| mudcow007 |
 mudcow007 World Chat Champion
| pepperami |
 pepperami Super Spammer
 Posted: 11:52 - 24 Nov 2017 Post subject: |
I usually lightly screw it back in when checking the level.
I’ve not had any issues using that method  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| Suntan Sid |
 Posted: 12:06 - 24 Nov 2017 Post subject: |
Depends on the manufacturer.
On my, admittedly 30+ year old, Honda the level is taken with the dip stick NOT screwed in, just resting in place! ____________________ "Everybody needs money, that's why they call it money!"  |
| arry |
 arry Super Spammer
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 12:26 - 24 Nov 2017 Post subject: |
| Suntan Sid wrote: | Depends on the manufacturer.
On my, admittedly 30+ year old, Honda the level is taken with the dip stick NOT screwed in, just resting in place! |
This +1
You wouldn't believe how many people take false readings, then overfilling or underfilling their engines, because they had a mate, that had a mate who told a mate........
Also check wether the manual say you take the measurement on the side stand, or main stand or with the both wheels on the ground and the motorcycle being level (CB-1 and also not screwed in). ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| mudcow007 |
 Posted: 12:51 - 24 Nov 2017 Post subject: |
err right ok, just checked it with it screwed in (bike is on center stand) an its just touching the bottom of the stick
So if its not to be screwed in, the oil level is even lower
Bike is Honda Blackbird
just read its not screwed in... fack!
going to go an hunt around work an see if anyone has any oil |
| RhynoCZ |
| mudcow007 |
 Posted: 13:13 - 24 Nov 2017 Post subject: |
I was planning on dropping the oil on Sunday, but worried now the engine is basically dry
Im going to go the garage an get a litre of oil to throw in
cheers all  |
| NJD |
 NJD World Chat Champion
| Polarbear |
 Polarbear Super Spammer
| MCN |
 MCN Super Spammer
| mudcow007 |
| RhynoCZ |
 Posted: 18:20 - 24 Nov 2017 Post subject: |
Was the motorcycle level, horizontally? If you lean it a few millimeters left, it'll show much less and a few right, it'll show a lot more on the dipstick.
I used to measure the oil this way:
1) put it on the side stand (bike leaned left)
2) the dipstick off + clean it + put it back (it's still leaned left, so no oil touches the dipstick yet)
3) balance the motorcycle, horizontally (now you're getting the measurements)
4) put it back on the side stand (gently put it on the sidestand)
5) the dipstick off and read the value
Always got the correct measurement. Be careful not to lean the motorcycle right when balancing it, that would splash the dipstick, just as I was telling you about in the first paraghrap. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| P.addy |
 P.addy Red Rocket
| ThatDippyTwat |
| janner_10 |
 janner_10 World Chat Champion
| Courier265 |
 Courier265 World Chat Champion
| davebike |
 davebike World Chat Champion
 Posted: 12:46 - 30 Nov 2017 Post subject: |
Always despite what the Keyboard wariers say better overfull than under
Bikes have had good breather systems and have not had an overpressure problem since the 1960's !
Yes I am a trained mechanic (Suzuki) that has worked it or run a workshop since the 1970's
Me I run my FZ6 cub 90 and previous bike at least 10% over full il is cheaper than engine repairs
Never seen overfill dammage seen lots damaged by too little!! ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| RhynoCZ |
 Posted: 13:14 - 30 Nov 2017 Post subject: |
| davebike wrote: | Always despite what the Keyboard wariers say better overfull than under
Never seen overfill dammage seen lots damaged by too little!! |
That's exactly why there is the MIN and MAX notch on the glass/dipstick. Running low on oil isn't about someone not puting in enough. It's about oil consumption. How much is too much is stated in your owner's manual. Just because you overfill it you won't cure the issue.
In a car engine the difference between the MIN and MAX notch may be even 2L+ of oil and some cars do actually require refilling as you go and you wouldn't possibly be able to overfill the engine so the oil would last to the next oil change (Mazda petrol engines).
The issue with oil consumption is, it may vary + may also drastically change to worse as your engine ages, due to various reasons, internal and external oil leaks.
Yes, you are a trained mechanic, I do believe that. But your views seem very ''I don't give a feck, it works'' and that's never good. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
The last post was made 8 years, 293 days ago. Instead of replying here, would creating a new thread be more useful? |
