Dip stick oil level
mudcow007
PostPosted: 11:44 - 24 Nov 2017    Post subject: Dip stick oil level Reply with quote
Stupid question this, but ive always had bikes with sight glasses....
when checking oil levels with a dip stick, do you remove said dipstick, wipe it clean then rescrew it in then remove to check level
or just remove it, wipe it an push it back in (so its sitting unscrewed in)
if that makes sense??
pepperami
PostPosted: 11:52 - 24 Nov 2017    Post subject: Reply with quote
I usually lightly screw it back in when checking the level.
I’ve not had any issues using that method Thumbs Up
Suntan Sid
PostPosted: 12:06 - 24 Nov 2017    Post subject: Reply with quote
Depends on the manufacturer.
On my, admittedly 30+ year old, Honda the level is taken with the dip stick NOT screwed in, just resting in place!
arry
PostPosted: 12:09 - 24 Nov 2017    Post subject: Reply with quote
As above, depends on manufacturer. I've had one of both, ie screw all the way in and then unscrew to check, and one where manual says to rest it on top.
Need to check manual.
RhynoCZ
PostPosted: 12:26 - 24 Nov 2017    Post subject: Reply with quote
This +1
You wouldn't believe how many people take false readings, then overfilling or underfilling their engines, because they had a mate, that had a mate who told a mate........
Also check wether the manual say you take the measurement on the side stand, or main stand or with the both wheels on the ground and the motorcycle being level (CB-1 and also not screwed in).
mudcow007
PostPosted: 12:51 - 24 Nov 2017    Post subject: Reply with quote
err right ok, just checked it with it screwed in (bike is on center stand) an its just touching the bottom of the stick Shocked Shocked
So if its not to be screwed in, the oil level is even lower
Bike is Honda Blackbird
just read its not screwed in... fack!
going to go an hunt around work an see if anyone has any oil
RhynoCZ
PostPosted: 13:01 - 24 Nov 2017    Post subject: Reply with quote
When is the oil change due? If soon, just drain it and put in the right amount of oil (read the manual).
mudcow007
PostPosted: 13:13 - 24 Nov 2017    Post subject: Reply with quote
I was planning on dropping the oil on Sunday, but worried now the engine is basically dry
Im going to go the garage an get a litre of oil to throw in
cheers all Thumbs Up
NJD
PostPosted: 14:40 - 24 Nov 2017    Post subject: Reply with quote
You measuring it cold or just after a run?
Far as I understand it you'll need to let it settle before taking a measurement.
On the Arrow I used to go for 3 / 4 x's on the dipstick out of 5; I doubt they're overly accurate.
PostPosted: 14:46 - 24 Nov 2017    Post subject: Reply with quote
In my experience the majority of screw in dip sticks measure the oil level while resting on the threads, not screwed in.
Triumph Trophy Launch Edition
MCN
PostPosted: 16:31 - 24 Nov 2017    Post subject: Reply with quote
/\/\ This.
Some have to be screwed fully in and some just on the thread but not turned into the thread.
O.E.M. Books or website is a good place to start.
mudcow007
PostPosted: 17:14 - 24 Nov 2017    Post subject: Reply with quote
I went out at lunch time an measured again, an the level seemed higher?
The bike had been sat for at least 2 hours the first time I measured etc.
After checking an hour later the oil seemed to be halfway up the dip stick?!
very odd, bike hasnt moved or anything
I bought a litre of cheap oil from local garage to get me home, which i will drop on sunday anyways
Oh an just read my manual an it says check on centre stand, with the stick unscrewed in
cheers
RhynoCZ
PostPosted: 18:20 - 24 Nov 2017    Post subject: Reply with quote
Was the motorcycle level, horizontally? If you lean it a few millimeters left, it'll show much less and a few right, it'll show a lot more on the dipstick.
I used to measure the oil this way:
1) put it on the side stand (bike leaned left)
2) the dipstick off + clean it + put it back (it's still leaned left, so no oil touches the dipstick yet)
3) balance the motorcycle, horizontally (now you're getting the measurements)
4) put it back on the side stand (gently put it on the sidestand)
5) the dipstick off and read the value
Always got the correct measurement. Be careful not to lean the motorcycle right when balancing it, that would splash the dipstick, just as I was telling you about in the first paraghrap.
PostPosted: 21:43 - 24 Nov 2017    Post subject: Reply with quote
Just change it, remove oil and filter, replace with what manual tells you and run for a few minutes. Let it settle and test again. Use that as your reading next time, with it in or out. At that point you know where it 'should' be
ThatDippyTwat
PostPosted: 21:45 - 24 Nov 2017    Post subject: Reply with quote
Depends on Manufacturer. Last 2 bikes, dipstick lightly seated, not screwed in. The 125 cruiser, screwed down until you feel reesistance.
Read your manual.
janner_10
PostPosted: 09:20 - 25 Nov 2017    Post subject: Reply with quote
This. Quite literally a 10 minute job.
Courier265
PostPosted: 15:42 - 25 Nov 2017    Post subject: Re: Dip stick oil level Reply with quote
I just remove, wipe, drop in.... however I always check my levels in the garage because of the perfect flat surface.
davebike
PostPosted: 12:46 - 30 Nov 2017    Post subject: Reply with quote
Always despite what the Keyboard wariers say better overfull than under
Bikes have had good breather systems and have not had an overpressure problem since the 1960's !
Yes I am a trained mechanic (Suzuki) that has worked it or run a workshop since the 1970's
Me I run my FZ6 cub 90 and previous bike at least 10% over full il is cheaper than engine repairs
Never seen overfill dammage seen lots damaged by too little!!
Dave
NC750Xdct + others at work !
[email protected]
RhynoCZ
PostPosted: 13:14 - 30 Nov 2017    Post subject: Reply with quote
That's exactly why there is the MIN and MAX notch on the glass/dipstick. Running low on oil isn't about someone not puting in enough. It's about oil consumption. How much is too much is stated in your owner's manual. Just because you overfill it you won't cure the issue.
In a car engine the difference between the MIN and MAX notch may be even 2L+ of oil and some cars do actually require refilling as you go and you wouldn't possibly be able to overfill the engine so the oil would last to the next oil change (Mazda petrol engines).
The issue with oil consumption is, it may vary + may also drastically change to worse as your engine ages, due to various reasons, internal and external oil leaks.
Yes, you are a trained mechanic, I do believe that. But your views seem very ''I don't give a feck, it works'' and that's never good.
The last post was made 8 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 104.78 Kb
