| Ted |
 Ted World Chat Champion
| Monkeywrenche... |
 Monkeywrenche... Nearly there...
| colink98 |
 colink98 Could Be A Chat Bot
| arry |
 arry Super Spammer
| colink98 |
| Polarbear |
 Polarbear Super Spammer
| stinkwheel |
 Posted: 13:37 - 14 Nov 2017 Post subject: |
8,8 should be strong enough in terms of tensile strength. You're using a locknut so there are no worries regarding security.
Therefore it's all down to fit. Of there is no play and it's not fouling anything, I see no reason it shouldn't pass. If there is play, it should fail.
You could probably argue that there shouldn't be a threaded section inside the shock bushing too but the MOT tester can't see that. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| piazza |
 piazza Could Be A Chat Bot
| Ted |
| Ted |
| P.addy |
 P.addy Red Rocket
| Courier265 |
 Courier265 World Chat Champion
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| P.addy |
 P.addy Red Rocket
| arry |
 arry Super Spammer
| P.addy |
 P.addy Red Rocket
| P.addy |
 P.addy Red Rocket
| Courier265 |
| Nobby the Bastard |
| P.addy |
 P.addy Red Rocket
| Ted |
 Posted: 23:43 - 14 Nov 2017 Post subject: |
My CBF is too low for me really, and I keep catching my feet on the road on roundabouts and tight corners.  |
| Islander |
 Islander World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 07:59 - 15 Nov 2017 Post subject: |
Doubtful that MOT would notice but what you've put in is a long way from being adequate IMO. It's already visibly bending in the photo.
You've removed a M12 fine thread shouldered cap screw for a hardware- store M12 coarse bolt. Just losing the shoulder and measuring down to the thread's minor diameter loses you 71% of cross-section. Now the bolt (screw, actually) that's fitted is probably 8.8 grade but socket cap heads are 10.9 or 12.9 - each 125% and 146% stronger respectively - that's if the new fastener even reaches 8.8 spec.
A 71% reduction in cross-section and possible 65% reduction in strength makes your replacement bolt as poor as 46% the capacity of the one you've replace.
Time to re-evaluate what you have there IMO. ____________________ a.k.a 'Geri'
| Ted |
| arry |
 arry Super Spammer
The last post was made 8 years, 330 days ago. Instead of replying here, would creating a new thread be more useful? |
