How much could I ask for this?
Flip
PostPosted: 22:04 - 09 Mar 2005    Post subject: How much could I ask for this? Reply with quote
Decided that it's time to sell the gixxer (1990) (see link in sig).
All it needs is...
Front fairings.
H frame and headlights (which I have, but will sell seperately).
Rear plastic needs repairing.
Indicators etc.
Or streetfighter it.
Oh and the oil cooler is slighty bent. This needs bending back because you cannot get full lock to the right. (Easily done though).
Bike has been stood for about 6 months.
What would be a fair price to ask (bearing in mind that the engines sell for around £400 on their own)?
Flip
PostPosted: 22:19 - 09 Mar 2005    Post subject: Reply with quote
I should add, that the frame and forks have been tested by Carole Nash to see if they're bent and they are totally straight. Thumbs Up
Gazdaman
I did a trackday!!!
PostPosted: 23:53 - 09 Mar 2005    Post subject: Reply with quote
Hard call, doesn't look like it needs much money spending on it though to get it back 100% road worthy. A little bit of work, and the added hastle of not being able to ride it to its new home.
I think you're looking at just over £1000. There's a mint 1990 Gixxer750 like yours on biketrader priced at just over £2k. That has braided lines the works, and a years T&T, based on that I think you could get £1200-£1600 for yours at a push.
Gaz
Flip
PostPosted: 02:38 - 10 Mar 2005    Post subject: Reply with quote
So does anyone think asking a grand for it is optomistic?
Maybe it's worth advertising on a streetfighter site as I don't reckon it'd sell on here.
Or is ebay my friend? Thinking
yzf750r
PostPosted: 09:52 - 10 Mar 2005    Post subject: Reply with quote
nice bike, i'd try ebay, probably get more than you think...! Thumbs Up
base
PostPosted: 09:58 - 10 Mar 2005    Post subject: Reply with quote
i personally dont think you would get the figure you want via ebay, especially for a damageed repairable private sale but in all honestly it depends who sees it and what its worth to them, you may be lucky and get what your asking but i would be surprised.................good luck
v4forlife
PostPosted: 09:59 - 10 Mar 2005    Post subject: Reply with quote
ill give ya a tenner for it, and you hafta get it to me and walk home
www.wilcollinsphoto.co.uk
map
Mr Calendar
PostPosted: 10:27 - 10 Mar 2005    Post subject: Reply with quote
A poor GSXR750 (running but cosmetics etc. shagged) would be about £1000. So crash damaged, with the cost of the plastics I'd say lucky to get about half that.
Although this 1985 one is priced at £795 Shocked, so what do I know Rolling Eyes
flip wrote:
...bearing in mind that the engines sell for around £400 on their own...
Bear in mind that bikes are often worth more in bits than when put together!
The GSX-R750 was made from '96 so not your bike, easy to confuse the 2 though just from the letters. Careful if you advertise it someone doesn't think you're passing it off as the newer one (although buyer beware applies Wink).
Just my thoughts, HTH Karma
EuropeanNC30R...
Gay Hairdresser
PostPosted: 11:36 - 10 Mar 2005    Post subject: Reply with quote
Also bear in mind SRAD 750's have been going for unbelievably low amounts on ebay recently. I've seen two in half-decent condition go for 1550 and 1750, admittedly high mileage though.
sickpup
Old Timer
PostPosted: 19:43 - 10 Mar 2005    Post subject: Reply with quote
How fast have you gone on your bike?
ALL Japanese GSXR's after 1988 are restricted via the cams, carbs and CDI. Due to this the engine is not worth £400 but nearer £200 and the whole bike in my experience and bear in mind I own 3 oil boilers and deal in them is around £1000-£1200 but if you fail to admit it's an import or sell to a numpty you might get £1700.
Flip
PostPosted: 19:44 - 10 Mar 2005    Post subject: Reply with quote
Thinking Think I'll ebay it and see what happens.
OK.
Cheers fellas.
