Nsr125 just purchased with crank case full of mystery fluid
spitfire123
PostPosted: 20:20 - 11 Sep 2017    Post subject: Nsr125 just purchased with crank case full of mystery fluid Reply with quote
Nsr 125
Just picked this up , guy said he'd owned it 4 days and was on the way home and it was pissing it down and the bike cut out, he was recoverd home and told by the recovery firm "wet electrics " leave it 2 or 3 days and it will stat.
3 months later I bought it with it still not staring .
Now somthing very worrying , he took the barrel off and took some photos , the crank case was full of liquid a reddish liquid , Now that's either gear oil gushing through the seals or he's been cranking it for hours on end and massively flooded it .
I've added the pic he showed me , surly it's not possible to flood it that bad ?
Btw he said he cleaned it all out and it still dident start ?
What do you lot think it could be ?
You won't be able to eat my dust......As it'll settle before you get there.
PostPosted: 20:23 - 11 Sep 2017    Post subject: Reply with quote
Red liquid does suggest 2 stroke oil or gearbox oil. But also possibly pink anti freeze if they didn't drain the coolant before they started to take it to pieces.
Do you have a spark? Do you have fuel getting in?
Katy
spitfire123
PostPosted: 20:26 - 11 Sep 2017    Post subject: Reply with quote
Forgot to add
The engine was fully rebuilt 6k ago
I've litraly just picked it up .
I'm trying to add pics for you guys to have a look it .
But it's not having none of it !
spitfire123
PostPosted: 20:27 - 11 Sep 2017    Post subject: Reply with quote
Katy
I dident think of that Katy !
I wonder .....
The pic I have looks like a thick oil .... but I just cant get them to upload Neutral
PostPosted: 20:36 - 11 Sep 2017    Post subject: Reply with quote
Pure antifreeze might appear like that, while also possibly being too viscous to pump around effectively for coolant.
That said, some people have filled cooling systems with oil before now!
Katy
spitfire123
PostPosted: 20:44 - 11 Sep 2017    Post subject: Reply with quote
I'll try get this picture on here .
spitfire123
PostPosted: 20:52 - 11 Sep 2017    Post subject: Reply with quote
Pic
spitfire123
PostPosted: 20:58 - 11 Sep 2017    Post subject: Reply with quote
More pics
Stalk
PostPosted: 21:04 - 11 Sep 2017    Post subject: Reply with quote
Used to have a Honda moped with a gear driven 2stroke oil pump on the crankcase, as the bike was left standing for long periods of time the oil would leak past the oil pump seals and into the crankcase. Caused all sorts of messing about when trying to start including hydrolocking, fouling the plug and smoking big time once started. That does look like oil in your engine, have you got the same autolube pump? Is it leaking internally? Was there oil in the tank when you collected the bike?
Hope this might be of some help
PostPosted: 21:05 - 11 Sep 2017    Post subject: Reply with quote
That is pretty full! That level is high compared to even the gearbox oil level.
Does look like oil with a bit of water in it.
It is odd. Only way I can see getting that much 2 stroke oil in is if someone connected the oil tank directly to the carb, bypassing the pump! But the gearbox oil would require a very dead seal. Either wrecked (in which case I would expect it to go back into the gearbox when parked), or the seal in backwards (in which no way would it run for 6k)
Katy
spitfire123
PostPosted: 21:37 - 11 Sep 2017    Post subject: Reply with quote
I belive so .
It's still on the trailer at the moment .
I'll be having a look when I get a chance during the week I hope !
spitfire123
PostPosted: 21:38 - 11 Sep 2017    Post subject: Reply with quote
Katy
I thought this Katy
Unless it hasn't got a spark or somthing and he's been cracking it for a while ?
spitfire123
PostPosted: 21:39 - 11 Sep 2017    Post subject: Reply with quote
Also getting back to this point , I have an rs and rg 125 and both of them run off the engine pumps that go back to the carb .
Does the nsr have a 2ndry feed to the crank ?
PostPosted: 19:52 - 12 Sep 2017    Post subject: Reply with quote
spitfire123 wrote:
I thought this Katy
A hell of a long time maybe. Say there is 1/4 litre in there, that is ~100 miles of 2 stroke oil. If you assume 10000rpm at 100mph, that is 600,000 revolutions worth of 2 stroke oil even at full throttle. Crank it over at 1000rpm (at best) then that is 10 hours solid cranking minimum.
The feed goes to the slide on the carb on the NSR I think (quite a odd place to connect).
Katy
Kawasaki Jimbo
PostPosted: 22:16 - 12 Sep 2017    Post subject: Reply with quote
Anti-freeze was mentioned early on, although subsequent posts suggest it is more likely to be oil. Still, for information ethylene glycol tastes sweet but latterly I believe it is sold with a bittering agent to deter self-poisoning. For analytical purposes taste could be useful, but dip your finger and don't swallow, spit.
The last post was made 8 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 89.52 Kb
