Hot Oil On Tyre
Fin
PostPosted: 21:39 - 02 Jul 2017    Post subject: Hot Oil On Tyre Reply with quote
TL:DR - Could an oil leak from the sump cause a rear tyre to wear fast? (xj600)
A few months ago I got a puncture and was about 1 mile from a petrol station/shop. I rode there flat and bought some tyre foam stuff which did me fine to work and back.
I noticed when I got to the shop that the tread in the centre of my tyre had worn quite a bit. A few weeks ago I noticed that the tread line in the centre had gone although I had loads on the sides. My Oil was also low as I have a slow oil leak from where the sump isn't flush. Today while parked up my brother pointed at my tyre which was worn down to the canvas. It seems weird to me how it's suddenly worn down so much.
Here is the bike when I bought it just under 2000 miles ago
https://i.imgur.com/CyZtZUO.jpg
Right now
https://i.imgur.com/iuNHRBU.png
sickpup
Old Timer
PostPosted: 21:46 - 02 Jul 2017    Post subject: Reply with quote
The first picture looks like the tyre is overinflated and worn in the centre. Did you seriously not notice your tyre was worn out before it got to the canvas?
PostPosted: 21:51 - 02 Jul 2017    Post subject: Reply with quote
Considering that's had 2000miles on it suggests you don't often corner. Razz
Premature wear could also be down to incorrect pressure.
Oil does have the ability to break down rubber but tyres are not all rubber.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:53 - 02 Jul 2017    Post subject: Reply with quote
This ^. There's ignorance, and there's criminal incompentance. You've strayed badly into the latter with that tyre.
Triumph Sprint ST 1050
MCN
PostPosted: 22:10 - 02 Jul 2017    Post subject: Reply with quote
Yes, oil on the tyre will allow it to wear faster as any lubricant on a tyre will accelerate wear. Even rain. Smile
Yes, you are now in the uppers of the tyre and should be ban-hammered off the forum.
But in mitigation, you presented with fine digital images so a ban may not be required in this instance.
And yes, you never corner. Shocked
sickpup
Old Timer
PostPosted: 22:17 - 02 Jul 2017    Post subject: Reply with quote
Most manufacturers say rain slows wear as it cools the tyre.
Stalk
PostPosted: 22:28 - 02 Jul 2017    Post subject: Reply with quote
So, if its raining, less grip therefore less friction. So less wear. Oil may perish rubber after prolonged exposure, but won't cause it to wear. Riding a bike for 2000 miles in a straight line on partworns will wear a tyre.
Just my thoughts on the subject.
You can all decide if it sounds realistic.
Fin
PostPosted: 22:40 - 02 Jul 2017    Post subject: Reply with quote
So most likely a new tyre and I'll be all good?
does that mean I wont have to fix my leaky sump? I've tried a new gasket and am now using instant gasket stuff which seems to be the best so far. It's a pain to undo all the bolts, clean and apply etc. Issue seems to be a somewhat warped or uneven sump I bought to replace my old one with the stripped thread.
I've bought a Conti Trail attack which is supposed to be quite hard wearing. I always thought oil would make the tyre wear less like chafing when no lube on privates Wink I guess it depends on the temperature of the oil, a bit like the cold rain helping tyres last longer.
155mph
PostPosted: 22:56 - 02 Jul 2017    Post subject: Reply with quote
Fix leak.
sickpup
Old Timer
PostPosted: 23:02 - 02 Jul 2017    Post subject: Reply with quote
What it means is that you have no place giving others advice in the workshop. Please stop,
Tracer1234
PostPosted: 01:09 - 03 Jul 2017    Post subject: Re: Hot Oil On Tyre Reply with quote
Right now
Question. Did you ride your bike, knowing that your tyre looked that worn?
Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
Fin
PostPosted: 06:34 - 03 Jul 2017    Post subject: Re: Hot Oil On Tyre Reply with quote
Yeah I rode it about 20 miles home, the picture is when I got home, it wasn't as bad when my brother noticed it.
