Fastening soft luggage plastic securing rings to bike
Paul2129
PostPosted: 16:28 - 08 Jun 2017    Post subject: Fastening soft luggage plastic securing rings to bike Reply with quote
Hi guys, I just bought an Oxford X40 tail pack for my CRF250. It came with a variety of straps and bungees, all of which seem unusable to attatch it to my tubular rear rack. I simply need to fasten the plastic securing rings around the bottom of the bag to the rack that it's sat on. The rings line up with the rack, so it's just a case of tying the two to each other, going around the tube of the rack, and through the securing ring.
I could use cable ties (maybe removable ones) but they rubbed the paint off the rack on my previous bike
Just wondered if anyone had a neat and elegant solution for this ?
There are some small Velcro straps, kind of like a mini buckle, that loop around, feed through the buckle and fasten back to the Velcro
Just wondered if anyone has any ingenious ideas ?
Many Thanks
Tracer1234
PostPosted: 16:29 - 08 Jun 2017    Post subject: Re: Fastening soft luggage plastic securing rings to bike Reply with quote
Many Thanks
Pictures may help Smile
Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
Paul2129
PostPosted: 16:42 - 08 Jun 2017    Post subject: Reply with quote
Thanks for your reply. Unable to add a photo, it won't upload but.... it's pretty straightforward. I removable cable tie is strong, just wondered if anyone had a better solution
Many thanks
Tracer1234
PostPosted: 16:44 - 08 Jun 2017    Post subject: Reply with quote
Paul2129 wrote:
Thanks for your reply. I've just taken a photo.... it's pretty straightforward. I removable cable tie is strong, just wondered if anyone had a better solution
Many thanks
As in, pictures of the attachments / seat that you are trying to attack it to may help suggest solutions.
Paul2129
PostPosted: 16:47 - 08 Jun 2017    Post subject: Reply with quote
Struggling like mad to attach a photo using my iPad. I'll try again on my PC later.... but it's a small plastic ring, connected to the tube
Kawasaki Jimbo
PostPosted: 17:02 - 08 Jun 2017    Post subject: Reply with quote
File too big, perhaps. Try an app called Cram.
kgm
PostPosted: 17:14 - 08 Jun 2017    Post subject: Reply with quote
I know what you mean - I have a similar tail pack but mine just sits on the rear seat rather than a rack so bungees work for me, although I understand the issue. .
Id probably go with the velcro strap idea. More flex for things bouncing about and less likely to fail than a cable tie. Another option is to use elasticated straps so that they run through two of the plastic D-rings and around the rack as a whole (weave it if possible for more purchase). Basically like you would with the strap if there's one on the bottom of the pack.
As for rubbing paint - most things will rub. You can protect the paint with electrical tape or using some of that grippy stuff (Google for Oxford Blanket to see what I mean). The Oxford stuff (or cheaper equivalent) is good for protecting paintwork from lots of things.
Paul2129
PostPosted: 17:28 - 08 Jun 2017    Post subject: Reply with quote
That's a great idea for using one strap and going right under the bag through both rings, for that I can possibly even use a strap that came with the bag, it's nylon and had d-rings like a helmet. Good thinking Smile
I'll try the app called Cram too, thank you
Paul2129
PostPosted: 17:32 - 08 Jun 2017    Post subject: Reply with quote
(Cram works !!) thanks
chickenstrip
PostPosted: 19:17 - 08 Jun 2017    Post subject: Reply with quote
I use some straps with double-D rings. Secure enough. Came with some old Oxford luggage I no longer use, and were about the only useful thing from them Rolling Eyes
Fizzer Thou
PostPosted: 20:11 - 08 Jun 2017    Post subject: Reply with quote
I used a rubber mat sold by Oxford/Halfrauds to cover the pillion seat and tail unit to go under the tail pack when I rode around France the other year.
I drilled out the tips of the pillion footpegs so that I could attach a pair of bungee hooks and made sure that the mat covered the bodywork from the rear bungee cord going to the rear indicators. I then used a bungee web around the lot so that it would hold the bike cover between me and the soft luggage.Worked a treat,even at highly illegal speeds Very Happy Thumbs Up
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Biking%20Abroad/Picture016_zpsef556bfb.jpg
Always have a 'Plan B'
chickenstrip
PostPosted: 21:50 - 08 Jun 2017    Post subject: Reply with quote
I gave up on bungees. They don't hold things as securely as straps, I've found. I sometimes still carry a cargo net, useful to stuff things under, but damned if I can find good quality ones anymore Sad
That Oxford "Blanket" stuff I use in exactly the same way, with a bit under the tank bag too.
The last post was made 9 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 78.99 Kb
