Bandit blocked drain?
mudcow007
PostPosted: 21:33 - 11 Jul 2017    Post subject: Bandit blocked drain? Reply with quote
For ages ive been trying to figure out why my Bandit runs like a bag of spanner if it gets a tad bit moist
I think i figured it, after checking the wiring as best i could, i pulled the caps out, leaving the plugs in and poked a bit of wire in all the drain holes which all seemed clear.
I then squirted a bit of water down the plug holes, all but one drained as it should.
For the life of me, i cant get the other to unblock.
Any ideas??
Tariq_S
PostPosted: 15:23 - 12 Jul 2017    Post subject: Reply with quote
Squirt quite a bit of DW40 in the hole as well as in the spark plug hole. should help with the cleaning.
Poke a wire through from the headers side, try some garden plant wire as it should be thin enough to go through.
MCN
PostPosted: 18:54 - 12 Jul 2017    Post subject: Reply with quote
Brake or Clutch Cable will be flexible enough to go down or up the hole too.
Pedal Bikes use thinner gauge cable.
RhynoCZ
PostPosted: 19:02 - 12 Jul 2017    Post subject: Reply with quote
I use the string from a mower. A steel cable could damage something.
If it's a straight passage, just use a long nail. Thumbs Up
mudcow007
PostPosted: 09:10 - 13 Jul 2017    Post subject: Reply with quote
Still blocked grr
tried a straightened big paper clip, it hits something an goes no further.
Tried a copper rod which was thinner than the paperclip an nothing
road bike (pedal) gear cable....nowt
anyone any ideas?
i cant get anything thin enough into the hole, but strong enough to give it a clout
Quote Me Happy
PostPosted: 09:24 - 13 Jul 2017    Post subject: Reply with quote
Any room to get a compressor airline in there?
RhynoCZ
PostPosted: 09:45 - 13 Jul 2017    Post subject: Reply with quote
A pipe cleaner, perhaps?
https://images-na.ssl-images-amazon.com/images/I/91m8soF%2BTaL._SX355_.jpg
ADSrox0r
PostPosted: 10:09 - 13 Jul 2017    Post subject: Reply with quote
If you haven't got a compressor then pick up a can of compressed air from the pound shop, give it a blast through.
RhynoCZ
PostPosted: 10:32 - 13 Jul 2017    Post subject: Reply with quote
If the passage is straight, use a small drill bit, and drill the dirt out. Use the smallest drill bit possible, go slow, low revs. IF that won't help, then I don't know what could. Thinking
Tankie
PostPosted: 10:35 - 13 Jul 2017    Post subject: Reply with quote
+1 drill it with a long series bit
mudcow007
PostPosted: 14:21 - 13 Jul 2017    Post subject: Reply with quote
didnt think of compressed air, will have a go tonight.
I will see if i can get anything into the drain from the plug side tonight, be a tight squeeze with the plug still in the hole though.
next step i think is to them attack it with a drill?
MCN
PostPosted: 15:37 - 13 Jul 2017    Post subject: Reply with quote
And this thread is not serious without one or more crisp photos of the area/s. Rolling Eyes
mudcow007
PostPosted: 23:22 - 13 Jul 2017    Post subject: Reply with quote
fixed it!!
I stopped being lazy an pulled the tank off, coil an anything else in the way so you could see direct into the recess an spotted what looked like a rubber seal/ o ring
made a hook out of a bit of wire an pulled it out, it was one of the little rubber seals from a coil plug grrr
water now drains as it should.
Reckon that would cause all the misfires when it rained?
RhynoCZ
PostPosted: 23:39 - 13 Jul 2017    Post subject: Reply with quote
Yes. Thumbs Up
ADSrox0r
PostPosted: 14:11 - 15 Jul 2017    Post subject: Reply with quote
Simple to check, fire it up and leave it idling while you fire the garden hose/watering can at it.
The last post was made 8 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 84.9 Kb
