Decent LED indicators
M.C
PostPosted: 00:39 - 16 Oct 2017    Post subject: Decent LED indicators Reply with quote
Can anyone recommend any? The last pair of indicators I bought fell apart almost immediately. Also I'd like to get as close to these as possible:
https://i62.servimg.com/u/f62/15/13/82/47/indica10.jpg
Tracer1234
PostPosted: 02:56 - 16 Oct 2017    Post subject: Re: Decent LED indicators Reply with quote
Useful thread it useful. Also in the market for these.
Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
Ben90
PostPosted: 06:36 - 16 Oct 2017    Post subject: Reply with quote
Money no object, these ones are the mutts nuts.
Much sturdy, very brightness etc. Still need an LED relay though.
Yamaha do even more expensive ones for the MT-09 range which have additional brake lights built in on the rears and DRLs in the fronts Shocked
Yamaha FZ6 S2
PostPosted: 06:41 - 16 Oct 2017    Post subject: Re: Decent LED indicators Reply with quote
I blame Brexit. Thumbs Down
grr666
PostPosted: 08:03 - 16 Oct 2017    Post subject: Reply with quote
I'm looking to LED my indicators, I'm probably going to have a couple of sets of the first type.
The fancy ones with DRLs etc aren't the most attractive looking things in the world, but I like the idea.
https://www.youtube.com/watch?v=6CIfUWFURxw
M.C
PostPosted: 14:23 - 16 Oct 2017    Post subject: Reply with quote
I don't think I've got one. The indicators flash quite fast, is that why you need an LED relay?
grr666
PostPosted: 14:30 - 16 Oct 2017    Post subject: Reply with quote
Yes.
https://www.ebay.co.uk/itm/MOTORCYCLE-LED-INDICATOR-RELAY-OEM-YAMAHA-CORRECTS-FLASHING-FLASHER-UNIT/120515584523?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
PostPosted: 18:57 - 16 Oct 2017    Post subject: Reply with quote
No SMD ones. I much preferr SMDs.
OP, use normal indicators you like the look of, replace the bulb with SMD ones.
Tracer1234
PostPosted: 21:11 - 16 Oct 2017    Post subject: Reply with quote
Interesting. Are these a case of just plug and play? Anyone had any problems with these? Seems like a good option for me.
redeem ouzzer
PostPosted: 22:54 - 16 Oct 2017    Post subject: Reply with quote
It’s odd that I agree with our gap toothed village idiot, but yeah - LED indicators are wank and pointless.
Be a REAL MAN!
M.C
PostPosted: 09:51 - 17 Oct 2017    Post subject: Reply with quote
Well the bike has them already (along with an LED brake light) but maybe it'll be best going back to standard ones Thinking
Anyone recommend any standard indicators then? Smile
PostPosted: 09:58 - 17 Oct 2017    Post subject: Reply with quote
You still need an electronic relay because they don't draw as much power as standard ones. That said, electronic relays are the way forwards anyway.
As with all LED bulbs, quality varies. I've used ones from these people before (link below), quality is good, price is fairly high though. I put thge 6v ones on the wifes YB100. The thing to watch is if you use white ones, it can overwhelm the tint on the flasher lens. I'd get amber ones next time.
https://www.classiccarleds.co.uk/collections/indicator-bulbs
Matt B
PostPosted: 14:07 - 17 Oct 2017    Post subject: Reply with quote
+1
They can be too directional and often hard to see in bright daylight. You can still go mini but just use a bulb type or go with Stinkwheel's idea of an SMD bulb.
Hong Kong Phooey
PostPosted: 22:07 - 20 Oct 2017    Post subject: Reply with quote
Oxford eyeshot, I made my own inline resistors as it worked out cheaper.
They're bright and small, but as with a lot of these things where the rubber moulding meets the screwthread can break, if you overtighten or drop the bike.
I mitigated against that issue by adding an extra nut on the stem.
RhynoCZ
PostPosted: 23:45 - 20 Oct 2017    Post subject: Reply with quote
This, C:\BCF\Thread\Solved.exe
grr666
PostPosted: 11:44 - 26 Nov 2017    Post subject: Reply with quote
I am led to believe there is one included with these. I'll let you know when mine turn up. They are a bit smaller
unit compared to the stock ones. As this photo (which isn't mine) illustrates.
https://i.ytimg.com/vi/fpu-QAbOxX0/maxresdefault.jpg
I think they match the tail light better tbh. And they definitely stick out less. Thumbs Up
kramdra
PostPosted: 13:31 - 26 Nov 2017    Post subject: Reply with quote
Indicaors made up with individual LEDs are shit. Why? The lens is moulded on the led. They seem bright but only becuase they are directional. The design is not correct for indicating - being seen from any direction with a large noticable surface area.
The ideal led for indicating is the COB, which do not have a built in lens. Costs about a pound each, but noone yet has put them in a indicator housing... Ive got some but too lazy.
bladerunner
PostPosted: 02:46 - 29 Nov 2017    Post subject: Reply with quote
HELP! I bought some LED indicators for an old RD125 LC I'm doing up. it didnt have any so thought I'm to old not to bother these days! ok I bought an LED relay from the same ebay seller but that turned out not to be a bloody LED relay just rather a solid state relay that needed at least a 10W load......anyhow they sent me out one of those adjustable relays that so long as the motor is running I can get a steady flash rate ( god knows how long for tho!) anyhow.. How the hell do I rig up a dash light that shows the indicators are on without flashing all 4? ive removed the current normal bulb and cant find the T5 led wedge bulbs required if thats the fix? I've ordered 3 bulbs from different ebay sellers as the correct type but they always send the side light type. ANY ADVICE GUYS?
Teflon-Mike
tl;dr
PostPosted: 05:11 - 29 Nov 2017    Post subject: Reply with quote
Anomolies with LED Lamps, & Indicators
The last post was made 8 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 112 Kb