Flip
PostPosted: 19:49 - 10 Mar 2005    Post subject: Reply with quote
Quickest I had was 135 mph. Had plenty left in it, but got nervous Laughing . The fella I bought it from had 150 out of it.
Got a TRE on it so it accelerates well too. And the Cyclone sounds ace.
sickpup
Old Timer
PostPosted: 01:34 - 11 Mar 2005    Post subject: Reply with quote
You can't fit a TRE to a 1990 GSXR750. There is no retard on the timing.
What you might have is a diode inserted into a wire to trick the CDI into thinking your in fourth so the engine can rev out but this doesn't remove the restriction from the carbs or cams.
The way to check is to see how many wires are with the neutral light wire, if one more than UK standard your restricted. If not the person you bought it off lied to you as well as lieing when they said it had a TRE fitted.
As an idea the UK spec does around 32-34 to the gallon so if your getting more your restricted. It will also power slide the rear upto third as well as wheelie off the throttle to third dependant on body position.
UK 1990's had 38 mm carbs but japanese imports had 34's or 36's
sickpup
Old Timer
PostPosted: 01:41 - 11 Mar 2005    Post subject: Reply with quote
Sorry but what are you talking about?
The GSX-R was first made in '85 the hyphen being there to differentiate it from the GSX therefore GSX-R(acing).
Flip
PostPosted: 03:47 - 11 Mar 2005    Post subject: Reply with quote
Well it had something done to it. It's got a 0 - 60 of about 3 - 4 seconds and keeps pulling strong over 130. Wouldn't of thought a resricted bike would do these speeds? Thinking
map
Mr Calendar
PostPosted: 12:07 - 11 Mar 2005    Post subject: Reply with quote
sickpup wrote:
...what are you talking about...The GSX-R was first made in '85 the hyphen being there to differentiate it from the GSX therefore GSX-R(acing).
GSXR750 - from 1985 to 1993.
GSX-R750W - from 1993 to 1996 (W for water cooled).
GSX-R750 - from 1996 to current.
GSX750 - from 1980 to 1989.
GSX750F - from 1996 to current.
GSX750W - from 1998 to 2003.
So if you seen and advert for a GSXR750 and there isn't a year given, which one will it be?
HTH Thumbs Up
mattd
PostPosted: 13:21 - 11 Mar 2005    Post subject: Reply with quote
If you wait a little while Flip, there's a free listing day coming up for motors on Ebay Thumbs Up
Save yourself a few quid!
Professional Hobo
Flip
PostPosted: 19:03 - 11 Mar 2005    Post subject: Reply with quote
Nice one Matt, do you know when?
EDIT/ This Sunday. Just found it. Thumbs Up
sickpup
Old Timer
PostPosted: 21:53 - 11 Mar 2005    Post subject: Reply with quote
So this would be 89 for example.
https://www.gixxer.com/photopost/data/2/489gsxrs-med.jpg
Note that little hyphen.
sickpup
Old Timer
PostPosted: 21:59 - 11 Mar 2005    Post subject: Reply with quote
map wrote:
So if you seen an advert for a GSXR750 and there isn't a year given, which one will it be?
HTH Thumbs Up
Fuck knows I go by the model letter. Smile and the water cooled models started with the WN in 92 except the states where they had to wait until 93
Flip
PostPosted: 22:24 - 11 Mar 2005    Post subject: Reply with quote
@Map
Now I get you. Yeah, mine is an 'L' which will be made clear in the ad. Thumbs Up
sickpup
Old Timer
PostPosted: 02:41 - 16 Mar 2005    Post subject: Reply with quote
Sorry map but I'd like to know why you rated my post showing a 1989 Suzuki brouchure as confusing just because it proves you wrong on your idea of the model names?
Please explain...
sickpup
Old Timer
PostPosted: 06:04 - 17 Mar 2005    Post subject: Reply with quote
Think I'll just bump this as I'd really like an answer.
The last post was made 21 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 116.84 Kb
