| binge |
 binge Emo Kiddy
 Posted: 18:10 - 27 Jun 2017 Post subject: |
| Pete. |
 Pete. Super Spammer
 Posted: 21:05 - 27 Jun 2017 Post subject: |
Cool
Did you watch them rebuild the crank? Can you run us through the process? ____________________ a.k.a 'Geri'
| binge |
 binge Emo Kiddy
 Posted: 21:31 - 27 Jun 2017 Post subject: |
Nope. Afraid not.
Dropped it off at the counter, an old boy took it off me.
Called me the next morning. I went there, gave him 45 notes, and got my crank back.
Speaking to a couple of local bike shops, they're meant to be the best in town for having cranks pressed and re-alligned.
I looked into doing it myself loads online, and there are a couple of ways.
The proper way, is to press it apart on a plate which sits between the webs.
And when rebuilding it, there is a jig that gets it almost smack on in line first time.
And then fine tuned with dial gauges.
Other people, just press the pin right through both webs, from one side, using a hollow socket-type tube.
Not sure if this is any good for the bottom web as I'm not sure if the pin is meant to be pressed out from that side.
But, mine looks to have been done very well. spacing is all spot on.
Fingers crossed it runs okay.  |
| binge |
 binge Emo Kiddy
| stevo as b4 |
| Pete. |
 Pete. Super Spammer
 Posted: 20:07 - 01 Jul 2017 Post subject: |
If you want to really press the engine I have an unopened drum of 119 octane fuel here. It's a few years old but it's been kept in a cool dry place so it should be good as new. ____________________ a.k.a 'Geri'
| Kickstart |
 Kickstart The Oracle
| binge |
 binge Emo Kiddy
| 331X2 |
 331X2 Crazy Courier
 Posted: 23:39 - 04 Jul 2017 Post subject: |
Good skills
A lot of people I know with skis are going over to the Exol Optima Racing oil, I've run Silkolene Comp 2, Putoline MX9, Castrol Power 2T, Castrol A747, Maxima 927 and I've never had a problem with any. Although my engines are a lot less revvy than a 125 they do spend minutes at a time pinned at full revs/load.
Pete, there's a good thread somewhere on rebuilding a banshee crank, I used it as the basis for rebuilding a twin cylinder press fit crank although I set the phase with slips on a surface plate rather than machining a jig. Came out at 0.127 degrees out of phase and 0.0002" out of true which is well under allowable limits, it did take me 10 hours and a bit of copper mallet work though  |
| binge |
 binge Emo Kiddy
 Posted: 13:46 - 14 Jul 2017 Post subject: |
| binge |
 binge Emo Kiddy
| binge |
 binge Emo Kiddy
 Posted: 21:46 - 18 Jul 2017 Post subject: |
| stevo as b4 |
 Posted: 23:03 - 18 Jul 2017 Post subject: |
Damn that bike is so cool and so nicely put together it's a legend!
I can't imagine how fucking cool it'll look on the grid at an open class round, and how many people will be all over it looking at the beast you have created. I reckon it'll win a race against everyman KTM's just because everyone else will be staring at your bike instead of concentrating on their riding.  |
| binge |
 binge Emo Kiddy
 Posted: 10:08 - 20 Jul 2017 Post subject: |
Cheers dude
I just hope it's gonna have the low down power to pull out of the corners and make at least some effort to keep up.
Failing that, I may need to close the power valve up and run it in it's 'restricted' state, just to be competitive in the twisties.
After my crash and broken hand, I'm gonna struggle to ride this thing properly. Clutch slipping and powering it into every corner.
I cant afford another crash, as my hand will break easier next time.
Tempted to look into Powervalve systems for it.
My only option will be the Rotax Max, gokart set up, but it means head off again, to drill the air hole.
And battery relocation to allow clearance for the unit.  |
| stevo as b4 |
 Posted: 19:16 - 20 Jul 2017 Post subject: |
I totally get your point and then some, after that nasty high side on the grunty 4valve outlaw class thumper, which with its big midrange torque was probably worse?
