trying to work out what this pipe is
dcoffman
PostPosted: 06:39 - 15 Jun 2017    Post subject: trying to work out what this pipe is Reply with quote
i have been looking at a 125cc motorcycle its a 2008 cruiser problem is i had a 2000 motoroma which had a metal pipe running from the engine just next to the exhaust connection this pipe tilted forward and ran up the front of the bike not sure where it went now this 2008 cruiser has the same metal pipe problem is this 1 is snapped off the pipe goes nowhere i need to know what that pipe was and where should it go????
i am sure i have seen the same sort of pipe system on newer bikes but instead of metal they are rubber running from roughly the same location.
will attach a picture of the pipe in question
kgm
PostPosted: 07:04 - 15 Jun 2017    Post subject: Reply with quote
What is the model name?
dcoffman
PostPosted: 07:15 - 15 Jun 2017    Post subject: not sure Reply with quote
i didnt take much notice so the model not sure kind of took a step back after i saw a snapped tube, didnt want to go any further without investigating i have googled 125s and came accross multiple for instance the lexmoto arrow has the same tubes but in this case its rubber like most newer bikes
https://www.lexmoto.co.uk/gallery/HT125-4F/600/17.jpg
https://www.lexmoto.co.uk/HT125-4F.php
dcoffman
PostPosted: 07:17 - 15 Jun 2017    Post subject: i think its some sort of breather Reply with quote
imagine a snorkle it has the pipe that comes from ur mouth ur side of ur face so in this case a metal pipe that runs from top of engine into the tank and connects to the air valves at top of fuel tank not to sure of this tho
dcoffman
PostPosted: 07:21 - 15 Jun 2017    Post subject: found another picture Reply with quote
another picture of an 125 engine see the 3 dots above the sparky left and right are screw holes middle is where the pipe/tube runs from
https://legacy.chinesemotorcyclepartsonline.co.uk/images/largeimages/120600043-2.jpg
kgm
PostPosted: 07:30 - 15 Jun 2017    Post subject: Reply with quote
It should probably lead to the EGR valve - an emissions device that recirculates some of the exhaust gases back into the engine to reduce nitrogen oxide emissions. That's what you see at the end of the pipe on the Lexmoto photos you posted.
It's possible the previous owner has tried to remove the EGR valve in an attempt to improve performance but if that's the case it should really be blanked off rather than just having the pipe chopped. They're not expensive on most chinese bikes if it's missing but if it was a tuning attempt I'd be wondering what else had been done.
dcoffman
PostPosted: 07:35 - 15 Jun 2017    Post subject: cheers Reply with quote
thanks mate well that answered my question not worth the risk in my eyes because i am now wondering what else has been messed with think i will look elsewhere thanks pal Very Happy
PostPosted: 07:52 - 15 Jun 2017    Post subject: Re: cheers Reply with quote
Japanese. Not Chinese. Point your eyes that way.
NJD
PostPosted: 09:09 - 15 Jun 2017    Post subject: Reply with quote
Just for visual reference as to what would have been (or along the lines of):
https://s8.postimg.org/sxk7m5ghh/image.jpg
PostPosted: 10:38 - 15 Jun 2017    Post subject: Reply with quote
My GF has a Derbi Cross City 125 with the same engine... No idea where the pipe goes, but as said it's probably some emissions thing.
The last post was made 9 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 63.14 Kb
