| Hahadumball |
 Hahadumball World Chat Champion
 Posted: 23:11 - 31 Oct 2017 Post subject: welding or liquid metal? vtr engine borked |
Vtr chain snapped and twatted the sprocket cover which has the clutch piston on it too...
snapped all the bolt threads off the damn case
weld?
liquid metal?
ratchet strap around it?
what do... its only got to take the pressure of the clutch piston.
avoiding having to replace the engine, its a monoblock so case isnt in the question.
https://i.imgur.com/pyIG64H.jpg
https://i.imgur.com/ET1bFna.jpg ____________________ Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015 |
| jjdugen |
 jjdugen World Chat Champion
| Hahadumball |
| mentalboy |
 mentalboy World Chat Champion
| Hahadumball |
| Polarbear |
 Polarbear Super Spammer
| Hahadumball |
 Posted: 02:22 - 01 Nov 2017 Post subject: |
no clue how it did all mounts, i was doing about 25-30 if that when it went, looked a right cunt as i overtook a corsa only to rev the shit out of it when the chain went bye byes
only other thing i can think of is longer bolts and tap into whats left...
and hope like fuck
generic image shows a decent length to tap into..
https://i.imgur.com/GFbxtl1.png
if i could get deep enough i could liquid metal on the parts i have and then use longer bolts...
its only got to last me a few months until i replace it with the winter steed of 4 wheels
3 i can drill and tap with loads left...
1 is a bit risky
and 1 is quite fucked and doubtful.. i could maybe add... 3-4 turns on whats left and chemical metal the broken part on and hope it holds just for extra strength...
otherwise the 3/4 will hold fairly well.. ____________________ Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
| stinkwheel |
 Posted: 10:23 - 01 Nov 2017 Post subject: |
I mention this every time one of these comes up and nobody seems to take it on.
Aluminium solder will fix that. You'll be able to bridge that small hole and solder the bits back on. You'll need a good source of heat like MAP or oxy-acetylene. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| chris-red |
| stinkwheel |
| Hahadumball |
| stinkwheel |
| Northern Monkey |
 Northern Monkey World Chat Champion
| c_dug |
 c_dug Super Spammer
| Hahadumball |
| A100man |
 A100man World Chat Champion
 Posted: 20:28 - 01 Nov 2017 Post subject: |
| Despined_By_Ex wrote: | managed to bodge it, now to run this bike into the ground.
drilled and tapped what was left, metal putty the broken parts back on for asthetics and added a little thick aluminium bracket from the stator cover bolt to the bolt that holds the clutch piston to the sprocket cover for that extra bit of support just in case. |
Come on let's see it then. I am nothing if not a bodge connoisseur.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Hahadumball |
| jjdugen |
| ZRX61 |
 ZRX61 Victor Meldrew
| mentalboy |
| c_dug |
 c_dug Super Spammer
 Posted: 01:28 - 02 Nov 2017 Post subject: |
Top bodge  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Polarbear |
| Hahadumball |
| Hahadumball |
 Posted: 11:39 - 03 Nov 2017 Post subject: |
got the bolt in, trimmed the bracket and painted it
https://i.imgur.com/mpgJ2dZ.jpg ____________________ Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
| MCN |
 MCN Super Spammer
 Posted: 14:07 - 03 Nov 2017 Post subject: |
Jeez.. is no fucker going to mention the elephant in the room here or what?
That hooring front sprocket.... WTF?
Get a chain and sprocket set onto that beast ASAP.
Well some cnut had to say it.
 ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
The last post was made 8 years, 339 days ago. Instead of replying here, would creating a new thread be more useful? |
