Suspension bolts & the MoT?
Ted
PostPosted: 12:31 - 14 Nov 2017    Post subject: Suspension bolts & the MoT? Reply with quote
Probably a bit of a can of worms here.
Would an 8.8 rated bolt on a mono shock unit be an MoT pass/fail?
This is more of an academic question than anything else, as I'm intending to buy a new (correct) bolt, but I'm just intreged...
Monkeywrenche...
PostPosted: 12:41 - 14 Nov 2017    Post subject: Reply with quote
https://www.mot-testing.service.gov.uk/documents/manuals/m1s02000401.htm
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
colink98
PostPosted: 13:24 - 14 Nov 2017    Post subject: Reply with quote
that looks very similar to the back of my CBF.
That should be a CAP head bolt which sits in the recess on the left.
as a normal bolt is smaller in diameter than the recess, how are you stopping it from having excessive movement ?
id suggest the MOT bloke is going to have a look and might refer to this part of the rules
deliberate modification which significantly reduces the original strength, excessive corrosion, severe distortion, a fracture or an inadequate repair of a load bearing member or its supporting structure
its most probably not that use of that bolt but rather the bolt not fitting correctly.
Ride it like you stole it.
arry
PostPosted: 13:25 - 14 Nov 2017    Post subject: Reply with quote
Would seem it's a bit grey and I'd expect it to get an advisory only, subject to it actually being secure.
colink98
PostPosted: 13:26 - 14 Nov 2017    Post subject: Reply with quote
Also if it is the read end of a CBF the correct CAP bolts cant be found at Screw fix/Tool station.
you have to get them off the inter webs.
im 99% sure when i replaced my one, i ordered a spare.
happy to dig it out and post it if it helps.
PostPosted: 13:27 - 14 Nov 2017    Post subject: Reply with quote
I would suspect if there is no play in it you would probably get away with it as the tester won't be specifically looking at the bolt.
If he detects play and then has a good look I would expect that to be a fail.
This is purely guess work though, going on how my tester checks the suspension.
PostPosted: 13:37 - 14 Nov 2017    Post subject: Reply with quote
8,8 should be strong enough in terms of tensile strength. You're using a locknut so there are no worries regarding security.
Therefore it's all down to fit. Of there is no play and it's not fouling anything, I see no reason it shouldn't pass. If there is play, it should fail.
You could probably argue that there shouldn't be a threaded section inside the shock bushing too but the MOT tester can't see that.
piazza
PostPosted: 13:52 - 14 Nov 2017    Post subject: Reply with quote
It looks like the bolt is already bending to my eye. I'd be changing it regardless of MOT decision. It's probably less than a fiver for the right one fom Amazon.
Ted
PostPosted: 14:21 - 14 Nov 2017    Post subject: Reply with quote
It is a CBF, and yes the original bolt head sits in a recess. I had to make a spacer out of the original bolt head (photo attached).
As I fitted a second hand shock I needed to test it, so couldn't just fit the bolt without a way of holding it firmly.
Ted
PostPosted: 14:24 - 14 Nov 2017    Post subject: Reply with quote
That's just my photography skills. Sad
Lol
PostPosted: 14:46 - 14 Nov 2017    Post subject: Reply with quote
I'd be amazed if anyone gave a toss. Chuck a bit of black paint or dirt on it and thats that done.
Courier265
PostPosted: 15:14 - 14 Nov 2017    Post subject: Reply with quote
Ah the tight fisted approach....
redeem ouzzer
PostPosted: 15:41 - 14 Nov 2017    Post subject: Reply with quote
I’m boring the centre out of all my suspension bolts anyway. For speed add lightness.
Be a REAL MAN!
PostPosted: 17:25 - 14 Nov 2017    Post subject: Reply with quote
Not really, like you I couldn't reach the top shelf with the proper nuts and bolts.
arry
PostPosted: 18:58 - 14 Nov 2017    Post subject: Reply with quote
There's a back story here, I'm sure of it. I'm just not in the picture.
PostPosted: 19:12 - 14 Nov 2017    Post subject: Reply with quote
Neither is he. Tripod too high.
PostPosted: 20:49 - 14 Nov 2017    Post subject: Reply with quote
Courier for 901639164 years, can't ride bikes because they are too tall, has issues with a monkey bike by the sounds of it.
Courier265
PostPosted: 22:30 - 14 Nov 2017    Post subject: Reply with quote
Bottom line is modern motorcycles have higher seats than older bikes which means I can't get BOTH feet on the ground at standstill which makes my choice of the next bike very hard.
My CBF500 is perfect, however the latest model CB500 has a higher seat and can't get the feet on the ground.
Sadly some smart arses on this forum are taking this as ever so funny.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:37 - 14 Nov 2017    Post subject: Reply with quote
Jebus, just how short are you? I'm short....
Triumph Sprint ST 1050
PostPosted: 23:14 - 14 Nov 2017    Post subject: Reply with quote
I can't put both feet down when I rode my TTR600, didn't die. Did ride. Just incompetent rider too short for this world.
Ted
PostPosted: 23:43 - 14 Nov 2017    Post subject: Reply with quote
My CBF is too low for me really, and I keep catching my feet on the road on roundabouts and tight corners. Sad
Islander
PostPosted: 00:02 - 15 Nov 2017    Post subject: Reply with quote
Apparently he's a lawn ornament. Laughing
PostPosted: 07:59 - 15 Nov 2017    Post subject: Reply with quote
Doubtful that MOT would notice but what you've put in is a long way from being adequate IMO. It's already visibly bending in the photo.
You've removed a M12 fine thread shouldered cap screw for a hardware- store M12 coarse bolt. Just losing the shoulder and measuring down to the thread's minor diameter loses you 71% of cross-section. Now the bolt (screw, actually) that's fitted is probably 8.8 grade but socket cap heads are 10.9 or 12.9 - each 125% and 146% stronger respectively - that's if the new fastener even reaches 8.8 spec.
A 71% reduction in cross-section and possible 65% reduction in strength makes your replacement bolt as poor as 46% the capacity of the one you've replace.
Time to re-evaluate what you have there IMO.
Ted
PostPosted: 08:48 - 15 Nov 2017    Post subject: Reply with quote
It's not bending at all, as previously said that's poor photography, also the double nut I think plays tricks on the eye. Considering that in that photo the only weight on the bolt was the swingarm and wheel, and it had only just been fitted, I'd be very concerned if it had bent!
Everything else I'm in agreement with.
arry
PostPosted: 09:02 - 15 Nov 2017    Post subject: Reply with quote
Ah, I see. Did this all happen in a previous incarnation or is this an actual new user with actual issues?
The last post was made 8 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 3.54 - MySQL Queries: 13 - Page Size: 127.37 Kb