I'd be very scared of pulling the pin on a 30bhp peaky 2stroke with a snappy band, and a bike that can't be much heavier than the 190cc racer?
I didn't even realise about the Rotax needing midrange for racing against the KTM's etc. I guess being MX derived bikes they have better power spread and gearing than a 30bhp sports bike stroker would.
Are the restricted Aprilias quite docile and with a much more decent midrange than full power motors?
It's a shame you can't run the electronic servo controlled exhaust valve as in theory they should be smoother with progressive opening depending on the powervalve design. The Rotax pneumatic system looks very bulky and like it'd take up too much space?
I don't know much about power valves, but I've read that on systems like the KTM one where the opening speed is adjustable to change the power delivery, that setting it up to open as late as possible makes it alot more friendly and less aggressive. Thinking it's maybe because you have to ride past the natural power peak before you get all the screaming top end?
You could try riding it like Doohan rode his NSR500's.
He said he always wanted to go into every turn at over 11'000rpm, past the torque peak so that if the rear tyre lit up he
only had a few hundred rpm left for it to slide, so hopefully it would limit the slide as the power fell away, instead of suddenly exploding into the power band on corner exit.
I'll be fucked if I'm willing to try it myself and find out though. I imagine that even the last 1000rpm of a 190bhp 500 looks like a pretty horrific mountain!  |
| Kickstart |
 Posted: 21:03 - 20 Jul 2017 Post subject: |
The old RAVE 2 pneumatic system is a bit bulky. There are more compact versions of it, on the very old engines (not adjuster screw) but no idea if this could be turned into a hybrid that would work on a 123 engine.
The electronic valve is less bulky but has the cable poking forward
I wonder if you could build some kind of hybrid system using a pneumatic valve metal housing on the barrel but without the cap and spring, and instead operate it via a cable and a lever (the bikes with a pneumatic system had a cable from the back brake to a lever to open the valve).
How much clearance do you have? Any reason you can't use an electronic valve beyond clearance?
With the valve pegged open it will kick in with a bang at about 8k. With the valve closed it will be pretty useless above 8k, and probably max out at about 15hp.
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| binge |
 binge Emo Kiddy
 Posted: 21:42 - 20 Jul 2017 Post subject: |
I have no loom to run the electric one.
I assume they get the 8k signal from the clocks?
My rev counter was cable driven, but now it's got an MX pipe fitted, there is no clearance for the cable to exit the clutch housing. I've had to blank it off.  |
| Kickstart |
| binge |
 binge Emo Kiddy
| binge |
 binge Emo Kiddy
 Posted: 21:55 - 11 Aug 2017 Post subject: |
TAX'd and insured today.
Less than £100 for both.
Been out for a spin. Had 2L of petrol in the tank (it holds just under 4).
Totally lost track of how far I'd ridden.
15.3 miles, and it conked out on me.
1/2 mile push to petrol station.
Filled it up, Made a big fucking mistake of brimming it, and then realizing there was no room to add the Pre-mix.
Managed to wiggle the bike and get the fuel into the other side of the tank, and make enough gap to drop the 120ml of oil in (I run it 25:1 but thinking about going to 30:1)
Fucking thing wouldn't run properly. Wouldn't rev into the band or anything.
Limped it home, took the carb off, and everything was just full of bloody red 2-stroke oil.
I assume it'd all sunk in the tank, and when I ran it out, it dragged all the sludge through and clogged the thing up.
Cleaned the plug, cleaned the reed block and carb out.
Fresh fuel and oil bled through, and took it for another good spin.
The result:
Bottom to Mid-range - Total shite.
We knew this anyway, as it's over-jetted to avoid seizure while running it in for a dyno.
