my strange noises
garth
PostPosted: 17:51 - 11 Mar 2005    Post subject: my strange noises Reply with quote
hi,
I have just put my honda c200 together and got it running, it is a 90cc pushrod four stroke single.
When I try to pull away, it feels as though it is pinching up, and slows down, asthough there is excessive friction, and it knocks. I suspect the big ends.
However I drained out the oil, and found no trace of swarf etc.
the engine has been stood up for about 2 years, and had a rebore before that.
I am not best pleased, as you can imagine.
Does it sound like the big ends to you? Or possible oil starvation?
Any help appreciated, thanks.
Sad
PostPosted: 19:21 - 11 Mar 2005    Post subject: Reply with quote
What are the tappets like? not over tight?
Knocking could be big-ends or mains. Also consider the possibility of crappy unleaded fuel, I presume it was made back in the 60's? You using an octane-boost and lead substitute in it?
I wouldn't have thought oil pressure should be a problem, I think those things use a trochoidal oil pump with is very robust. Unless there was a blocked oilway or something
garth
PostPosted: 09:06 - 12 Mar 2005    Post subject: Reply with quote
would tight tappet clearances cause the engine to pinch up at higher revs?
As it seems fine on tickover, just whenever any force is put onto it, i.e first gear, it trys to pinch up.
Cheers Smile
PostPosted: 16:01 - 12 Mar 2005    Post subject: Reply with quote
Well they would be holding the valves open for too long which would rob the engine of compression.
The last post was made 21 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 40.55 Kb
