (my temperature controlled one goes up to 450 degrees), but the amount of heat is limited. My big soldering iron is 80W, which is fairly hefty for a soldering iron but pathetic to heat up a lump of metal the size of a wheel.
Katy
PostPosted: 18:52 - 05 Jun 2017    Post subject: Reply with quote
Output shafts are not full-hard like drills bits and easi-outs or they would explode in use and since they are turned they'll have a nice countersink in the end for easy starting.
You did well but not at all like over-drilling a busted drill, in a thin bolt, in an alloy thread.
The last post was made 8 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 118.36 Kb
