Fitted hot grips - now throttle sticks
Andy_Pagin
PostPosted: 20:55 - 28 Oct 2017    Post subject: Fitted hot grips - now throttle sticks Reply with quote
What happens is the throttle doesn't snap shut when I release it so I'm guessing some of the glue has run into the throttle body or between the bar and throttle sleeve. How easy is to dismantle the throttle unit? Do I just unbolt it or do the throttle cables need releasing from the carbs first. Bike is 2003 Fazer.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:05 - 28 Oct 2017    Post subject: Reply with quote
Take off the bar weight and see if it still does it
Triumph Sprint ST 1050
Courier265
PostPosted: 21:49 - 28 Oct 2017    Post subject: Reply with quote
what he said...
PostPosted: 22:04 - 28 Oct 2017    Post subject: Reply with quote
It's always going to be rubbing on the bar end or the plastic handlebar controls. Can trim the ends of the heated grips gently so only the rubber bits.
Is why muffs are supreme btw. Wink
Nobby the Bastard
Harley Gaydar
PostPosted: 09:53 - 29 Oct 2017    Post subject: Reply with quote
My FZ developed a sticky throttle after I'd been riding for about 10 miles each time I rode it.
It took me about 6 months to work out it was the heated grip expanding enough when hot it was rubbing on the bar end weight....
Andy_Pagin
PostPosted: 12:47 - 29 Oct 2017    Post subject: Reply with quote
Sorted. Turned out to be a tiny smear of glue between the bar and throttle sleeve. Dismantling the twist grip was dead easy.
The last post was made 8 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 47.3 Kb