PostPosted: 09:42 - 03 Jul 2017    Post subject: Reply with quote
I've had a tyre go from just above the wear bars to having canvas showing in 2 hours.
They can go quickly when they go.
PostPosted: 11:10 - 03 Jul 2017    Post subject: Reply with quote
I bet you weren't bimbling to work when that happened though.
fatjames
PostPosted: 11:30 - 03 Jul 2017    Post subject: Re: Hot Oil On Tyre Reply with quote
20 mile upright doughnut?
But seriously, man, wtf?? With shit like this and chav who only know how to rev, it's no wonder biker's get such a bad name.
Just look at your tyres before you ride, that tyre is OBVIOUSLY not safe to ride on.
inb4 - I have no brake pads, is this due to the exhaust getting hot?
redeem ouzzer
PostPosted: 11:32 - 03 Jul 2017    Post subject: Reply with quote
OP is too stupid to live in this fucking world.
Be a REAL MAN!
Fin
PostPosted: 17:58 - 03 Jul 2017    Post subject: Reply with quote
Help me out daddy Dan, could the oil leak cause the tyres to wear faster?
You'll also be glad to know I may have put about 50psi in before the 70 odd mile ride, just because I think the gauge on the pump is out. I also hit over 100 on the ride home (on my 1 mile drive of course).
Enduro Numpty
PostPosted: 21:14 - 03 Jul 2017    Post subject: Reply with quote
Last year I got a puncture on a well worn tyre. It deflated slowly and it took a while for me to suss there was a problem. Running the tyre on ever decreasing pressures accelerated the wear to the point that when I finally decided there was a problem, what tread I had, was all but gone. If the pressure is too low the tyre generates too much heat and the rubber just wears at a crazy rate.
As for oil on the tyre - do you really have to ask? Excessive wear should be the least of your worries.
sickpup
Old Timer
PostPosted: 22:41 - 03 Jul 2017    Post subject: Reply with quote
You didn't do 2000 miles in those 2 hours did you?
sickpup
Old Timer
PostPosted: 22:44 - 03 Jul 2017    Post subject: Reply with quote
So massive wear in the centre, over inflate tyre so wear is concentrated in centre. Rolling Eyes
MCN
PostPosted: 23:07 - 03 Jul 2017    Post subject: Reply with quote
Agree, rain cools the tyre so helps maintain stable pressures and prevents high temperatures softening the walls which are then easily damaged.
On desert roads, high speed and high temperature (Numb-Nut Steerers driving the vehicles) just fcuked tyres. Brand new tyres came back after maybe two trips (1000km) tread perfect but walls like puff pastry.
The lubricant oil or water or whatever accelerates wear as it make the rubber easier to cut. The road surface slices at the tyre as it rolls, slides and grips. Any lubricant will assist the slicing of tiny bits of tyre.
The easiest way to cut rubber is with a wetted knife.
We budgeted for more tyre wear in mining trucks during wet season. Tyres only lasted half as long on wet haul roads than on dry dusty roads.
MCN
PostPosted: 23:11 - 03 Jul 2017    Post subject: Reply with quote
You will get great fun out of the trail attack but it wont last long. They have a very soft grippy compound. I got 7k miles out of Metzeler Tourance on my R1200GS but only 3.5k miles on the Conti.
It was fun but not for long.
Fix the sump you ham-fisted lazy sod. Think of the environment... Sad
What about a double gasket? (and gloop)
Tracer1234
PostPosted: 00:08 - 04 Jul 2017    Post subject: Reply with quote
Top of your to do list is: fix leak!
kramdra
PostPosted: 13:27 - 04 Jul 2017    Post subject: Reply with quote
Replace shit tire. Recommend pilot road 4's or metlezer roadtec 01 as they do not give a shit about oil.
My garage floor is excessivly oiled from excess chain lube. Makes no difference to grip or life.
Tracer1234
PostPosted: 14:43 - 04 Jul 2017    Post subject: Reply with quote
However, Extra tyre wear or not, riding along with the sump leaking in front of the rear tyre does not sound like a smart move.
The last post was made 9 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 134.29 Kb
