A question about shifting into first
firg
PostPosted: 18:02 - 12 Mar 2005    Post subject: A question about shifting into first Reply with quote
Hi all,
something occured to me: If you are already in first gear, is there any problem with trying to shift down again (say your unsure at lights when youve stopped if you have already shifted into first)?
I.e. will it cause painful crunching?
cheers,
Loz
Ex-'96 Bandit 600S -> '99 Bandit 600 -> K7 V-Strom 650
Bomberman
PostPosted: 18:04 - 12 Mar 2005    Post subject: Reply with quote
Nothing will happen. It just won't move except maybe bend a little Very Happy
firg
PostPosted: 18:07 - 12 Mar 2005    Post subject: Reply with quote
Alrighty, thanks.
Also, whats clutchless shifting? Do ya just use brute force?
wildcat
I usually do this just to check, or I flick it up to neutral.
https://www.bebo.com/Z1000-Wildkat
Fruit'n'nut
PostPosted: 18:15 - 12 Mar 2005    Post subject: Reply with quote
No, not brute force Shocked Shocked Shocked
Do it going up the box; toe under the gear lever ready to change up, roll the throttle shut, then gently apply pressure to the shift lever - it should just go straight into gear. Roll throttle open, up through the revs and repeat.
You'll get better and quicker with practice.
Use the clutch on the way down.
Smile
Power Ranger Very Happy
Flip
PostPosted: 18:20 - 12 Mar 2005    Post subject: Reply with quote
You have to be 'giving it some' for clutchless shifting to work though. Once you have it nailed, it is so much better. Just takes a little practice on the timing but it's easy to do. Thumbs Up
Fire_Eyes
PostPosted: 18:39 - 12 Mar 2005    Post subject: Reply with quote
Does clutchless shifting harm the engine in any way? Thanks.
Kawasaki ZZR 400 | K5 GSX-R 600
Flip
PostPosted: 18:42 - 12 Mar 2005    Post subject: Reply with quote
No.
strag
PostPosted: 18:44 - 12 Mar 2005    Post subject: Reply with quote
Do not use clutchless from 1st to second!!
It is easy once you have mastered it. All you need to do is shut the throttle quickly, knock it up and open the throttle again. Much faster changes. It's all timing which you will get with practice.
Oh yeah, don't try to do it going down the gears either.
carbon bling
dodsi
Dirty Carny
PostPosted: 19:07 - 12 Mar 2005    Post subject: Reply with quote
I like kawasaki positive neutral, kick it right down and stop....
...will only go into neutral.
Claud 14.7 to 1
PostPosted: 19:16 - 12 Mar 2005    Post subject: Reply with quote
Why? I do it all the time when giving it some. Confused
mchaggis
PostPosted: 19:28 - 12 Mar 2005    Post subject: Reply with quote
I find it a bit easy to get stuck in neutral or for it to get into second and drop out again when going for a rapid (as fast as 10hp 130kg will go rapid) takeoff. It might just be the vagueries of my Chinese gearbox but it's still somewhat frustrating revving and wondering why you're going nowhere.
Then you change up and get third. Laughing
I must not be a troll...
Mmmm, Guinness
Little Miss PMT
PostPosted: 19:42 - 12 Mar 2005    Post subject: Reply with quote
I have got into the habit of tapping the gear down before a move off.................just in case Wink
Watch out LMPMT is out!!!!
Flip
PostPosted: 19:43 - 12 Mar 2005    Post subject: Reply with quote
Nowt wrong with that. I still do it after 3 years.
Aikman666
PostPosted: 19:53 - 12 Mar 2005    Post subject: Reply with quote
thot this might be the right place to put the question in: when im shifting (im 15, an offroader) the gear sometimes slips and goes into neutral, is this because im not puttin the gear lever up (or down) hard enough, or is it a problem with my gearbox? BTW im not using clutchless shifting, only ever done that once by mistake Razz
Thanx guys!
Will work for petrol
My Design Blog
instigator
PostPosted: 19:56 - 12 Mar 2005    Post subject: Reply with quote
Yes, it's most likely you not pushing your foot down hard enough and it slips into a false enutral. My bike sometimes does it too. The sr125 bike I learned on done that too (on the test, I got a minor for that Sad)
Unless it does it excessively after pushing down/up with your foot, then there might be something wrong.
Flip
PostPosted: 21:24 - 12 Mar 2005    Post subject: Reply with quote
Yeah. Give a firm stamp down and it'll go in if not your gearbox has probs.
Is it a suzuki? Got a gixxer and that needs a firm stamp into first, So does my loaned SV.
White Noise
Mr Dudwee
PostPosted: 21:27 - 12 Mar 2005    Post subject: Reply with quote
Also if you are having problems getting it out of neutral into first or second, let the clutch out a little then give it a firm stamp, it should get you into first.
WN
jonboy
PostPosted: 21:48 - 12 Mar 2005    Post subject: Reply with quote
I'd say clutchless shifting is much easier at low revs and just cruising tbh - it takes much more timing to get smooth shifts at high revs and full throttle.
Aikman666
PostPosted: 22:31 - 12 Mar 2005    Post subject: Reply with quote
thanx for the help guys, ill keep that in mind next time i go out on her..... After i get my front brake fixed (hit a tree a few days back). To answer you flip, no its not a suzuki, its an old BSA. I bought it about 4 months ago, and just finished completely refurbishing it, which probably explains why it dont work right Razz
If you have access rights to the Scottish forum this is the thread:
https://www.bikechatforums.com/viewtopic.php?t=38264
wish i had taken some before pictures tho Sad
My Design Blog
WildGoose
White Van Man
PostPosted: 22:32 - 12 Mar 2005    Post subject: Reply with quote
advice on clutchless shifting from what i have learnt, DONT think about it as:-
"roll off throttle, push gear lever up, then apply throttle again"
if you are on a constant throttle, no matter how hard the gear lever is pushed up, it wont change, so apply the pressure to the lever early...
the moment you roll off, even a few mm, the gear will change, and as soon as you hear the click, bang the throttle back open, it takes milliseconds to do, and this will give you the smoothest change if you arent using the clutch at all
remember you dont have to close the throttle all the way, just a few mm will do
jonboy
PostPosted: 22:36 - 12 Mar 2005    Post subject: Reply with quote
The idea I think is to close the throttle to the point where the bike is neutral - ie slowing down at the same rate as it would if you just pulled the clutch in and let it coast. This means all the transmission is unloaded and the gear will just slip in.
So if you were cruising at a steady speed you would hardly need to adjust the throttle at all, and if the bike was slowing down under engine braking you would actually open the throttle before moving the gear lever up.
How high your revs are when shifting would also affect how much throttle you should roll off to - heeping revs steady at about 11k needs quite a bit of throttle, whereas changing up just above idle would require rolling off to pretty much no throttle.
Usually putting a little pressure upwards on the gear lever before rolling off is the best way.
Flip
PostPosted: 22:46 - 12 Mar 2005    Post subject: Reply with quote
Disagree on that one Karma I do think it's easier at speed, although this does depend on the bike. Thumbs Up
Fruit'n'nut
PostPosted: 22:52 - 12 Mar 2005    Post subject: Reply with quote
Suzuki gearboxes Thumbs Up Wink
FWIW, my 600 slips up the gears pretty smoothly even at low revs.
Did your 750 not do the same? Question Confused
jonboy
PostPosted: 22:59 - 12 Mar 2005    Post subject: Reply with quote
Thumbs Up This is far too civilized - surely we should have a flame war, or at least a bit of slanging? Laughing
The last post was made 21 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 127 Kb
