| karoshi |
 karoshi Brolly Dolly
 Posted: 16:01 - 08 Jun 2017 Post subject: Voltmeter options |
Looking for a voltmeter, needs to be 3-wire so I can have it only on with the ignition.. suitable for handlebar mounting onto a bike with no fairings.
I'm struggling to find anything that would be small enough (and waterproof enough) to stick on either a bar mount, or be glued to the upper yoke.
Front running option is this one at the moment but it's a month away in China.
Anyone know of anything I could get more local?  ____________________ Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd |
| Copycat73 |
 Copycat73 World Chat Champion
| Tracer1234 |
 Tracer1234 World Chat Champion
 Posted: 16:25 - 08 Jun 2017 Post subject: |
Stupid, naive question, what would be the purpose of this?
Not a dig, a genuine curiosity about what would be the purpose.
 ____________________ Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15 |
| karoshi |
| Copycat73 |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| Shinigami |
 Shinigami World Chat Champion
 Posted: 17:10 - 08 Jun 2017 Post subject: |
i use one of these cheap ones from ebay wired to a push button switch (can see it at the bottom)
https://i.imgur.com/B32NxiH.jpg ____________________ Current: Honda City Fly CLR125 2003 Honda CB600F Hornet 2008 Yamaha FZ6 S2 + 1991 Kawasaki GPZ500
"Once you realize what a joke everything is, being the Comedian is the only thing that makes sense. |
| Radiotwo |
 Radiotwo Derestricted Danger
 Posted: 17:49 - 08 Jun 2017 Post subject: Re: Voltmeter options |
| karoshi wrote: | Looking for a voltmeter, needs to be 3-wire so I can have it only on with the ignition.. suitable for handlebar mounting onto a bike with no fairings.
Anyone know of anything I could get more local?  |
I see you say you need a three wire version, Why ? you only need two (+&-)
but if you want a on going check of the system you would be better with a ammeter, which would show a discharge, charge(and how much) and when everything is ok it will just show nothing, and also will show if there is a short etc. |
| Pigeon |
 Pigeon World Chat Champion
| WD Forte |
 WD Forte World Chat Champion
| stinkwheel |
 Posted: 23:20 - 08 Jun 2017 Post subject: |
I have a cheap shit 2-wire one on my VFR because ti suffers intermittant charging issues (which I have now narrowed down to heat sinking problems and fixed).
I just attached it to a switched live. Only comes on with the ignition. The absolute voltage is unimportant. It's changes you need to watch for. Mine reads 13.8v consistantly while running with the lights on. Any lower and it means I left the heated grips on or something is wrong.
As said, an analogue ammeter is better than a voltmeter for monitoring battery charging. The enfield has one, and you know for sure if it is charging or discharging.
I just used one of these (from this seller, different LED colour). Fitted it into the removable fuse cover and potted over the back of it with epoxy resin (araldite) to keep it waterproof. I attached it with flying wires and spade terminals which alows me to unbolt it and use it to fix other peoples bikes while out on runs. It's been more useful for other peoples bikes than my own.
Bottom right:
https://i48.photobucket.com/albums/f216/stinkwheel/drumbrake/CIMG1686_zps2e9b0a95.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| karoshi |
| stinkwheel |
| G |
 G The Voice of Reason
| WD Forte |
 Posted: 12:29 - 09 Jun 2017 Post subject: |
I just connect mine to a live feed so it comes on when the bike is switched on.
I routinely test and check it with a meter and any voltage drop
from the battery to the point I patch in to is insignificant.
I made a simple weather proof gauge set for the old thing using a car temp gauge that is very accurate compared to the original one.
An expanded scale meter with 7 leds showing from about 11.5V to 17V with the sweet spot in the middle around 14.2V is all i need.
This is enough to show trends and if the voltage is going out of bounds
the bottom row has
2 yellow 3 green 2 red.leds
A glance tells me if all is well
yellow or red is cause for concern, centre green is optimal
https://imgur.com/nxFzTKy.jpg ____________________ bikers smell of wee |
| stinkwheel |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| ADSrox0r |
 ADSrox0r World Chat Champion
| stinkwheel |
The last post was made 8 years, 241 days ago. Instead of replying here, would creating a new thread be more useful? |