Once it crosses over onto the Main jet, it improves so much
And as soon as it comes on the pipe. Oh my gosh! So good.
https://scontent-lht6-1.xx.fbcdn.net/v/t1.0-9/20770054_522108071473556_5449683495709330559_n.jpg?oh=3877eabe62928dd1425a7af5e42deed0&oe=59EB250A
https://scontent-lht6-1.xx.fbcdn.net/v/t1.0-9/20708179_522098204807876_529651825035230329_n.jpg?oh=189ffc928fc23a15a6adca9406c2f102&oe=5A30A867
https://scontent-lht6-1.xx.fbcdn.net/v/t1.0-9/20728342_522067154810981_3469233886629648531_n.jpg?oh=0b61bb6fdb3e63b18ca0ec3603210455&oe=59F3A5F3
I'm a bit pissed off cos it's dropping box oil out of the cases somewhere, and onto the rear tyre.
I need to clean it all off and find out where.
Annoyingly I cant split the cases again without fuck arsing around pulling the crank bearings out. So gonna have to hope nipping up the case bolts will stop it. Maybe loosen them off a bit and smear some silicone gasket in there and nip them up again.
Who knows. Job for another day.
Fingers crossed it'll be reliable enough to get to Brands Hatch on Sunday. |
| stevo as b4 |
 Posted: 22:07 - 11 Aug 2017 Post subject: |
This post is just spilling full of MFPW!
That is all!
P.s I love the little custom alloy Rad, you've inspired me to have one made for my bike. Oh and an oil leak is normal IMO as I've got a weepy gearshift shaft oil seal, and I'm not fucking around to replace a tiny little seal when there's a sunny evening for 2smoking.  |
| Kickstart |
| binge |
 binge Emo Kiddy
| Kickstart |
 Posted: 12:33 - 13 Aug 2017 Post subject: |
There were several different covers used . Mine have a level hole (ie, fill up until it overflows). 1L sounds about right (the 127, 123 and 122 use different amounts of oil).
But looking at the picture sideways on you seem to have mounted the engine at a slight angle compared to the bikes normally using this engine. This will affect the oil level in any level hole or window, and possibly also where the oil is relative to the breather.
Mind you, too long on the back wheel would have the same effect
| binge |
 binge Emo Kiddy
 Posted: 15:24 - 13 Aug 2017 Post subject: |
I sorted the oil leak (Sort of).
The crappy gasket in the clutch cover wasnt sealing at about 2-oclock to the clutch.
So it was just launching oil up, and causing it to leak out of the gap.
Loosened all engine mounts, unbolted cover, pulled it up an inch, and splurged some instant gasket all the way around the cover.
Tightened back up, and it's sealed.
Not pretty, but the engine will have to come out to do it nicely. So that's a job for the winter when I tart the engine up properly.
Pretty fucked off though, because the alloy rad (Which is literally brand new) is leaking from the very top rail, on the back.
So it's not impact damage. Just shitty rad basically.
Bought it online, it wasnt cheap, and cant remember the seller.
So... I've bought some alloy brazing rods, and gonna have a pop at soldering / brazing it with the little butane torch I've got.
Might have to give Pete a bell for some advice.
Rode to brands this morning for Festa Italia.
Little bit disappointing. After receiving tickets and fliers about 'Aprilia bike stands', And this, and that.
There were just Italian cars, and bikes plonked all over the place.
There were no bike, or car stands.
Watched a few idiots do a parade lap in their Lambos, little bit of Italian vs British racing (Minis verses Lancias etc)
Couldnt keep myself occupied enough to stay until 5pm when the bikes did a parade lap, So left early.
Bike runs awesome on the smaller pilot jet, but it's still really boggy, so more tweaking required.
77 miles on the odo now, so it's near enough ready for some Dyno work next week.
Fuel consumption is working out at about 25mpg, which isn't terrible, but im sure stock RS125s do around 50mpg. So hopefully some smaller jets are needed and it'll improve slightly.
https://scontent-lht6-1.xx.fbcdn.net/v/t1.0-9/20767766_522840814733615_6190803573814995215_n.jpg?oh=d71d021ea4984b3cd6bc7e5897eb6b38&oe=59F390C2 |
The last post was made 9 years, 17 days ago. Instead of replying here, would creating a new thread be more useful? |
